首页 > 矿用橡套电缆
[技术资料] HPN 检验规范
P:2008-08-20 15:01:06
STYLE : HPN  300V  90℃OR 105℃  FLEXIBLE CORD
Standard:UL 62   UL 1581
Applications:Use in household colocks,fans,radios and similar appliances
Construction Details:
Test Item                                     Style & Size  18AWG/2C
Conductor:Construction   AS41/0.16±0.003    max. lay. length  S 25mm ↓    絞合外徑   Cond. Dia.  1.18mm
Separator: No
Core Insulation:  Material: CPE 氯化聚乙烯/EP 乙丙橡胶    Avg. thickness : 1.14mm  Min. thickness: 1.02mm
导体间距min acceptable distance   无地线 without  grounding  conductor : 2.03mm  有地线 with conductor : 1.02mm
外形尺寸   Over Diameter  長mm:3.5±0.10   寬mm6.9±0.20
外觀          Surface:平滑    顏色  Colors: OPTIONAL
烘箱老化 After ageing in heating cabinet: 抗張強度Tensile Strength 斷裂伸長率 Elongation    136±2℃ 7 DAYS   老化前50%↑
火花電壓試驗   Spark Test  AC 5KV
冷挠試驗 cold bend    -20±2℃  Mandrel  dimameter 12.7mm  ,6 turns of specimen around mandrel
電弧試驗       Arcing  Resistance  48~62Hz 120V 2~30A,20 Cycle/2min
燃燒試驗         Flame  Test : VW-1  FT1 FT2 -F-
mono-crystalline diamond wire drawing die - 单晶金刚石拉线模 (0) 投诉
P:2008-08-20 16:37:12
HPN  18AWG/2C  的检验数据,不错,谢谢分享!
beam - 射束,光束,电子束 (0) 投诉
P:2012-06-19 08:16:05
挺不错的,多谢了。
galvanizing bath - 电镀槽,镀锌槽,锌浴 (0) 投诉
P:2012-07-13 00:48:42
clear bore - (穿电缆的)孔 (0) 投诉
