首页 > 国外线缆
[问题求助] UL Detailed Examination
P:2008-08-15 13:18:57
UL Detailed Examination都检查些什么?
transmission loss - 传输损耗 (0) 投诉
P:2008-08-15 13:46:48
1. Verify Insulation Compound 9.   Covering Thickness
2. Verify Jacket Compound     10.   Conductor Lay Length
3. Conductor Material         11.  Tape Thickness
4. Conductor Dimensions       12.  Tape Overlap
5. Strand Lay Length          13.  Tag Markings
6. Insulation Thickness       14.  Surface Print Markings
7. Jacket Thickness           15.  Recognition Label Denomination
8. Verify extruded covering compound
芝麻开门了 奖励 0 金币,.1 声望,于 2008-8-15 16:47:43 原因:感谢您的回答
AI - artificialintelligence人工智能 (0) 投诉
