[问题求助] 关于1394 9PIN的问题请教
P:2008-08-14 14:26:39
请教各位,1394  9IN的点位定义,及9对9的图纸,9对4图纸,9对6图纸,请不吝告知!
impulse wave - 冲击波,脉冲波 (0) 投诉
P:2008-08-14 14:54:32
规范里找呀
barrier-layer - 阻挡层 (0) 投诉
P:2008-10-09 13:12:17
规范里都有的!
planning department - 企划部 (0) 投诉
P:2008-10-18 08:42:46
4-pin
connector
6-pin
connector
9-pin
connector
Name Descriptioncolor of wire
in cable
 18PowerUnregulated DC; 30 V no loadwhite
 26GroundGround return for power and inner cable shieldblack
131TPB-Twisted-pair B, differential signalsorange
242TPB+Twisted-pair B, differential signalsblue
353TPA-Twisted-pair A, differential signalsred
464TPA+Twisted-pair A, differential signalsgreen
  5A shield
  7 -
  9B shield
ShellOutercable shield
Unmating Force - 拔出力 (日) (0) 投诉
P:2008-10-28 11:51:44
現在都沒有人做ieee1394 了, 價格不好賺呀?
rectangulat bus-bar - 矩形汇流排 (0) 投诉
P:2010-08-11 10:08:03
Thanks
tangent - 切线,正切 (0) 投诉
P:2010-08-29 23:00:31
牛人牛资料
copper sulfate crystallizing bath - 硫酸铜结晶槽 (0) 投诉
P:2011-02-19 13:57:53
牛人牛资料
traverse screw - 排线螺杆 (0) 投诉
