[技术资料] 请教高手帮忙解读(翻译)
P:2008-08-04 09:23:25
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 1       Page 10800       Issued:  2003-11-28
Style 10800
FRPE Jacketed Cable.
Rating
80°C, 300 Volts.
Insulated Singles
Labeled or complying with manufacturer's AWM Procedure.
Singles must be rated minimum 80ºC and 300 V.
Covering
Optional.
Shield
Optional.
Jacket
FRPE, 16 mils minimum average, 12 mils minimum at any point.
Standard
Appliance Wiring Material UL 758.
Instructions
to UL
Representative
Detailed Examination.
Physical Properties of Jacket, Unaged.
The designation of all Styles of the individual conductors used making up the cable assembly shall be available, and the UL Representative’s tag shall indicate if the Style is labeled or not.  If they are not labeled, the appropriate Follow-Up Tests shall be conducted.
UL
Counter-Check
Program
(4)  Detailed Examination.
(4)  Physical Properties of Jacket.
(4)  Heat Shock.
(4)  Deformation.
(4)  Cold Bend.
(12) Horizontal Flame Test.
If the insulated style is not labeled, the appropriate Follow-Up Tests shall be conducted.
Marking
General.
Use
Internal wiring of electronic equipment.
continuous cross-linking machine - 连续交联机 (0) 投诉
P:2008-08-04 09:39:59
UL AWM style 10800
阻燃PE被覆单芯线,其中规定了最小平均及最小厚度
额定值:80C 300V
芯线绝缘必须符合工厂所申请的80C,300V AWM产品
隔离屏蔽遮蔽物是可选择性的
各项测试及检验参考UL758标准
电子设备内部用线
Kemirasorb - 克米拉索伯(芬兰 (0) 投诉
P:2008-08-04 22:34:30
大致如上的解释. 另外就是你们工厂必须要有 AWM STYLE 10800的认证才可生产.
bunching machine with foil-spinner - 有绕包头的束线机,有箔带绕包头的束线机 (0) 投诉
P:2008-08-05 08:14:09
谢谢了!!
wiredrawing emulsion - 拉线乳浊液 (0) 投诉
