首页 > 国外线缆
[问题求助] VDE电线电缆
P:2008-07-29 19:20:17
附件为一VDE的电线规格资料,不知有没有人知道是具体什么的电线,有那些厂可以生产。谢谢!急!!
coil-transporter - 圈线运输装置 (0) 投诉
P:2008-07-29 19:36:57
既然求助,为什么还要大家花钱买信息?
supervisory subnetwork - 监控子网络 (0) 投诉
P:2008-07-29 19:43:08
LAPP电线
PVC绝缘和护套屏蔽电缆
主要是材料
staromix - 混料头<挤出机的> (0) 投诉
P:2008-07-29 19:44:15
无锡线缆:
既然求助,为什么还要大家花钱买信息?
 不好意思。。我没有想到会要用钱。。。
vacuum drying - 真空干燥 (0) 投诉
P:2008-07-29 19:46:44
ÖLFLEX® CLASSIC 110 CY
The EMC-compliant Control Cable with numbered cores VDE certificated
Remark: A RoHS-non-compliant version is marketed under ÖLFLEX® 110 CY with VDE-REG.-Nr. 8067 To order this,
please add appendix <1> to the above stated part numbers. This does not affect the above given further technical
data or description.
Application:
􀂄 Mainly where electrical interference fields caused e.g. by electrical motor driven by frequency
converters, can disturb signal transmissions
􀂄 Further applications similar to ÖLFLEX® CLASSIC 110
Area of use:
􀂄 Plant engineering and construction
􀂄 Conveying and transport systems
􀂄 Measurement and control technology
􀂄 Production lines
􀂄 Air conditioning installations
􀂄 Office machines and systems for data processing
􀂄 Paint-spray lines
Advantage:
􀂄 High shielding coverage and low transfer impedance (max. 250 ohm/km at 30 MHz)
􀂄 The transparent outer sheath protect the tinned copper braiding against soiling and mechanical
damage
􀂄 The 4 kV Test Voltage ensures high insulation performance
􀂄 VDE registered (production monitoring)
􀂄 Largely resistant to oil and chemicals
􀂄 Manufactured free of substances harmful to lacquer (silicone free) and therefore suitable for use in
paint shops
Worth knowing:
􀂄 The copper braid serves as an electromagnetic screening between the internal electric circuits and the
surroundings
Accessories
􀂄 EMC-compliant earthing of the copper braiding with SKINTOP® EMC, see Cable Glands
􀂄 SILVYN® Cable Conduit Systems
􀂄 FLEXIMARK® Cable Marking
􀂄 Cable processing products see \"Cable Accessories\"
Comparable products:
􀂄 UV-resistant cables, see ÖLFLEX® CLASSIC 110 CY black 0.6/1kV or ÖLFLEX® ROBUST 215 C
􀂄 For cables with grey outer sheath, see ÖLFLEX® CLASSIC 115 CY
􀂄 For continuously flexing applications, see appendix Selection Table A2
Technical notes:
􀂄 Flame-retardant acc. to IEC 60332-1-2
􀂄 Further technical information see catalogue appendix: Selection Tables (A) and Technical Tables (T)
Cable Make-up:
􀂄 Fine strands of bare copper wires
􀂄 Core insulation made of LAPP PVC Compound P8/1
􀂄 Black cores with white numbers
􀂄 Cores twisted in layers
􀂄 Inner sheath made of special PVC-based compound, grey-coloured
􀂄 Screen braiding made of tinned copper wires
􀂄 Transparent outer sheath made of special PVC based compound
􀂄 Control and connection cable especially suitable for applications in industrial ambient conditions
􀂄 Mainly in dry, damp or wet interiors under medium mechanical load conditions
􀂄 Outdoor use with UV-protection only, considering the temperature range
􀂄 For free, non-continuously recurring movement application without tensile load or compulsory
guidance as well as for fixed installation
Area of use:
􀂄 Machine engineering
􀂄 Paint-spray lines
􀂄 Power station
ÖLFLEX® CLASSIC 110 Design
􀂄 Mainly where works standard, safety, colour or colour design are required.
ÖLFLEX® CLASSIC 110 Print
􀂄 Printing service in all colours made by ink-jet or using embossing tool (either embossed or embedded)
Advantage:
􀂄 Reduced space requirements due to small outer diameters
paint shops
Worth knowing:
Accessories
􀂄 SKINTOP® and SKINDICHT® cable glands
􀂄 For cables with coloured cores in accordance with VDE 0293-308, see ÖLFLEX® CLASSIC 100 range
􀂄 Appendix Table A2 \"Highly Flexible FD Cables\"
Technical notes:
lower order connection supervision - 低阶连接监测 (0) 投诉
P:2008-07-29 21:12:38
我见过样品,也生产过类似的产品,是德国进口设备指定要用的连接线
dip roll - 浸涂滚轮 (0) 投诉
P:2008-07-29 21:42:28
Fiber Optic Cross-Connect (LGX) Distribution System - 光纤交叉连接 (LGX) 布线系统 (0) 投诉
P:2008-07-30 10:16:09
无锡线缆:
請問仁兄,你公司可以生產嗎?請問你公司在那裡,名稱?謝謝!
computer case - 计算机外壳(组件) (0) 投诉
P:2008-07-30 11:20:29
回答8楼:
无锡市电线厂
www.--wuxiwire.com
(我是回答问题,不是做广告!)
carrier cable junction - 载波电缆连接点 (0) 投诉
P:2008-07-30 13:49:45
我做的线柔软性测试时20000多次时导体刺穿绝缘﹐除了改导体结构及增加绝缘硬度之外还有什么其他办法吗﹖
SPOF - single-mode full polymer optical fiber单模全聚合物光纤 (0) 投诉
P:2008-07-31 20:42:05
线材折弯性能不好,除了增加导体的柔软度外,还可以提高线材整体的抗拉性。
closed-loop take-up tension control system - 收线张力闭环控制系统 (0) 投诉
P:2008-08-01 09:26:12
绝缘及护套的抗张强度要多少比较合适
composite optical communication conductor - 光纤通信组合导线,光纤通信组合架空导线 (0) 投诉
P:2008-08-01 09:49:51
个人认为,跟绝缘护套本身的抗张强度没有多大关系。主要是硬度以及整体结构的“紧凑”。
scissors - 剪刀,线剪 (0) 投诉
