首页 > 国外线缆
[技术资料] 【有效期已过】有需要国外标准的请进来
P:2008-07-24 14:24:10
呵呵,楼主真是太好了!!
代表各位求资料的朋友们感谢一下!!
不知楼主有没有印度电线的相关资料?
IS 694-2005
IS 6538-2001
xiaoxiangtongzi@163.com
另外的印度标准:IS-下面的编号
| 292 : 1983 | Leaded brass ingots and casting (second revision) |
| 694 : 1990 | PVC insulated cables for working voltages up to and including 1 100 V (third revision) |
| 1068 : 1993 | Electroplated coatings of nickel plus chromium and copper plus nickel plus chromium (third revision) |
| 1359 : 1992 | Electroplated coating of tin (third revision) |
| 1573 :1986 | Electroplated coating of zinc on iron and steel (second revision) |
| 2824 : 1975 | Method for determining the comparative tracking index of solid insulating materials under moist conditions (first revision) |
| 3010 | Appliances connectors and appliance-inlets (non-reversible three pin type): |
| 3010 Part 1 : 1965 | Appliances connectors |
| 3010 Part 2 : 1965 | Appliances inlet |
| 9000 Part 5: Sec1 and 2 : 1981 | Basic environmental testing procedures for electronic and electrical items : Part 5 Damp heat cycling test, Section 1, 16 + 8 h cycle, Section 2, 12 + 12 h cycle |
| 9968 Part 1 :1988 | Elastomer-insulated cables: Part 1 For working voltages up to and including 1 100 V (first revision) |
| 11000 Part 2 : Sec 1:1984 | Fire hazard testing: Part 2 Test method, Section 1 Glow wire test and guidance |
| 12063 : 1987 | Classification of degree of protection provided by enclosures of electrical equipment |
| 14340 : 1996 | Brass for current-carrying parts in electrical wiring accessories |
| 14772 : 2000 |
Distributorship - 经销 (0) 投诉
111
