首页 > 国外线缆
[问题求助] UL线材资料标准在哪里找得到?
P:2008-07-24 20:44:55
看看這個,是否對你有幫助.UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 1 *Page 1061 Issued: May 1, 1959
Revised: June 20, 2001
Style 1061 Special PVC - Insulated Wire.
Rating 80°C, 300 Volts.
Conductor No. 30-16 AWG, solid or stranded, tinned or bare copper.
Insulation Extruded Semi-Rigid PVC: 9 mil average, 7 mil minimum at any
point.
Standard Appliance Wiring Material UL 758.
Instructions
to UL
Representative
Detailed Examination.
Physical Properties, unaged.
Flexing.
Spark Test.
UL
Counter-Check
Program
(4) Detailed Examination.
(4) Physical Properties, unaged.
(4) Heat Shock.
(4) Deformation.
(4) Cold Bend.
(4) Horizontal Flame Test.
Marking General.
Use Internal Wiring in Electric Bookkeeping, Accounting,
Time-Recording Machines, or Electronic Equipment if
within a chassis or protected from mechanical injury.
Subject 758 Section 1 *Page 1007 Issued: May 1, 1959
Style 1007 Polyvinyl Chloride Insulated Wire.
____________________________________________________________________________
Rating 80°C, 300 V.
Conductor 32-16 AWG, solid or stranded.
Insulation Polyvinyl Chloride, 15-Mils minimum average,
13 mils minimum at any point, 60 or 80°C in oil,
if applicable.
_____________________________________________________________________________
Instructions Detailed Examination.
to UL Physical Properties, unaged.
Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties.
Program (4) Heat Shock.
(4) Cold Bend
(4) Deformation.
Marking General.
Use Internal wiring of Appliances; or where exposed to oil at
a temperature not exceeding 60°C or 80°C, whichever is
applicable. Tags may indicate the following: 600 V Peak -
For Electronic Use Only.
nickeline wire - 镍合金线<一种高阻合金线> (0) 投诉
