首页 > 电气装备用线缆
[计算机线] 计算机电缆对绞节距
P:2008-07-05 16:35:15
<DIV class=xxxxAd><SCRIPT type=text/javascript></SCRIPT><SCRIPT src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type=text/javascript></SCRIPT><IFRAME name=google_ads_frame marginWidth=0 marginHeight=0 src="http://pagead2.googlesyndication.com/pagead/ads?client=ca-pub-5245470700607411&dt=1215246616296&lmt=1215246616&prev_slotnames=9908240416&output=html&slotname=3492416009&correlator=1215246616203&url=http%3A%2F%2Fwww.dxdlw.com%2FShowPost.asp%3FThreadID%3D33545&ref=http%3A%2F%2Fwww.dxdlw.com%2FShowForum.asp%3FForumID%3D54&frm=0&cc=211&ga_vid=15197406762370068.1215246616&ga_sid=1215246616&ga_hid=1128921051&flash=9.0.0.296&u_h=768&u_w=1024&u_ah=738&u_aw=1024&u_cd=32&u_tz=480&u_java=true" frameBorder=0 width=200 scrolling=no height=200 allowTransparency></IFRAME></DIV>
请教计算机电缆应根据什么原则确定对绞节距(不同绞对),对绞节距的选择对电缆性能有何影响?计算机电缆适用于传输的频率是多少?
回复:因国内还没有标准只参考BS5038英标.节距先择对绞外径的16倍,成缆的话和软电缆一样20-25倍,节距小影响的抗静电干扰,电容平衡,电感等都有影响.计算机电缆传输频率的话,楼上说的对,要看你用在什么地方.
mold cure - 模具硫化 (0) 投诉
