[问题求助] CAT6A UTP有测试标准吗
P:2008-06-27 21:12:53
有正式的CAT6A的测试标准吗?
superfine wire enamelling machine - 超细线漆包机 (0) 投诉
P:2008-06-28 08:34:09
论坛有.
single reel pay-off - 单盘放线装置 (0) 投诉
P:2008-06-28 10:10:15
FREQNEXTATTNRLPPACRPPELFEXTPSNEXTPSACRPSELFEXT
频率近端串扰(dB/100m)衰减回波损耗(dB)信噪比
(MHZ)最差值/典型值/标准值(dB/100m)最差值/典型值/标准值(dB/100m)等效远端串扰近端串扰功率和信噪比功率和等效远端串扰功率和
 ≥≤≥最差值/典型值/标准值(dB/100m)(dB/100m)(dB/100m)(dB/100m)
    ≥保证值/典型值/标准值 ≥最差值/典型值/标准值 ≥最差值/典型值/标准值 ≥最差值/典型值/标准值 ≥
187.0/90.0/74.3220.0/21.5/20.085.0/88.0/72.373.8/75.0/67.885.0/88.0/72.383.0/86.0/70.370.8/72.0/64.8
480.0/90.0/65.33.823.0/24.7/23.076.0/86.0/61.561.8/75.0/55.878.0/88.0/63.374.0/84.0/59.558.0/72.0/52.8
880.0/90.0/60.85.324.5/25.5/24.5874.7/84.0/55.555.7/75.0/49.778.0/88.0/58.872.7/82.0/53.552.7/72.0/46.7
1080.0/90.0/59.3625.0/28.0/25.074.0/84.0/53.353.8/74.0/47.878.0/88.0/57.372.0/82.0/51.350.8/71.0/44.8
1680.0/90.0/56.27.625.0/28.0/25.072.4/82.0/48.649.7/70.0/43.778.0/88.0/54.270.4/80.0/46.646.7/67.0/40.7
2080.0/90.0/54.88.525.0/28.0/25.071.5/81.0/46.347.8/68.0/41.878.0/88.0/52.869.5/79.0/44.344.8/65.0/36.8
2580.0/90.0/53.39.524.3/27.0/24.370.5/80.0/43.845.8/68.0/39.878.0/88.0/51.368.5/78.0/41.842.8/65.0/34.9
31.2580.0/90.0/51.910.723.6/26.5/23.669.3/79.0/41.243.9/64.0/37.978.0/88.0/49.967.3/77.0/39.240.9/61.0/34.9
62.575.3/90.0/47.415.421.5/24.6/21.559.9/74.0/32.037.9/58.0/31.969.1/83.0/45.457.9/72.0/30.034.9/55.0/28.9
10071.1/85.0/44.319.820.1/23.7/20.151.3/65.0/24.533.8/54.0/27.869.1/83.0/42.349.3/63.0/22.530.8/51.0/24.8
20071.1/85.0/39.82918.0/22.2/18.042.1/56.0/10.827.8/51.0/21.869.1/83.0/37.840.1/54.0/8.824.8/48.0/18.8
25071.1/85.0/38.332.817.3/21.6/17.338.2/52.0/5.525.8/48.0/19.861.7/78.0/36.336.2/50.0/3.522.8/45.0/16.8
30063.7/80.0/37.236.416.8/20.7/16.827.3/43.0/0.718.2/45.0/18.261.7/78.0/35.225.3/41.0/-1.321.2/42.0/15.2
35063.7/80.0/36.239.816.3/20.3/16.323.9/40.0/-3.716.9/45.0/16.961.7/78.0/34.221.9/38.0/-5.719.9/42.0/13.9
40063.7/80.0/35.34315.9/16.8/15.920.7/37.0/-7.715.7/45.0/15.761.7/78.0/33.318.7/35.0/-9.719.7/42.0/12.7
45063.7/80.0/34.546.315.5/16.5/15.517.4/33.0/-10.514.7/42.0/14.761.7/78.0/32.515.4/31.0/-12.517.5/39.0/11.7
50063.7/80.0/33.848.915.2/16.1/15.214.8/31.0/-15.113.8/42.0/13.861.7/78.0/31.812.8/29.0/-17.116.8/39.0/10.8
55063.7/80.0/33.251.814.9/15.7/14.911.9/28.0/-18.612.9/42.0/12.961.7/78.0/31.29.9/26.0/-20.616.0/39.0/9.9
60060.0/70.0/32.654.514.7/15.0/14.75.5/15.5/-21.912.2/39.0/12.258.0/68.0/30.63.5/13.5/-23.915.2/36.0/9.2
general view - 总图,外观图,鸟瞰图 (0) 投诉
P:2008-06-28 15:25:03
请问楼上,CAT  6A  UTP是600频率吗,谢谢
pressurized die - 加压模 (0) 投诉
P:2008-06-28 15:31:45
樓主,我給你傳一個,但我不知道你說的正式對不對,你試試看!
wrapping machine - 绕包机,包带机,捆带机 (0) 投诉
P:2008-06-28 15:44:51
顶  快传呀
elastic termination - 弹性终端 (0) 投诉
P:2008-06-29 07:42:42
NOTICE OF DISCLAIMER AND LIMITATION OF LIABILITY   已经有人上传到资料库内,请进入查找关键字。
bore check - 精密小测定器 (0) 投诉
P:2008-06-30 09:04:00
CAT.6A只要測到500MHz,樓主你只要看到500那欄就行了,何必在乎600呢。還是建議你下載我的CAT.6A標準吧
take-up board - 收线盘 (0) 投诉
P:2008-06-30 17:13:36
TKS
pintle-type spooler - 无轴式收线机 (0) 投诉
P:2008-07-05 13:56:57
谢谢  我正要这个
Cable Length Meter - 线缆计米器 (0) 投诉
P:2008-08-07 12:01:50
推销嫌疑,白送好了
optical fiber secondary coating process - 光纤二次涂覆[包覆]工艺 (0) 投诉
P:2008-09-12 14:55:10
ETA-TIA-568B.2-10
CAT.6A的标准已经出来带论坛OK后上传!
poly-organo-siloxane polyolefin - 聚有机硅氧烷聚烯烃 (0) 投诉
P:2008-09-12 15:42:27
PP ELFEXT
这个pp是什么意思??
RW - ring wire塞环线,b线,r线 (0) 投诉
P:2008-09-12 18:23:05
你搜索一下,我传得有上来,是DRAFT6.0的,草案,也不知道有没有正式版的,谁有就上传一份新的来
emulsifying system - 乳化装置 (0) 投诉
P:2008-09-25 10:04:03
ETA-TIA-568B.2-10
carboxylic acid end group - 羟酸端基 (0) 投诉
21
