首页 > 国外线缆
[问题求助] awm2560 60℃ 30V是什么玩意儿? 国内什么类型的可以替代
P:2008-06-17 11:28:32
先谢了,  这破玩意儿我真不理解/
multiconductor cable connector - 多芯电缆连接器 (0) 投诉
P:2008-06-17 11:29:24
 自己顶!
nominal cross-section - 标称截面 (0) 投诉
P:2008-06-17 11:48:41
楼主:是UL的,先搞懂AWM,然后上UL网上查。
建议你到高频区,绝大部分是做UL的。
drycured polyethylene - 干式交联聚乙烯 (0) 投诉
P:2008-06-17 12:22:15
AWM   "American Wire Material" 2560是型号 60C 30V是该类电缆的温度和电压等级要求。具体参考UL 1581
flame-sprayed coating - 火焰喷涂,火焰喷涂法 (0) 投诉
P:2008-06-17 12:49:48
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 2560        Issued:  1972-02-07
                                    Revised:  2003-03-31
Style 2560      PVC Jacketed Cable.
______________________________________________________________________________
Rating      60°C, 30 Volts.
Insulated       Labeled or complies with manufacturer's procedure
Conductors      or see Facing Page.
Assembly        Two or more singles or groups of singles twisted
together.  The singles or groups may be either laid parallel to form a flat cable with no more than three rows of single conductors or groups of conductors or cabled together to form a round cable.  Lay not specified.  Barrier layer and/or fillers optional.  Manufacturer shall maintain a complete description of each assembly.
Shield      Optional.
Jacket      PVC, Class 43.
            Major dia of flat
            cable or dia of round
            cable under jacket in        Minimum         Minimum at
            _______inches             Average (Mils)    Any Point
            0.425 or less             30         24
            0.426 to 0.700            45         36
            0.701 to 1.000            60         48
            1.001 to 1.500            80         64
            1.501 to 2.500             110            88
            2.501 and larger               140            124
Standard        Appliance Wiring Material UL 758.
                                (Continued on Page 2560A)
Subj. 758       Section 2       Page 2560A       Issued:  1972-02-07
                                    Revised:  2003-03-31
Instructions    Detailed Examination.
to UL           Tensile Strength and Elongation of Jacket, Class 43.
Representative
UL          (4)  Detailed Examination.
Counter-Check   (4)  Tensile Strength and Elongation of Jacket, Class 43.
Program     (4)  Heat Shock on Jacket.
            (4)  Deformation on Jacket, Class 43.
            (4)  Cold Bend on Completed Cable, Class 43
*           (12) Cable Flame Test on Completed Cable.
Marking     General.
Use         Interconnecting cable for use with EDP equipment where
            terminated in connectors and located entirely exterior
            to the equipment, Class 2 wiring systems only.
ominibus bar - 汇流线,母线 (0) 投诉
P:2008-06-17 13:48:08
是美国UL标准.
UL 758  AWM STYLE PAGE 内的一个型号.AWM 是(器具用线) 具体测试要求和方法参考UL1581.
催老大已经把UL的标准要求给你了。 这样你应该可以明白了.
paper insulated concentric quad - 纸绝缘同心四线组 (0) 投诉
P:2008-06-18 08:37:03
谢谢各位帮助扫盲, 这回有点明白了
再问个"地下室"问题, 电线电缆的国标跟UL有对应关系吗?
wire break control system - 断线控制系统 (0) 投诉
P:2008-12-17 21:11:59
UL1581 中文版
efficiency - 效率,效力,效应,效果 (0) 投诉
