首页 > 标准共享
[国外标准] MIL-C-915/6K-2002 CABLE, POWER ELECTRICAL, 600 VOLTS, FOR OUTBOARD USE ONLY? (NOT FOR INB0ARD USE), TYPE THOF
P:2025-09-28 17:22:00
MIL-C-915/6K-2002 CABLE, POWER ELECTRICAL, 600 VOLTS, FOR OUTBOARD USE ONLY(NOT FOR INB0ARD USE), TYPE THOF.pdf
acrylamide - 丙烯酸酯 (0) 投诉
P:2025-09-30 07:55:21
cable sheath length - 电缆皮长(线路两点间距离乘电缆条数) (0) 投诉
P:2025-09-30 07:55:28
steel-cored aluminium conductor - 钢芯铝绞线 (0) 投诉
