首页 > 标准共享
[国外标准] IEC 60811-506-2012 Electric and optical fibre cables- Test methods for non-metallic materialsPart 506
P:2025-09-04 15:01:16
IEC 60811-506-2012 Electric and optical fibre cables- Test methods for non-metallic materialsPart 506: Mechanical tests-lmpact test at low temperature for insulations and sheaths.pdf
PCD drawing die - 聚晶钻石拉线模 (0) 投诉
P:2026-08-06 08:54:05
挺好
flexed - 【医】曲折的,屈曲 (0) 投诉
