首页 > 标准共享
[国外标准] MS 2112-5-2009 ELECTRIC CABLE AND WIRE POLYVINYL CHLORIDE (PVC) INSULATED CABLES OF RATED VOLTAGES UP TO AND INCLUDING 450/750V PART 5: FLEXIBLE CABLES
P:2025-08-23 14:49:19
MS 2112-5-2009 ELECTRIC CABLE AND WIRE POL YVINYLCHLORIDE (PVC) INSULAτED CABLESOF RATED VOLTAGES UP TO AND INCILUIDING 450/750V PART 5: FLEXIBLE CABLES.pdf
length/diameter ratio ratio - 长径比 (0) 投诉
P:2025-09-06 16:08:36
segmental - 弓形导体,异形导体,扇形导体,分割导体 (0) 投诉
