首页 > 技术资料共享
[技术资料] 印度尼西亚电缆与中国电缆对应
P:2025-02-19 15:20:27
MODEL PRODUKPERUSAHAAN DAN STANDART IMPLEMENTASI
NO | TYPEIADONESIA | KODE STANDAR SN! | TYPE CHINA | STRUKTUR pRODUK | SPESIFKASIPRODUK |
1 | NYA(450-750V) | SNI 046629.3-2006 | BV(450-750V) | Cu/PVC | 1INTI,1.5mm2-300mm2 |
2 | NAYA(450-750V) | SNI 046629.3-2006 | BLV(450-750V) | Al/PVC | 1INTI,1.5mm2-300mm2 |
3 | NYAF(450-750V) | SNI 046629.3-2006 | BVR(450-750V) | Cu/PVC-f | 1INTI,1.5mm2-300mm2 |
4 | NYM(300-500V) | SNI 046629.4-2006 | BVWV(300-500V) | Cu/PVC/PVC | 2-5 INTI,1.5mm2-35mm2 |
5 | NYMHY(300-500V) | SNI 056629.5-2006 | RVV(300-500V) | Cu/PVC/PVC-f | 1-37 INTI,0.75mm2-10mm2 |
6 | NYY(0,6-1KV) | SNI IEC60502-1:2009 | VWf0,6-1KV) | Cu/PVC/PVC | 1-5 INTI,1.5mm2-300mm2 |
7 | NAYY(0,6-1KV) | SNI IEC60502-1:2009 | VLV (0,6-1KV) | Al/PVC/PVC | 1-5 INTI,1.5mm2-300mm2 |
8 | NYYHY(0,6-1KV) | SNI IEC60502-1:2009 | WR(0,6-1KV) | Cu/PVC/PVC-f | 1-5INTI,1.5mm2-300mm2 |
9 | NYBY(0,6-1KV) | SNI IEC 60502-1:2009 | VV22(0,6-1KV) | Cu/PVC/DSTA/PVC | 1-5 INTI,1.5mm2-300mm2 |
10 | NAYBY(0,6-1KV) | SNI IEC60502-1:2009 | VLV22(0,6-1KV) | Ai/PVC/DSTA/PVC | 1-5 INTI,1.5mm2-300mm2 |
11 | N2XY(0,6-1KV) | SNI IEC60502-1:2009 | YJV (0,6-1KV) | Cu/XLPE/PVC | 1-5 INT1,1.5mm2-300mm2 |
12 | NA2XY(0,6-1KV) | SNI IEC60502-1:2009 | YJLV (0,6-1KV) | Al/XLPE/PVC | 1-5 INTI,1.5mm2-300mm2 |
13 | N2XBY(0,6-1KV) | SNI IEC60502-1:2009 | YJV22(0,6-1KV) | Cu/XLPE/DSTA/PVC | 1-5INTI,1.5mm2-300mm2 |
14 | NA2XBY(0,6-1KV) | SNI IEC60502-1:2009 | YJLV22(0,6-1KV) | Al/XLPE/DSTA/PVC | 1-5INTI,1.5mm2-300mm2 |
15 | NYSY(0,6-1KV) | IEC60332 | VVP2(0,6-1KV) | Cu/PVC/CTS/PVC | 1-5 INTI,1.5mm2-300mm2 |
16 | N2XY-FR(0,6-1KV) | IEC60332 BS-6387 | ZR-YJV(0,6-1KV) | Cu/XLPE/LSZH | 1-5INTI,1.5mm2-300mm2 |
17 | N2XY-FRC(0,6-1KV) | IEC 60331BS-6387 | NH-YJV(0,6-1KV) | Cu/MT/XLPE/LSZH | 1-5 INTI,1.5mm2-300mm2 |
18 | NA2XY-FR(0,6-1KV) | IEC60332 BS-6387 | ZR-YJLV(0,6-1KV) | Al/XLPE/LSZH | 1-5 INTI,1.5mm2-300mm2 |
19 | NA2XY-FRC {0,6-1KY) | EC60331BS-5387 | NH-YEV 0,6-1KV) | Al/MT/XLPEASZH | 1-5INT!,1.5mm2-300mm2 |
20 | N2XBY-FR(0,6-1KV) | IEC60332BS-6387 | ZR-YJV22(0,6-1KV) | Cu/XLPE/DSTA/LSZH | 1-5 INTI,1.5mm2-300mm2 |
21 | N2XBY-FRC(0,6-1KV) | IEC60331BS-6387 | NH-YJV22(0,6-1KV) | Cu/MT/XLPE/DSTA/LSZH | 1-5 INTI,1.5mm2-300mm2 |
22 | NA2XBY-FR(0,6-1KV) | IEC60332 BS-6387 | ZR-YJLV22(0,6-1KV) | Al/XLPE/DSTA/LSZH | 1-5 INTI,1.5mm2-300mm2 |
23 | NA2XBY-FRC(0,6-1KV) | IEC60331BS-6387 | NH-YJLV22(0,6-1KV) | Al/MT/XLPE/DSTA/LSZH | 1-5 INTI,1.5mm2-300mm2 |
24 | NSLFF(300-500V) | KAWAT LAS | 1INTI,16mm2-120mm2 | ||
25 | EH-(300/500) {WELDiNGMACHiNE CABLE) | KAWAT LAS | 1INT1,16mm2-120mm2 | ||
26 | YSLY(450-750V) | BS EN 50288-7 | KW(450-750V) | Cu/PVC/PVC | 1-37 INTI,0.75mm2-6mm2 |
27 | YSLYF (450-750V) | BS EN 50288-7 | KVVR(450-750V) | Cu/PVC/PVC-f | 1-37 INTI,0.75mm2-6mm2 |
28 | YSLBY(450-750V) | BS EN 50288-7 | KWV22(450-750V) | Cu/PVC/DSTA/PVC | 1-37 INTI,0.75mm2-6mm2 |
29 | YSLCY(450-750V) | BS EN 50288-7 | KVVP(450-750V) | Cu/PVC/CWB/PVC | 1-37 INTI,0.75mm2-6mm2 |
30 | YSLCYF(450-750V) | BS EN 50288-7 | KVVRP(450-750V) | Cu/PVC/CWB/PVC-f | 1-37 INTI,0.75mm2-6mm2 |
31 | YSLCBY(450-750V) | BS EN 50288-7 | KVVP22(450-750V) | Cu/PVC/CWB/DSTA/PVC | 1-37 INTI,0.75mm2-6mm2 |
32 | YSLCBYF(450-750V) | BS EN 50288-7 | KVVRP22(450-750V) | Cu/PVC/CWB/DSTA/PVC-f | 1-37 INTI,0.75mm2-6mm2 |
33 | YSLY-FR(450-750V) | 8S EN 50288-7IEC-60332 | ZR-KW(450-750V) | Cu/PVC/LSZH | 1-37 INTI,0.75mm2-6mm2 |
34 | YSLY-FRC(450-750V) | BS EN 50288-7IEC-60331 | NH-KW(450-750V) | Cu/MT/PVC/LSZH | 1-37 INTL,0.75mm2-6mm2 |
35 | YSLCY-FR(450-750V) | BS EN 50288-7 IEC-60332 | ZR-KVVP(450-750V) | Cu/PVC/CWB/LSZH | 1-37 INTI,0.75mm2-6mm2 |
36 | YSLCY-FRC(450-750V) | BS EN50288-7IEC-60331 | NH-KVVP(450-750V) | Cu/MT/PVC/CWB/LSZH | 1-37 INTI,0.75mm2-6mm2 |
37 | NYMHCY(450-750V) | BS EN 50288-7 | RVVP(450-750V) | Cu/PVC/CWB/LSZH-f | 1-37 INTI,0.75mm2-6mm2 |
38 | NYMHCY-FR(450-750V) | BS EN 50288-7IEC-60332 | ZR-RWP(450-750V) | Cu/PVC/CWB/LSZH-f | 1-37 INTI,0.75mm2-6mm2 |
39 | NYMHCY-FRC(450-750V) | BS EN 50288-7IEC-60331 | NH-RVVP(450-750V) | Cu/MT/PVC/CWB/LSZH-f | 1-37 INTI,0.75mm2-6mm2 |
40 | LIYCY-CY(450-750V) | BS EN 50288-7 | DJVPVP(450-750V) | Cu/PVC/CWB/CWB/PVC | 1-37 INTI,0.75mm2-6mm2 |
41 | LIYCY-CY-FR(450-750V) | BS EN50288-7IEC-60332 | ZR-DJVPVP(450-750V) | Cu/PVC/CWB/CWB/LSZH | 1-37 INTI,0.75mm2-6mm2 |
42 | LIYCY-CY-FRC(450-750V) | BS EN50288-7IEC-60331 | NH-DJVPVP(450-750V) | Cu/MT/PVC/CWB/CWB/LSZH | 1-37 INTI,0.75mm2-6mm2 |
43 | N2XCBY(450-750V) | BS EN 50288-7 | KYJVP22(450-750V) | Cu/XLPE/CWB/PVC | 1-37 INTI,0.75mm2-6mm2 |
44 | N2XCBY-FR(450-750V) | BS EN50288-7 IEC-60332 | ZR-KYJVP22(450-750V) | Cu/XLPE/CWB/LSZH | 1-37 INTI,0.75mm2-6mm2 |
45 | N2XCBY-FRC(450-750V) | BS EN50288-7EC-60331 | NH-KYIVP22{450-750v | Cu/MTNLPE/CWB/LSZH | 1-37INT,0.75mm2-6mm2 |
hopper dryer - 带干燥器的加料斗(挤出机的) (0) 投诉
