[材料信息] 屏蔽用铍、钼、钨、钛金属箔
P:2024-08-10 14:06:40
Beryllium Foil/铍金属箔 0.0015mm Thick
Beryllium Foil /铍金属箔0.005mm Thick
Beryllium Foil /铍金属箔0.0lmm Thick
Beryllium Foil /铍金属箔0.125mm Thick
Beryllium Foil/铍金属箔 0.5mm Thick
Beryllium Foil /铍金属箔1mm Thick
Beryllium Foil /铍金属箔2mm Thick
Titanium 钛金属箔
钛金属箔 0.0025mm Thick Titanium Grade 1 Foi
钛金属箔 0.002mm Thick Titanium Grade 1 Foil
钛金属箔 0.003mm Thick Titanium Grade 1 Foil
钛金属箔 0.004mm Thick Titanium Grade 1 Foil
钛金属箔 0.005mm Thick Titanium Grade 1 Foil
钛金属箔 0.006mm Thick Titanium Grade 1 Foil
钛金属箔 0.007mm Thick Titanium Grade 1 Foil
钛金属箔 0.008mm Thick Titanium Grade 1 Foil
钛金属箔 0.009mm Thick Titanium Grade 1 Foil
钛金属箔 0.012mm Thick Titanium Grade 1 Foil
钛金属箔 0.015mm Thick Titanium Grade 2 Foil
钛金属箔 0.025mm Thick Titanium Grade 2 Foil
钛金属箔 0.02mm Thick Titanium Grade 2 Foil
钛金属箔 0.05mm Thick Titanium Grade 2 Foil
钛金属箔 0.075mm Thick Titanium Grade 2 Foil
钛金属箔 0.125mm Thick Titanium Grade 2 Foil
钛金属箔 0.14mm Thick Titanium Grade 2 Foil
钛金属箔 0.1mm Thick Titanium Grade 2 Foil
钛金属箔 0.25mm Thick Titanium Grade 2 Foil
钛金属箔 0.2mm Thick Titanium Grade 2 Foil
钛金属箔 0.025mm Thick Titanium Grade 5 Foi!
钛金属箔 0.075mm Thick Titanium Grade 5 Foil
钛金属箔 0.15mm Thick Titanium Grade 5 Foil
钛金属箔 0.lmm Thick Titanium Grade 5 Foil
钛金属箔 0.25m Thick Titanium Grade 5 Foil
钛金属箔 0.2m Thick Titanium Grade 5 Foil
钛金属箔 0.3m Thick Titanium Grade 5 Foil
钛金属箔 0.4m Thick Titanium Grade 5 Foil
钛金属箔 0.52m Thick Titanium Grade 5 Foil
钛金属箔 0.6m Thick Titanium Grade 5 Foil
钛金属箔 Titanium Micro Foil 0.00lmm Thick
钛金属箔 Titanium Micro Foil 0.0025mm Thick
钛金属箔 Titanium Micro Foil 0.002mm Thick
钛金属箔 Titanium Micro Foil 0.003mm Thick
钛金属箔 Titanium Micro Foil 0.004mm Thick
钛金属箔 Titanium Micro Foil 0.005mm Thick
钛金属箔 Titanium Micro Foil 0.006mm Thick
钛金属箔 Titanium Micro Foil 0.007mm Thick
钛金属箔 Titanium Micro Foil 0.008mm Thick
钛金属箔 Titanium Micro Foil 0.009mm Thick
铂贵金属箔
铂贵金属箔 Platinum Foil 0.0005mm Thick-Purity: 99.85%
铂贵金属箔 Platinum Foil 0.00075mm Thick-Purity: 99.85%
铂贵金属箔Platinum Foil 0.00125mm Thick- Purity: 99.95% As Rolled
铂贵金属箔Platinum Foil 0.0015mm Thick - Purity: 99.95% As Rolled
铂贵金属箔Platinum Foil 0.001mm Thick-Purity: 99.85%
铂贵金属箔Platinum Foil 0.00lmm Thick- Purity: 99.95%
铂贵金属箔Platinum Foil 0.002mm Thick- Purity: 99.95% As Rolled
铂贵金属箔Platinum Foil 0.003mm Thick - Purity: 99.95% As Rolled
铂贵金属箔Platinum Foil 0.004mm Thick -Purity: 99.95% As Rolled
钼金属箔
钼金属箔Molybdenum Foil 0.00lmm Thick
钼金属箔Molybdenum Foil 0.0025mm Thick
钼金属箔Molybdenum Foil 0.002mm Thick
钼金属箔Molybdenum Foil 0.003mm Thick
钼金属箔Molybdenum Foil 0.004mm Thick
钼金属箔Molybdenum Foil 0.005mm Thick
钼金属箔Molybdenum Foil 0.006mm Thick
钼金属箔Molybdenum Foil 0.007mm Thick
钼金属箔Molybdenum Foil 0.008mm Thick
钼金属箔Molybdenum Foil 0.009mm Thick
钨金属箔
钨金属箔Tungsten (w) Foil-0.05mm Thick
钨金属箔Tungsten (W) Foil-0.127mm Thick
钨金属箔Tungsten (W) Foil-0.lmm Thick
钨金属箔Tungsten (W) Foil-0.254mm Thick
钨金属箔Tungsten (W) Foil-0.2mm Thick
钨金属箔Tungsten (W) Foil-0.3mm Thick
钨金属箔Tungsten (W) Foil-0.5mm Thick
金属箔
金属箔Tantalum Foil 0.0005mm Thick
金属箔Tantalum Foil 0.0015mm Thick
金属箔Tantalum Foil 0.001mm Thick
金属箔Tantalum Foil 0.0020mm Thick
金属箔Tantalum Foil 0.0025mm Thick
金属箔Tantalum Foil 0.125mm Thick
金属箔Tantalum Foil 0.15mm Thick
金属箔Tantalum Foil 0.25mm Thick
金属箔Tantalum Foil 0.3mm Thick
金属箔Tantalum Foil 0.4mm Thick
镍基合金系 箔材
镍基合金箔 Waspaloy Foil 0.025mm Thick
镍基合金箔 Waspaloy Foil 0.25mm Thick
镍基合金箔 Waspaloy Foil lmm Thick
镍基合金箔 Nitinol Foil 0.125mm Thick
镍基合金箔 Nitinol Foil 0.lmm Thick
镍基合金箔 Nitinol Foil 0.5mm Thick
镍基合金箔 Alloy K/Nilo K/Kovar 0.015mm Thick Foil
镍基合金箔 Alloy K/Nilo K/Kovar 0.025mm Thick Foil
镍基合金箔 Alloy K/Nilo K/Kovar 0.05mm Thick Foil
镍基合金箔 Alloy K/ Nilo K/ Kovar 0.075mm Thick Foil
镍基合金箔 Alloy K/Nilo K/ Kovar 0.125mm Thick Foil
镍基合金箔 Alloy K/Nilo K/Kovar 0.20mm Thick Foil
镍基合金箔 Alloy K/Nilo K/Kovar 0.25mm Thick Foil
镍基合金箔 Alloy K/ Nilo K/Kovar 0.30mm Thick Foil
镍基合金箔 Alloy K/Nilo K/Kovar 0.50mm Thick Foil
镍基合金箔 Alloy K/Nilo K/Kovar 0.75mm Thick Foil
镍基合金箔 Alloy 825 Foil 0.075mm Thick-As Rolled
镍基合金箔 Alloy 825 Foil 0.5mm Thick
镍基合金箔 InconelX750 Foil 0.028mm Thick -As Rolled
镍基合金箔 InconelX750 Foil 0.075mm Thick-Annealed
镍基合金箔 InconelX750 Foil 0.075mm Thick -As Rolled
镍基合金箔 InconelX750 Foil 0.25mm Thick-Annealed
镍基合金箔 Inconel X750 Foil lmm Thick-Annealed
镍基合金箔 Alloy 718 Foil 0.10mm Thick
镍基合金箔 Alloy 718 Foil 0.20mm Thick
镍基合金箔 Alloy 718 Foil 0.50mm Thick
镍基合金箔 Alloy 718 Foil 1.0mm Thick
镍基合金箔 Alloy 718 Foil 2.0mm Thick
镍基合金箔 Alloy 718 Foil 5.0mm Thick
镍基合金箔 Alloy 625 Foil 0.025mm Thick
镍基合金箔 Alloy 625 Foil 0.10mm Thick
镍基合金箔Alloy 625 Foil 0.20mm Thick
镍基合金箔 Alloy 600 Foil 0.0125mm Thick
镍基合金箔 Alloy 600 Foil 0.025mm Thick
镍基合金箔 Alloy 600 Foil 0.05mm Thick
镍基合金箔 Alloy 600 Foil 0.075mm Thick
镍基合金箔 Alloy 600 Foil 0.1mm Thick
镍基合金箔 Alloy 600 Foil 0.2mm Thick
镍基合金箔 Alloy 600 Foil 0.5mm Thick
镍基合金箔 Alloy 600 Foil 0.6mm
镍基合金箔 Alloy 600 Foil 1.0mm Thick
镍基合金箔 Monel 400 Foil 0.025mm Thick
镍基合金箔 Monel 400 Foil 0.03mm Thick
镍基合金箔 Monel 400 Foil 0.05mm Thick
镍基合金箔 Monel 400 Foil 0.075mm Thick
镍基合金箔 Monel 400 Foil 0.125mm Thick
镍基合金箔 Monel 400 Foil 0.12mm Thick
镍基合金箔 Monel 400 Foil 0.2mm Thick
镍基合金箔 Monel 400 Foil 0.3mm Thick
镍基合金箔 Monel 400 Foil 0.5mm Thick
镍基合金箔 Monel 400 Foil 2mm Thick
镍基合金箔 Nickel 200(99.9%) Foil 0.05mm
镍基合金箔 Nickel 200(99.9%) Foil 0.075mm Thick
镍基合金箔 Nickel 200(99.9%) Foil 0.125mm Thick
镍基合金箔 Nickel200 (99.9%) Foil 0.15mm Thick
镍基合金箔 Nickel 200(99.9%) Foil 0.1mm Thick
镍基合金箔 Nickel 200(99.9%) Foil 0.25mm Thick
镍基合金箔 Nickel 200(99.9%) Foil 0.2mm Thick
镍基合金箔 Nickel 200(99.9%) Foil 0.30mm Thick
镍基合金箔 Nickel 200(99.9%) Foil 0.50mm Thick
哈氏合金箔Hastelloy C276 Foil 0.025mm Thick-As Rolled
哈氏合金箔Hastelloy C276 Foil 0.05mm Thick-Annealed
哈氏合金箔Hastelloy C276 Foil 0.075mm Thick-Annealed
哈氏合金箔Hastelloy C276 Foil 0.075mm Thick- Hard
哈氏合金箔Hastelloy C276 Foil 0.15mm Thick-Annealed
哈氏合金箔Hastelloy C276 Foil 0.5mm Thick-Annealed
哈氏合金箔Hastelloy C276 Foil lmm Thick-Annealed
镍基合金箔Alloy 36 Foil 0.008mm
镍基合金箔Alloy 36 Foil 0.0125mm
镍基合金箔Alloy 36 Foil 0.02mm
镍基合金箔Alloy 36 Foil 0.05mm
镍基合金箔Alloy 36 Foil 0.08mm
镍基合金箔Alloy 36 Foil 0.125mm
镍基合金箔Alloy 36 Foil 0.25mm
镍基合金箔Alloy 36 Foil 0.50mm
镍基合金箔Alloy 36 Foil 0.75mm
更多信息随时欢迎咨询:
上海富熬电子科技有限公司
分销航空、航天相关特种产品品牌如下:
2、连接器合作品牌:SOURIAU、AERO- ELECTRIC、 AirBorn、 AMP、ARMEL 、Amphenol、 Cinch、 TE、 ITT、 Radiall、 Rockwell、 Tri-Star、Positronic、Glenair、 Deutsch、THALES等;
3、线缆合作品牌:Nexans、 Carlisle、Harbour、 Nexans、 Micro-Coax、 Draka、 Gore、 Raychem、Thermax;
4、集成电路合作品牌:AD、IDT、NS、SATCON、TI、VICOR、INTERSIL、MICROSEMI、LATTICE;
5、开关/继电器/传感器合作品牌: EATON、HONEYWELL、LEACH、ENDEVCO、DEUTSH、DRI、ECE、GRAYHILL、EMRISE,SAFRAN、SENSATA 、STACOSYSTEMS
6、特种高端贵金属、高温合金丝、 带、板、箔 Ultra fine wir、plate、strip、foil
上海富熬电子科技有限公司
sodium conductor cable - 钠导体电缆,钠芯电缆 (0) 投诉
