[材料信息] 特种线缆用贵铂、铑、钯、铱金属箔、超细丝、毛细管
P:2024-08-08 11:01:00
铂、铑、钯、铱金属箔、超细丝、毛细管
??Platinum/铂 贵金属箔、超细丝、毛细管
Platinum Foil/铂箔 (Purity: 99.95%) – 0.0075mm Thick
Typical/典型规格: Thickness 0.001mm*25mm*25mm
Platinum Foil /铂箔(Purity: 99.95%) – 0.005mm Thickness;
Platinum Foil /铂箔( 99.95% ) – 0.002mm Thick
Platinum Foil /铂箔( 99.95% ) – 0.0025mm Thick
Platinum Foil/铂箔 ( 99.95% ) – 0.0015mm Thick
Platinum Foil/铂箔 ( 99.85% ) – 0.0005mm Thick
Platinum Tube /铂毛细管(Purity: 99.95%) – 0.5mm OD x 0.42mm ID x 0.04mm Wall
Platinum Tube/铂毛细管( (Purity: 99.95%) – 0.4mm OD x 0.1mm ID x 0.15mm Wall
Platinum ( Purity: 99.95%) Tube/铂毛细管( – 0.6mm OD x 0.5mm ID x 0.05mm Wall
Platinum ( Purity: 99.95%) Tube/铂毛细管( – 0.7mm OD x 0.4mm ID x 0.15mm Wall
Platinum Wire /铂极细丝( Wollaston Wire(Purity: 99.9%) – 0.002mm dia
Platinum /铂极细丝( ( Purity: 99.9%) Wire – 0.01mm dia
Platinum/铂极细丝( ( Purity: 99.9%) Wire – 0.015mm dia
Platinum /铂极细丝( ( Purity: 99.9%) Wire – 0.0125mm dia
?铂铱贵金属 箔
Platinum / Iridium (Pt90/Ir10) Foil/铂铱箔– 0.02mm Thick
Platinum / Iridium Foil (Pt90/Ir10) /铂铱箔– 0.01mm Thick
?铂铑贵金属 箔、极细丝
Platinum / Rhodium (Pt90/Rh10) Foil /铂铑箔– 0.2mm Thick
Platinum Rhodium Wire ( Pt70/Rh30 ) /铂铑线– 0.025mm dia
Pltinum Rhodium Wire ( Pt87/Rh13 ) /铂铑线– 0.015mm dia
Platinum Rhodium Wire ( Pt87/Rh13 ) /铂铑线– 0.025mm dia
Pltinum Rhodium Wire ( Pt87/Rh13 ) /铂铑线– 0.05mm dia
?铑贵金属 箔
Rhodium ( Purity: 99.85%)Foil/铑箔– 0.00075mm Thick
Rhodium ( Purity: 99.85%)Foil/铑箔 – 0.001mm Thick
Rhodium ( Purity: 99.9% )Foil/铑箔– 0.025mmThick
Rhodium Foil (Purity: 99.85%) /铑箔– 0.0005mm Thick
Rhodium Foil (Purity: 99.9%) /铑箔– 0.00025mm Thick
钯贵金属箔、毛细管
Palladium ( Purity: 99.95%)Foil/钯箔 – 0.0025mm Thick
Palladium ( Purity: 99.95%)Foil /钯箔– 0.002mm Thick
Palladium ( Purity: 99.95%)Foil/钯箔 – 0.003mm Thick
Palladium Foil (Purity: 99.75%) /钯箔– 0.0005mm Thick
Palladium Foil (Purity: 99.75%) /钯箔– 0.00075mm Thick
Palladium Foil (Purity: 99.95%)/钯箔 – 0.001mm Thick
Palladium Tube (Purity: 99.95%) /钯箔– 1mm OD x 0.8mm ID x 0.1mm Wall
Palladium Tube (Purity: 99.95%) /钯箔– 2mm OD x 1.6mm ID x 0.2mm Wall
Palladium (99.95%) Tube /钯管– 6.35mm OD x 6.6mm ID x 0.125mm Wall
Palladium (99.95%) Tube/钯管 – 5mm OD x 4.4mm ID x 0.3mm Wall
铱贵金属箔、极细丝
Iridium ( Purity: 99.9%)Foil /铱箔– 0.03mm Thick
Iridium ( Purity: 99.9%)Foil/铱箔– 0.05mm Thick
Iridium Foil (Purity: 99.9%) /铱箔– 0.01mm Thick
Iridium Foil (Purity: 99.9%) /铱箔– 0.025mm Thick
Iridium Wire (Purity: 99.9%) /铱线– 0.075mm dia
Iridium Wire ( Purity: 99.9% )/ 铱线0.125mm dia
更多信息随时欢迎咨询:
上海富熬电子科技有限公司
分销航空、航天相关特种产品品牌如下:
2、连接器合作品牌:SOURIAU、AERO- ELECTRIC、 AirBorn、 AMP、ARMEL 、Amphenol、 Cinch、 TE、 ITT、 Radiall、 Rockwell、 Tri-Star、Positronic、Glenair、 Deutsch、THALES等;
3、线缆合作品牌:Nexans、 Carlisle、Harbour、 Nexans、 Micro-Coax、 Draka、 Gore、 Raychem、Thermax;
4、集成电路合作品牌:AD、IDT、NS、SATCON、TI、VICOR、INTERSIL、MICROSEMI、LATTICE;
5、开关/继电器/传感器合作品牌: EATON、HONEYWELL、LEACH、ENDEVCO、DEUTSH、DRI、ECE、GRAYHILL、EMRISE,SAFRAN、SENSATA 、STACOSYSTEMS
6、特种高端贵金属、高温合金丝、 带、板、箔 Ultra fine wir、plate、strip、foil
上海富熬电子科技有限公司
taper tube - 异径管 (0) 投诉
