电力电缆
[低压力缆] YJV22 4*70 临界产品钢带厚度是多少?
942037057
P:2024-01-21 12:16:59
朋友们 YJV22 4*70 临界产品钢带厚度是多少?
continuous pickling device - 连续酸洗装置
aotuk
P:2024-01-21 12:39:30
rigid type stranding - 刚式绞合
(1)
CT18052410053
P:2024-01-22 08:01:32
sound system - 音响系统
psy
P:2024-01-22 08:04:14
non-magnetic ultraminiature cable - 非磁性超小型电缆
psy
P:2024-01-22 08:06:43
L.F. - low frequency低频
(1)
psy
P:2024-01-22 08:09:45
cold lap - 冷搭焊
(1)
刘岳晓
P:2024-01-22 10:36:50
miniature diameter coaxial cable - 微同轴电缆(同轴对内导体直径在0.6~0.8mm左右,外导体的内径在2.8~3.0mm左右的同轴电缆)
txy541
P:2024-01-22 11:25:04
capacity - 容量;电容;负载量
P:2024-01-22 13:20:15
aluminium ingot - 铝锭
xdjhxq
P:2024-01-22 14:33:45
deep borehole special cable - 深钻井用特种电缆
P:2024-01-22 14:46:09
X-scanner - X扫描仪
FayeDu
P:2024-01-22 16:59:33
0.2*30
cone-shaped flexible die - 锥形软模具(涂覆光纤用)
ZQ331629904
P:2024-01-23 08:20:33
我们用0.5的
semi-stop joint - 半塞止式接头盒
(1)
游客
P:2024-01-23 14:34:15
WL - wired logic布线逻辑
liqi6
P:2024-01-26 08:37:23
submerged arc surfacing wire - 埋弧堆焊填充丝
