首页 > 标准共享
[国外标准] AI-EIA-364(多集合)
P:2023-12-05 11:52:01
ANSI-EIA-364系列标准
ANSI-EIA-364-08C-2015 Crimp Tensile StrengthTest Procedure forElectrical Connectors.pdf
ANSI-EIA-364-08C-2015 电气连接器的压接拉伸强 度测试程序.pdf
ANSI-EIA-364-10G-2017 Fluid Immersion Test Procedurefor Electrical Connectors.pdf
ANSI-EIA-364-10G-2017 电气连接器的液体浸泡测试程序.pdf
ANSI-EIA-364-11C-2014 Resistance to SolventsTest Procedure for ElectricalConnectors and Sockets.pdf
ANSI-EIA-364-09D-2018 电气连接器和触点的耐用性测试程序.pdf
ANSI-EIA-364-12A-2005 Restricted Entry Test Procedurefor Electrical Connectors.pdf
ANSI-EIA-364-12A-2005(R2017)电气连接器的限制性进入测试程序.pdf
ANSI-EIA-364-13E-2011(R2017)交配和不交配的力量 .pdf
ANSI-EIA-364-13E-2011(R2017)Mating and Unmating Force TestProcedure for ElectricalConnectors and Sockets.pdf
ANSI-EIA-364-14B-1999(R2012) Ozone Exposure Test Procedure For Electrical Connectors.pdf
ANSI-EIA-364-14B-1999(R2012) 电连接器的臭氧暴露试验程序.pdf
ANSI-EIA-364-15C-2016 Contact StrengthTest Procedure forElectrical Connectors.pdf
ANSI-EIA-364-15C-2016 电气连接器的接触强度测试程序.pdf
ANSI-EIA-364-16A-2002(R2015)剥离力测试(无焊料包裹的连接器)电气连接器的测试程序.pdf
ANSI-EIA-364-09D-2018 Durability Test Procedure forElectrical Connectors andContacts.pdf
ANSI-EIA-364-17C-2011(R2017)电气连接器和插座的有无电气负载的温度寿命测试程序.pdf
ANSI-EIA-364-17C-2011(R2017)Temperature Life With orWithout Electrical Load TestProcedure for ElectricalConnectors and Sockets.pdf
ANSI-EIA-364-18B-2007(R2012) 电气连接器和插座的视觉和尺寸检查测 试程序.pdf
ANSI-EIA-364-18B-2007(R2012) Visual and Dimensional Inspection Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-19A-2001(R2015) 电气连接器的扭转插件固定测试程序.pdf
ANSI-EIA-364-19A-2001(R2015) Torsional Insert Retention Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-16A-2002(R2015)Stripping Force Test (Solderless Wrapped Connectors) Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-20E-2015 耐受电压 电气连接器、插座和同轴触点 的测试程序.pdf
ANSI-EIA-364-21F-2020 Insulation Resistance Test Procedure for Electrical Connectors, Sockets and Coaxial Contacts.pdf
ANSI-EIA-364-21F-2020 绝缘电阻 电气连接器、插座和同轴触点 的测试程序.pdf
ANSI-EIA-364-22B-2000 (R2012) Simulated Life Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-20E-2015 Withstanding Voltage Test Procedure for Electrical Connectors, Sockets and Coaxial Contacts.pdf
ANSI-EIA-364-23C-2006(R2017) Low Level Contact Resistance Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-23C-2006(R2017) 电连接器和插座的低水平接触电 阻试验程序.pdf
ANSI-EIA-364-24B-1998(R2015) Maintenance Aging Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-22B-2000 (R2012) 电气连接器的模拟寿命测试程序.pdf
ANSI-EIA-364-24B-1998(R2015) 电连接器的维护老化试验程序.pdf
ANSI-EIA-364-25E-2017 电气连接器的探针 损坏测试程序 电气连接器的测试程序.pdf
ANSI-EIA-364-26C-2014 Salt Spray Test Procedure for Electrical Connectors, Contacts and Sockets.pdf
ANSI-EIA-364-26C-2014 电气连接器、触点和插座的盐雾 测试程序.pdf
ANSI-EIA-364-27C-2011(R2017) Mechanical Shock (Specified Pulse) Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-27C-2011(R2017) 机械冲击 (电气连接器和插座的(特定脉冲 )测试程序.pdf
ANSI-EIA-364-11C-2014 对溶剂的抵抗力 电气连接器和插座的测试程序.pdf
ANSI-EIA-364-28F-2011(R2017) 电气连接器和插座的振动测试程 序.pdf
ANSI-EIA-364-25E-2017 Probe Damage Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-29D-2019 电气连接器的触点保持 力测试程序.pdf
ANSI-EIA-364-30A-2002(R2015) Capacitance Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-30A-2002(R2015) 连接器和插座.pdf
ANSI-EIA-364-31E-2017 Humidity Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-31E-2017 电连接器和插座的湿度试验程序.pdf
ANSI-EIA-364-32G-2014 Thermal Shock (Temperature Cycling) Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-32G-2014 电气连接器和插座的热冲击(温 度循环)测试程序.pdf
ANSI-EIA-364-33A-2002(R2015) Inductance Measurement Test Procedure for Electrical Connectors (100 nH – 100 mH).pdf
ANSI-EIA-364-33A-2002(R2015) 电气1的电感测量测试程序.pdf
ANSI-EIA-364-29D-2019 Contact Retention Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-34-2012(R2017)Ambient Condensation Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-35C-2012(R2017)插件留置测试到.pdf
ANSI-EIA-364-35C-2012(R2017)Insert Retention Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-36B-2006(R2013) Determination of Gas-Tight Characteristics Test Procedure for Electrical Connectors, and/or Contact Systems.pdf
ANSI-EIA-364-34-2012(R2017)电气连接器和插座的环境凝结测 试程序.pdf
ANSI-EIA-364-37C-2009(R2015) Contact Engagement and Separation Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-36B-2006(R2013) 测试电气连接器和/或接触系统.pdf
ANSI-EIA-364-38D-2014 Cable Pull-Out Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-38D-2014 电缆拉出测试程序 ,用于 电气连接器的测试程序.pdf
ANSI-EIA-364-39B-1999(R2013) Hydrostatic Test Procedure for Electrical Connectors, Contacts and Sockets.pdf
ANSI-EIA-364-39B-1999(R2013) 电连接器、触点和插座的水压 试验程序.pdf
ANSI-EIA-364-40B-1998(R2015) Crush Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-40B-1998(R2015) 电气连接器的抗压测试程序.pdf
ANSI-EIA-364-41E-2010(R2016) Cable Flexing Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-41E-2010(R2016) 电气连接器的电缆弯曲测试程序.pdf
ANSI-EIA-364-42C-2012 IMPACT TEST PROCEDURE FOR ELECTRICAL CONNECTORS.pdf
ANSI-EIA-364-42C-2012 冲击测试程序 电气连接器的冲击测试程序.pdf
ANSI-EIA-364-43C-2013 Cable Clamping (Bending Moment) Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-43C-2013 电连接器的电缆夹紧(弯矩)试验程 序.pdf
ANSI-EIA-364-44A-1998(R2015) Corona Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-44A-1998(R2015) 电连接器的电晕试验程序.pdf
ANSI-EIA-364-45C-2012 FIREWALL FLAME TEST PROCEDURES FOR ELECTRICAL CONNECTORS.pdf
ANSI-EIA-364-45C-2012 电气连接器的防火墙火焰测试程序.pdf
ANSI-EIA-364-46C-2012 Microsecond Discontinuity Test Procedures for Electrical Connectors, Contacts and Sockets.pdf
ANSI-EIA-364-46C-2012 电连接器、触点和插座的微秒不连续 性试验程序.pdf
ANSI-EIA-364-47A-2001(R2015) 电连接器的导体解开(无焊缠绕连接) 试验程序.pdf
ANSI-EIA-364-47A-2001(R2015) Conductor Unwrap (Solderless Wrapped Connection) Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-49-2013 Ultraviolet Radiation Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-49-2013 紫外线 电连接器和插座的试验程序.pdf
ANSI-EIA-364-50B-2012 Dust (Fine Sand) Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-50B-2012 电连接器的灰尘(细砂)试验程序.pdf
ANSI-EIA-364-51A-2002(R2016) Ice Resistance Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-51A-2002(R2016) 电连接器的抗冰试验程序.pdf
ANSI-EIA-364-53B-2000(R2016) Nitric Acid Vapor Test, Gold Finish Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-53B-2000(R2016) 电气连接器和插座的硝酸蒸汽试 验、金饰面试验程序.pdf
ANSI-EIA-364-54A-1999(R2018) Magnetic Permeability Test Procedure for Electrical Connectors, Contacts, and Sockets.pdf
ANSI-EIA-364-54A-1999(R2018) 导磁插座.pdf
ANSI-EIA-364-55A-2008(R2014) Current Cycling Test Procedure for Electrical Contacts, Connectors, and Sockets.pdf
ANSI-EIA-364-55A-2008(R2014) 电触点、连接器和插座的电流循环 试验程序.pdf
ANSI-EIA-364-56E-2011(R2017)电连接器和插座的耐焊接热 试验程序.pdf
ANSI-EIA-364-56E-2011(R2017)Resistance to Soldering Heat Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-57A-2017 Coupling Pin Strength Test Procedure for Circular Bayonet Electrical Connectors.pdf
ANSI-EIA-364-57A-2017 耦合销强度 圆形卡口电连接器的试验程序.pdf
ANSI-EIA-364-58A Temperature Life with Mechanical Loading for Connectors with Removable Contacts (Static Mechanical Load at Temperature) Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-58A 带可拆卸触点的连接器在机械负 荷下的温度寿命(温度下的静态机 械负荷)电连接器的试验程序.pdf
ANSI-EIA-364-59A-2006(2013) Low Temperature Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-59A-2006(2013) 电连接器和插座的低温试验程序.pdf
ANSI-EIA-364-60A-2008(R2014) General Methods for Testing of Contact Finishes for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-60A-2008(R2014) 电连接器和插座接触光洁度的一般 试验方法.pdf
ANSI-EIA-364-60B-2020 General Methods for Porosity Testing of Contact Finishes for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-37C-2009(R2015) 电气连接器的接触接合和分离测试 程序.pdf
ANSI-EIA-364-28F-2011(R2017) Vibration Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-61A-2014 Resistance to Soldering Heat from Rework Test Procedure for Electrical Connectors and Sockets Mounted on Printed Circuit Boards.pdf
ANSI-EIA-364-61A-2014 印刷电路板上安装的电连接器和插 座的返工试验程序的耐焊接热性.pdf
ANSI-EIA-364-62A-2004(R2017)电连接器和插座的端子 强度试验程序.pdf
ANSI-EIA-364-62A-2004(R2017)Terminal Strength Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-63-2013 Accessory Thread Strength Test Procedure for Circular Electrical Connectors.pdf
ANSI-EIA-364-63-2013 圆形电连接器的附件螺纹强度试验程序.pdf
ANSI-EIA-364-64-2014 Shell Spring Finger Force Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-64-2014 电连接器的外壳弹簧指力 试验程序.pdf
ANSI-EIA-364-65B-2009(R2020) Mixed Flowing Gas Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-65B-2009(R2020) 混合流动气体试验程序 电气连接器和插座.pdf
ANSI-EIA-364-66A-2000(R2013) EMI Shielding Effectiveness Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-66A-2000(R2013) 电连接器的电磁干扰屏蔽效能 试验程序.pdf
ANSI-EIA-364-68A-2001(R2015) Actuating Mechanism Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-68A-2001(R2015) 电连接器的执行机构试验程序.pdf
ANSI-EIA-364-69A-2002(R2015) Low Level Induction Measurement for Electrical Contacts of Electrical Connectors.pdf
ANSI-EIA-364-69A-2002(R2015) 电连接器电触点的低电平感应测量.pdf
ANSI-EIA-364-70C-2014 Temperature Rise Versus Current Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-70C-2014 电连接器和插座的温升与电流的 试验程序.pdf
ANSI-EIA-364-71C-2008(R2014) Solder Wicking (Wave Solder Technique) Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-71C-2008(R2014) 电连接器和插座的焊料芯吸(波峰 焊接技术)试验程序.pdf
ANSI-EIA-364-75A-2009(R2015) 电连接器的雷击试验程序.pdf
ANSI-EIA-364-75A-2009(R2015) Lightning Strike Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-78C-2018 Cavity Leakage Bonding Integrity Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-78C-2018 电连接器的空腔泄漏粘接完整性 试验程序.pdf
ANSI-EIA-364-80-2015 Low Frequency Shielding Effectiveness Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-79-1998(R2015) 电连接器的插入粘结强度试验程序.pdf
ANSI-EIA-364-79-1998(R2015) Insert Bond Strength Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-80-2015 电连接器和插座的低频屏蔽效能试 验程序.pdf
ANSI-EIA-364-81A-2005(R2017)电连接器外壳、连接器组件和插 座的燃烧特性试验程序.pdf
ANSI-EIA-364-81A-2005(R2017)Combustion Characteristics Test Procedure for Electrical Connector Housings, Connector Assemblies and Sockets.pdf
ANSI-EIA-364-82A-2005(R2017)电连接器和插座外壳的塑料腐 蚀性试验程序.pdf
ANSI-EIA-364-82A-2005(R2017)Corrosivity of Plastics Test Procedure for Electrical Connector and Socket Housings.pdf
ANSI-EIA-364-83A-2017 电连接器的外壳对外壳和外壳对 隔板电阻试验程序.pdf
ANSI-EIA-364-83A-2017 Shell-To-Shell and Shell-To-Bulkhead Resistance Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-84-2015 Residual Magnetism Test Procedure for Electrical Connectors Used in Space Applications.pdf
ANSI-EIA-364-84-2015 剩磁测试程序 空间应用中使用的电连接器.pdf
ANSI-EIA-364-85-1996(R2015) General Test Procedure for Assessing Wear and Mechanical Damage Testing of Contact Finishes for Electrical Connectors.pdf
ANSI-EIA-364-86A-2014 Polarizing/Coding Key Overstress Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-85-1996(R2015) 评估电连接器接触涂层磨损和机械 损伤试验的一般试验程序.pdf
ANSI-EIA-364-86A-2014 电连接器和插座的极化/编码键 过应力测试程序.pdf
ANSI-EIA-364-87B-2017 Nanosecond Event Detection Test Procedure for Electrical Connectors, Contacts and Sockets.pdf
ANSI-EIA-364-88A-2009(R2016) Residual Magnetism Test Procedure for Electrical Connectors, Contacts and Sockets.pdf
ANSI-EIA-364-88A-2009(R2016) 电气连接器、触点和插座的残磁 测试程序.pdf
ANSI-EIA-364-90A-2019 Crosstalk Ratio Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems.pdf
ANSI-EIA-364-90A-2019 串扰比 电气连接器、插座、电缆组件或互连 系统的测试程序.pdf
ANSI-EIA-364-91B-2016 电连接器和插座的灰尘试验程序.pdf
ANSI-EIA-364-92-1997(R2014) Wire Bending Test Procedure for Insulation Displacement Contacts (IDC) for Electrical Connectors.pdf
ANSI-EIA-364-91B-2016 Dust Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-92-1997(R2014) 用于电气连接器的绝缘置换触点 (IDC)的电线弯曲测试程序.pdf
ANSI-EIA-364-93-1997(R2015) 用于电气连接器的绝缘置换触点( IDC)的重复导线连接和断开测试程 序.pdf
ANSI-EIA-364-93-1997(R2015) Repeated Wire Connection and Disconnection Test Procedure for Insulation Displacement Contacts (IDC) for Electrical Connectors.pdf
ANSI-EIA-364-94-1997(R2015) Transverse Extraction Force Test Procedure for Insulation Displacement Contacts (IDC) for Electrical Connectors.pdf
ANSI-EIA-364-94-1997(R2015) 用于电气连接器的绝缘位移触点( IDC)的横向拔出力测试程序.pdf
ANSI-EIA-364-95-1999(R2018) Full Mating and Mating Stability Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-95-1999(R2018) 电气连接器的完全配接和配接稳 定性测试程序.pdf
ANSI-EIA-364-96A-2017 Plated Through Hole Integrity Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-96A-2017 电镀通孔完整性测试程序 电连接器的电镀通孔完整性测试程序.pdf
ANSI-EIA-364-97-1997(R2015) Housing Panel Retention Test Procedure for Insulation for Electrical Connectors.pdf
ANSI-EIA-364-97-1997(R2015) 电气连接器绝缘的外壳面板固定测试 程序.pdf
ANSI-EIA-364-98-1997(R2015) 电气连接器的外壳锁定机构强度测试 程序.pdf
ANSI-EIA-364-98-1997(R2015) Housing Locking Mechanism Strength Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-99-1999(R2018) Gage Location and Retention Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-99-1999(R2018) 电气连接器的量具位置和保 留测试程序.pdf
ANSI-EIA-364-100A-2012 Marking Permanence Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-100A-2012 电气连接器和插座的标记永久性测试 程序.pdf
ANSI-EIA-364-101-2000(R2013) Attenuation Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems.pdf
ANSI-EIA-364-101-2000(R2013) 电气连接器、插座、电缆组件或互连系 统的衰减测试程序.pdf
ANSI-EIA-364-103-1998(R2018) Propagation Delay Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems.pdf
ANSI-EIA-364-103-1998(R2018) 电气连接器、插座、电缆组件或 互连系统的传播延迟测试程序.pdf
ANSI-EIA-364-102-1998(R2018) 电气连接器、插座、电缆组件或 互连系统的上升时间衰减测试程 序.pdf
ANSI-EIA-364-106-2000(R2013) Standing Wave Ratio (SWR) Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-106-2000(R2013) 电连接器的驻波比(SWR)测试程序.pdf
ANSI-EIA-364-107A-2019 Eye Pattern and Jitter Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems.pdf
ANSI-EIA-364-107A-2019 电气连接器、插座、电缆 组件或互连系统的眼型和 抖动测试程序.pdf
ANSI-EIA-364-108A-2019 在电连接器、电缆组件或互连系统 的时域和频域测试程序中测量的阻 抗、反射系数、回波损耗和VSWR.pdf
ANSI-EIA-364-108A-2019 Impedance, Reflection Coefficient, Return Loss, and VSWR Measured in the Time and Frequency Domain Test Procedure for Electrical Connectors, Cable Assemblies or Interconnection Systems.pdf
ANSI-EIA-364-109-2003(R2016) Loop Inductance Measurement Test Procedure for Electrical Connectors (1 nH-10 nH).pdf
ANSI-EIA-364-109-2003(R2016) 电连接器(1 nH-10 nH)的回路电 感测量试验程序.pdf
ANSI-EIA-364-110-2006(R2013) Thermal Cycling Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-110-2006(R2013) 电连接器和插座的热循环试验程序.pdf
ANSI-EIA-364-111A-2015 确定电气连接器、插座组件或组 件的总离子污染测试程序.pdf
ANSI-EIA-364-112-2010(R2016) Contact Resistance and Current Rating of Parallel Circuits Test Procedure for Electrical Connectors, Contacts and Sockets.pdf
ANSI-EIA-364-112-2010(R2016) 电气连接器、触点和插座的接触电 阻和平行电路的额定电流测试程序.pdf
ANSI-EIA-364-113-2010(R2016) 电气连接器和插座的触点腐蚀性 测试程序.pdf
ANSI-EIA-364-113-2010(R2016) Corrosivity of Contacts Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-114-2010(R2017) 电气连接器、插座和适用附件的 耦合和脱钩力测试程序.pdf
ANSI-EIA-364-114-2010(R2017) Coupling and Uncoupling Force Test Procedure for Electrical Connectors, Sockets and Applicable Accessories.pdf
ANSI-EIA-364-115-2016 电流过载 电气连接器和插座的测试程序.pdf
ANSI-EIA-364-115-2016 Current Overload Test Procedure for Electrical Connectors and Sockets.pdf
ANSI-EIA-364-116-2015 Pin Contact Stability Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-116-2015 电气连接器的引脚接触 稳定性测试程序.pdf
ANSI-EIA-364-117-2017 Dielectric Breakdown Voltage Test Procedure for Electrical Connectors, Sockets and Coaxial Contacts.pdf
ANSI-EIA-364-117-2017 电连接器、插座和同轴触点的 介电击穿电压试验程序.pdf
ANSI-EIA-364-118-2016 Thermal Shock Test Procedure for Hermetic Electrical Connectors and Sockets.pdf
ANSI-EIA-364-118-2016 密封电连接器和插座的热冲击试 验程序.pdf
ANSI-EIA-364-120-2019 Electrolytic Erosion Test Procedure for Electrical Connectors.pdf
ANSI-EIA-364-120-2019 电解侵蚀试验程序 对于电连接器.pdf
ANSI-EIA-364-1000B-2019 Environmental Test Methodology for Assessing the Performance of Electrical Connectors and Sockets Used in Controlled Environment Applications.pdf
ANSI-EIA-364-1000B-2019 评估性能的环境试验方法 受控环境应用中使用的电连 接器和插座.pdf
ANSI-EIA-364-1002A-2015 Test Methodology for Assessing the performance of Compliant Contact Terminations used as Free Standing Contacts or in Electrical Connectors and Sockets.pdf
ANSI-EIA-364-111A-2015 Determining the Total Ionic Contamination Test Procedure for Electrical Connectors, Socket Assemblies, or Components.pdf
ANSI-EIA-364-1002A-2015 评估用作独立触点或在电连接器 和插座中使用的柔性触点终端性 能的试验方法.pdf
ANSI-EIA-364-1004A-2016 验证独立式电源触点或电连接器和 插座额定电流的环境试验方法.pdf
ANSI-EIA-364-1005-2011(R2017) 确定触点对微动腐蚀敏感性的环 境试验方法.pdf
ANSI-EIA-364-1005-2011(R2017) Environmental Test Methodology for Determining the Susceptibility of Contacts to Fretting Corrosion.pdf
ANSI-EIA-364F-2014 电连接器/插座测试程序,包括 环境分类.pdf
ANSI-EIA-364F-2014 Electrical Connector/Socket Test Procedures Including Environmental Classifications.pdf
EIA-364 full series Electrical Connector-Socket Test Procedures _机翻.pdf
ANSI-EIA-364-102-1998(R2018) Rise Time Degradation Test Procedure for Electrical Connectors, Sockets, Cable Assemblies or Interconnection Systems.pdf
ANSI-EIA-364-1004A-2016 Environmental Test Methodology for Verifying the Current Rating of Freestanding Power Contacts or Electrical Connectors and Sockets.pdf
EIA-364 full series Electrical Connector-Socket Test Procedures.pdf
ATE - automatic trunk exchange自动干线交换机 (0) 投诉
P:2023-12-05 17:21:03
太狠了这得收多少钱
FITL - fiber in the loop光纤环路 (0) 投诉
P:2024-09-26 17:15:14
太贵了
high-count fiber cable - 多芯数光缆,多纤芯数光缆 (0) 投诉
P:2026-06-08 15:02:25
moisture permeation - 透潮 (0) 投诉
P:2026-06-18 21:28:19
大侠,能否打包分享一份给我们学习一下,跪谢!yglyl@126.com
pretension load - 预张力载荷 (0) 投诉
