首页 > 专业英语|国际贸易
[翻译求助] 非普通线缆的.有点看不懂.急
P:2006-11-19 19:19:44
 CABLE   SCHEDULE FOR SOHAR FURNACE EQUIPMENT
(1).    0.75 SQ MM CABLE                                       QTY.IN MTRS
2+E CORE (XLPE/LSLH/SWB/LSOH )    ----            2500
2+E CORE FLEXIBLE                              -----            25
3 CORE (XLPE/LSLH/SWB/LSOH)       ----               45
3+E CORE (XLPE/LSLH/SWB/LSOH)     ---             425
6+E CORE (XLPE/LSLH/SWB/LSOH)     ---           1150
6+E FLEXIBLE                                             ---             50
11+E CORE (XLPE/LSLH/SWB/LSOH)----             -425
18+E CORE (XLPE/LSLH/SWB/LSOH)-----             650
18+E CORE FLEXIBLE                           ---               110
26+E CORE (XLPE/LSLH/SWB/LSOH)  ---              380
36+E CORE (XLPE/LSLH/SWB/LSOH)  ----             135
36+E CORE FLEXIBLE                           -----               25
(2) 0.75 MM CABLE
1 PAIR (XLPE/SCN/LSLH/SWB/LSOH)-----             370
2 PAIR(XLPE/SCN/LSLH/SWB/LSOH)  ----             430
2 PAIR FLEXIBLE                                    ----               25
5 PAIR (XLPE/SCN/LSLH/SWB/LSOH)----              105
10 PAIR(XLPE/SCN/LSLH/SWB/LSOH ----               75
20 PAIR (XLPE/SCN/LSLH/SWA/LSOH)---               90
20PAIR FLEXIBLE                                    ---                25
(3) 1.5 SQ MM CABLE
2+E CORE (XLPE/PVC/SWA)              ------              950
2+E CORE FLEXIBLE                           ------               46
6+E CORE (XLPE/PVC/SWA)              ------           1585
6+E FLEXIBLE                                      ------               70
9+E CORE (XLPE/LSLHSWB/LSOH)------               138
11+ E CORE(XLPE/LSLH/SWB/LSOH)----               265
18+E CORE (PVC/SWA/SWA)          ------                 300
26+E (LPE/PVE/SWA)                        -----                  110
36+E (XLPE/LSLH/SWB/LSOH)       -------                175
36+E FLEXIBLE                                  -------                 46
(4) 2.5 SQ MM CABLE
 3 CORE(XLPE /PVC/SWA)                 ----                  600
3+E CORE (XLPE/PVC/SWA)            --------            1055
3+E CORE FLEXIBLE                      ----------                46
3+e SCN (XLPE/PVC/SWA)                 ---------           920
(5) 4 SQ MM CABLE
3 CORE (XLPE/PVC/SWA)                ---------                95
3+E CORE (XLPE/PVC/SWA/PVC)     ----------          112
4C (XLPE/PVC/SWA)                            ----------          123
(6) 6 SQMM CABLE
2 CORE FLEXIBLE                                    -----------     175
3 CORE (XLPE/PVC/SWA)                  ----------           140
3+E CORE(XLPE/PVC/SWA)           ------------            335
(7) 10 SQ MM CABLE
3 CORE (XLPE/PVC/SWA)               -----------           1200
3+E CORE (XLPE/PVC/SWA)           -----------            138
(8) 16 SQ MM CABLE
3 CORE (XLPE/PVC/SWA)               ------------            480
4+E CORE (XLPE/PVC/SWA)          ------------             800
(9) 35 SQ MM CABLE
3+E (XLPE/PVC/SWA)                      ------------            220
(10) 70 SQ MM(XLPE/PVC/SWA)
3+N CORE (XLPE/PVC/SWA)         -------------            105
(11) 95 SQ MM CABLE
3+E CORE (XLPE/PVC/SWA)          -------------           225
(12) 240 SQ MM CABLE
12 CORE TEXOPRENE TR 75         ------------               22
(13) CO-AXIAL RG-6 CABLE       --------------            900
(14) 0.5 MM 4SCN                            -------------              70
(15) TYPE “K” CABLE
2x1 PAIR (PVC/SCREEN/PVC)        -------------             92
1 PAIR (PVC/SCREEN/PVC)           ------------               12
FLYING LEAD                                 ----------- -               12
polypropylene filler yarn - 聚丙烯填充绳 (0) 投诉
P:2006-11-19 19:21:35
X+E的什么意思啊?(XLPE/LSLH/SWB/LSOH ) XLPE是否是低密度PE?LSLH.SWB.LSOH.SWA.SCREEN.TEXOPRENE TR等等什么意思.麻烦好心人帮忙翻译几个.谢谢了.
edge runner mixer - 辗碎机,轮辗机 (0) 投诉
P:2006-11-19 19:51:52
XLPE: 交联聚乙烯
LSLH:低烟低卤
SWB:钢丝编织铠装
LSOH:低烟无卤
SWA:钢丝铠装
SCREEN: 屏蔽
+E : 代表有地线,黄绿色
[绿野仙踪 在 2006-11-19 19:59:50 编辑过]
江南狼 奖励 0 金币,.1 声望,于 2007-8-31 8:42:55
breathe - 呼吸式(SZ-绞合) (0) 投诉
P:2006-11-19 19:56:12
谢谢.感激不尽.you're very best.good and good.
compression of the conductor - 导线的压缩 (0) 投诉
P:2007-01-07 11:05:26
对的,这些都是英国标准里面的描述,出口电缆经常都是这样描述,建议你看看BS标准
pickle - 酸洗液;酸洗 (0) 投诉
P:2007-01-12 08:14:35
过来学习了一下,不错
low noise cable - 低噪音电缆,低噪声电缆 (0) 投诉
P:2007-01-15 19:08:59
绿野仙踪:
XLPE: 交联聚乙烯
LSLH:低烟低卤
SWB:钢丝编织铠装
LSOH:低烟无卤
SWA:钢丝铠装
SCREEN: 屏蔽
+E : 代表有地线,黄绿色
SWB:钢丝编织铠装
SWA:钢丝铠装
请问一下"铠装"是什么意思??  我们厂里都没有听说过,老是看到这个词,却搞不懂.请指点一下.
heat-resistant insulation - 耐热绝缘 (0) 投诉
P:2007-01-19 21:19:41
"铠装"顾名思义就是象铠甲一样的保护层,可以是钢丝的,可以是纲带的,看到样品就明白了...用于室外防鼠啮
Thermal stress - 热应力 (0) 投诉
P:2007-03-24 07:53:33
铠装电缆一般用于直埋敷设,主要是抵抗外界应力对电缆的影响,楼上所说的也是其功能中的一部分。
electric cutter - 电气切割机 (0) 投诉
P:2007-04-15 20:04:02
谢谢!学到很多
riser cable - 电梯电缆;竖井电缆;垂直电缆(指敷设在穿透一层以上楼面的垂直通道内的电缆>;吊索 (0) 投诉
P:2007-04-28 14:07:10
翻译过来就是一般的线
sliding socket joint - 滑动套筒接头 (0) 投诉
P:2007-08-30 18:01:57
呵 有收获
ethylene-vinyl acetate copolymer - 乙烯-醋酸乙烯共聚物 (0) 投诉
P:2007-08-31 08:13:52
学了几个新词!
radio frequency interference - 射频干扰,广播频率干扰 (0) 投诉
P:2007-09-09 17:31:37
FLEXIBLE 软结构
tensioning capstan - 张力牵引轮 (0) 投诉
