首页 > 国外线缆
[问题求助] UL电线表面印字是否有标准其一排字后之间间距是否有标准?
P:2008-05-24 08:32:06
aramid paper - 芳族聚酰胺纸 (0) 投诉
P:2010-01-21 22:34:25
有标准可查, 最大600MM
THWH - 结构同 THW,但有尼龙外被。 (0) 投诉
P:2010-01-22 19:02:48
学习中
polyvinyl formal enamelled wire - 缩醛漆包线 (0) 投诉
P:2010-02-21 16:11:26
我怎么没看见过对印字间隔的要求条款呢?谁要是找到了,交流一下。
braking - 制动,刹车 (0) 投诉
P:2010-02-26 15:13:55
xj168:
有标准可查, 最大600MM
在哪里标准,等否具体下?
microbend - 微弯 (0) 投诉
P:2010-03-04 15:57:25
完整的印字内容要在1米内体现,其它并没有规定。此要求可以在跟踪服务细则的Sec.Gen部分查到,例如:
For products meeting only Canadian requirements, surface printing is required for finished products having an overall diameter of 1.3 mm and larger.  A finished product shall have a distinctive marking throughout its entire length by which it may be readily recognized as the product of a particular factory.  The marking shall consist of surface printing, indent‑marking, embossing, colored threads, or printed tape.  If the marking is not continuous, it shall appear at intervals of not more than 1 m.  A finished product of Appliance Wiring Material shall also be legibly and durably identified with the following marked at intervals not more than 1 m:
optical fiber connector without focusing junction - 无聚焦结的光纤连接器 (0) 投诉
P:2010-03-06 10:39:08
厉害啊,学习了
smart erminal - 智能终端 (0) 投诉
P:2010-04-24 14:28:34
很不错,学习了。
cable distribution frame - 电缆配线架 (0) 投诉
P:2010-04-26 13:29:25
 english?
starting plug - (浇铸机的)始铸塞 (0) 投诉
P:2010-04-27 16:56:19
UL的好像没有要求吧,3C有要求的
Two-sided board - 双面板 (0) 投诉
P:2010-04-27 22:30:37
学习了,谢谢
cable matching gear - 电缆匹配装置(雷达的) (0) 投诉
P:2011-11-21 16:24:00
请问这些标准出自哪份标准文件?各有不同的讲法,太迷茫了,最近遇一客诉,一定要标准文件,不知哪位大侠知道,非常感谢!
machine tool wire - 机床用电线 (0) 投诉
P:2011-11-24 22:19:36
标准在那里啊
wire covering - 线绕包层 (0) 投诉
P:2014-03-12 13:30:47
UL跟踪细则里有,最大1米左右
transverse - 排线 (0) 投诉
P:2014-03-13 12:17:52
持續跟蹤
aluminium alloy conductor,steel-reinforced - 钢芯铝合金绞线 (0) 投诉
