首页 > 专业英语|国际贸易
[专业词汇] 电缆英语2
P:2008-05-23 16:09:02
细导线 fine wire conductor
一级导体 first class conductor
螺旋形导线 fish line conductor
五线组 five-wire conductor
扁导体带状电缆 flat conductor cable
软线 flex conductor
软接线 flexible circuit conductor
软导体 flexible conductor
软绞线 flexible stranded conductor
扩径导线 expanded conductor
外导体 external conductor
特细丝导线 extra-fine wire conductor
特软绞线 extra-flexible stranded conductor
极低弧垂钢芯铝绞线 extremely low-sag invar-reinforced aluminium conductor
导电体 electric conductor
电导体 electrical conductor
电工用铜 electrical conductor grade copper
导体电阻 electrical resistance of conductor
电解质导体 electrolytic conductor
漆包铜线 enamelled copper conductor
漆包扁线 enamelled rectangularsection conductor
接地线芯 drain conductor
无载导线 dummy conductor
地导体 earth conductor
接地导线 earth continuity conductor
接地均衡器导线 earth equalizer conductor
接地导线 earthing conductor
双分裂导线 double bundle conductor
双芯软线 double conductor cord
皱纹同心导体 corrugated concentric conductor
纱包铜线 cotton-covered copper conductor
低温超导体 cryogenic superconductor
截流导线 current carrying conductor
限流导线 current limiting conductor
连接器光导损耗 connector optical conductor loss
连接器引起的光导损耗 connector-induced optical conductor loss
接触导线 contact conductor
铜芯聚氯乙烯绝缘平型软线 copper conductor PVC-insulated parallel flexible cord
铜芯聚氯乙烯绝缘绞型软线 copper conductor PVC-insulated twisted flexible cord
铜芯电缆 copper conductor cable
铜包钢线 copper covered steel conductor
铜绞线 copper stranded conductor
铜包铝导体 copper-clad aluminium conductor
铜包钢线 copper-clad steel conductor
铜包钢线 copper/steel bimetallic conductor
铜包钢线 copperweld conductor
压缩扇形绞合导线 compact sector stranded conductor
压缩扇形导体 compact segmental conductor
紧压导体 compacted conductor
紧压同心式绞合1350圆铝导线 compact-round concentric-lay-stranded aluminium 1350 conductor
紧压同心式绞合圆钢芯铝绞线 compact-round concentric-lay-stranded aluminium conductor,steel-reinforced
紧压同心式绞合圆铜导线 compact-round concentric-lay-stranded copper conductor
导线的压缩 compaction of the conductor
补偿导线 compensating conductor
复合导线 composite conductor
光纤通信组合导线 composite optical communication conductor
复合超导体 compound superconductor
压缩型绞合导体 compressed-stranded conductor
同心导体 concentric conductor
同心层绞导线 concentric lay conductor
同心中性线 concentric neutral conductor
同心中性导体 concentric neuttral conductor
同心绞合线芯 concentric stranded conductor
同轴线路 concentric-conductor line
同心式绞合1350铝导线 concentric-lay-stranded aluminium 1350 conductor
同心式绞合铝导体 concentric-lay-stranded aluminium conductor
同心式绞合钢芯铝绞线 concentric-lay-stranded aluminium conductor,coated steel-reinforced
同心式绞合5005- H19
铝合金导线 concentric-lay-stranded aluminium-alloy 5005-H19 conductor
同心式绞合6201- T81
铝合金导线 concentric-lay-stranded aluminium-alloy 6201-T81 conductor
同心式绞合铝包钢导线 concentric-lay-stranded aluminium-clad steel conductor
同心式绞合铜包钢导线 concentric-lay-stranded copper and clad steel conductor
同心式绞合铜和铜包钢复合导线 concentric-lay-stranded copper and copper-clad steel composite conductor
同心式绞合铜导线 concentric-lay-stranded copper conductor
圆形同心绞合导体、同心式绞合圆导体 concentrically stranded circular conductor
导线外径 conductor Outside diameter
布线 conductor arrangement
导体绕扎带 conductor binder
导体[线]断线 conductor break
导线结构 conductor design
导体场强 conductor field strength
导体梯度 conductor gradient
导体绝缘 conductor insulation
导线负载 conductor loading
导体损耗 conductor loss
导体材料 conductor material
导线制品 conductor productor
汇流排 conductor rail
导体电阻 conductor resistance
导体屏蔽 conductor screen
导体形状 conductor shape
导体屏蔽 conductor shield
导体间隔 conductor spacing
线芯接续强度 conductor splicing force
导线绞合 conductor stranding
导体温度 conductor temperature
导线张力 conductor tension
导线对导线 conductor to conductor
导线对屏蔽 conductor to shield
导线交叉 conductor transposition
导体单位 conductor unit
单线 conductor wire
横截面积减少了的导线 conductor with reduced cross-sectional area
配线 conductor-configuration
线芯冷却大功率电缆 conductor-cooled heavy duty cable
出线梗 conductor-stalk
导体结构 conductorconstruction
导体材料 conductormaterial
圆导体 circular conductor
同轴内导体 coaxial inner conductor
同轴外导体 coaxial outer conductor
铜芯电缆 cable with copper conductor
阴极导体 cathode conductor
管状导线 cellular conductor
中心导体 centre conductor
青铜导线 bronze conductor
束绞导线 bunch-stranded conductor
束绞铜束线 bunch-stranded copper conductor
束合导体 bunched conductor
分裂导线 bundle conductor
铜芯编织电缆 braid cable with copper conductor
编织导线 braid conductor
编织导线 braided conductor
分支导线 branch conductor
断线检测器 broken conductor detector
钢芯铝绞线 aluminium-steel conductor
绝对导体 absolute conductor
架空线 aerial conductor
金属氧化物半导体 metal-oxide semiconductor
分割导体 Milliken conductor
塑料绝缘线芯 plastic insulated conductor
塑料绝缘导体 plastic insulated conductor
实心铝导体 solid aluminium conductor
双漆包纸绝缘电线 Tietgen conductor
泡沫绝缘电线 dual expanded plastic insulated conductor
电工用铝 EC-aluminium
导电用铝 EC-aluminum
型铜芯电缆 Efglas type electric cable with copper conductor cable Efglas
内冷电缆超导体 internally cooled cable superconductor
内冷电缆超导体 internally cooled cabled superconductor
电缆专业英语 电工术语 电缆 |
I.D.P. - integrated data processing综合数据处理法 (0) 投诉
23
,免费,感动ing
