[材料介绍] 关于满足挪威NEK606:2004标准的电缆材料
P:2006-11-17 15:04:58
国际上GCC、NEXANS、CCI、JINRO、PIRELLI等公司生产石油平台电缆的厂家,在耐泥浆电缆护套的性能要求上,基本上均按照NEK606标准考核。主要是在IEC 60092-359 的SHF2型的基础上,加上了耐泥浆要求,如耐IRM903油,100℃7天,要求抗张强度、断裂伸长率、体积膨胀、重量增加均≤30%。我一直在寻求此料,但至尽收获很小,国内常规的无卤料(无论辐照交联、还是蒸汽硫化)指标相距很大,特别是后两项指标。各位理工朋友如果对这方面有过研究的,请指点或探讨。
[copartner 在 2007-12-19 13:54:39 编辑过]
sheath eddy current loss factor - 护套涡流损耗因素 (0) 投诉
P:2008-12-03 13:19:22
也许我们可以帮到诸位!
NEK606对于国内的目前的标准来说,就是耐油、耐泥浆的要求高一些!
可以通过干式硅烷交联或通过辐照交联以获得更高的耐温性能。
DESCRIPTION/FEATURES: Low Smoke Fume Zero Halogen Compound (LSFOH)
APPLICATIONS: Wire & Cable
Physical properties Test method Unit Typical value
Specific density ISO 1183 kg/m3 1510
Melt flow, 150°C , 21,6 kg ISO 1133, (b) g/10min 2,5
Tensile strength IEC 60811-1-1 MPa 9 (12**)
Elongation at break IEC 60811-1-1 % 180(160**)
Tear strength BS 6469:99.1 N/mm 6
Hot pressure test 6h at 115°C IEC 60811-3-1 % 8
Hot pressure test 4h at 125°C IEC 60811-3-1 % 34**
Cold impact at -40°C IEC 60811-1-4 pass
Elongation at break -40°C IEC 60811-1-4 % 40
Air ageing 10d at 120°C
Tensile strength, variation from original % -26 (25**)
Elongation, variation from original % -40 (-16**)
** After Crosslinking
Burning properties Test method Unit Typical value
Oxygen index ISO 4589-2 % 34 *
Flammability temperature index ISO 4589-3 °C 330**
Smoke density – Flaming mode (1mm) ASTM E-662 Ds max -
Smoke density – Non Flaming Mode (1mm) ASTM E-662 Ds max -
Toxicity NES 713 - -
Halogen content IEC 60754-1 - *
Acid Gas Emission IEC 60754-2 -
- pH (min) pH 4.34
- conductivity (max) μScm-1 21.5
*measured on type IV specimen
**measured on type II specimen
Electrical properties Test method Unit Typical value
Dielectric constant at 50 Hz, at 23°C, 50%HR IEC 60250 4.01
Dissipation factor at 50 Hz, at 23°C, 50%HR IEC 60250 0.001
Dissipation factor at 1MHz, at 23°C, 50%HR IEC 60250 0,07
Volume resistivity , at 23°C, 50%HR IEC 60093 W cm 3,2x 1015
Surface resistivity , at 23°C, 50%HR IEC 60093 W 3,0x 1015
Other properties Test method Unit Typical value
Water absorption after 7d at 70°C BS 6724 mg/cm2 1,43
Tensile strength, variation from original % 2 (-5**)
Elongation, variation from original % -45 (-11**)
Oil ageing, IRM 902 oil, 7d at 100°C IEC 60811-2-1
Tensile strength, variation from original % -10 (-8**)
Elongation, variation from original % -21 (-21**)
Oil ageing, IRM 903 oil, 7d at 100°C IEC 60811-2-1
Tensile strength, variation from original % -35 (-28**)
Elongation, variation from original % -40 (-21**)
Mud resistance, oil based, 56d at 70°C IEC60892-4 (NEK606)
Tensile strength, variation from original % -7(-19**)
Elongation, variation from original % -44 (-32**)
Heat shock 1h at 150°C IEC 60811-3-1 Pass
Hardness ISO R 868 Shore D 48
Hardness ISO R 868 Shore A 94
Mooney viscosity, ML (1+4) 140°C DIN 53523 - 58
Shrinkage, 1h at 100°C IEC 60811-1-3 % 0
leading-out - 引出,引出线 (0) 投诉
18
