首页 > 标准共享
[国外标准] LV112-1-2023道路车辆—电缆—铜导体单芯非屏蔽电缆
P:2023-09-11 16:29:33
谁有最新版的德标汽车线的标准,急需
EPT - ethylene-propylene terpolymer乙烯-丙烯三元共聚物 (0) 投诉
P:2023-09-12 08:20:15
Intranet - 企业内联网(企业内部的一种电脑网络,可与Internet连接) (0) 投诉
P:2023-09-12 08:30:28
ISO 6722
harness - 绕线组,线束,导线系统,汽车电气配线;光缆束,光缆捆束 (0) 投诉
P:2023-09-12 09:03:13
long wave - 长波 (0) 投诉
P:2023-09-13 08:22:31
DIN是德标么?
trimethoxysilane - 三甲氧基硅烷 (0) 投诉
P:2023-09-14 10:41:38
songfeiX 奖励 20 金币,10 声望,于 2023-09-15 09:15:23 原因:奖罚
varnishing unit - 涂漆装置 (0) 投诉
P:2023-09-15 09:40:38
200金币!!!
Number of Conductors - 导体数量 (0) 投诉
P:2023-09-18 09:37:38
买不起
lightning withstand level of transmission lines - 线路耐雷水平 (0) 投诉
P:2023-09-19 09:09:09
International standards
ISO 6722 -1
Road vehicles, 60 V and 600 V   single-core cables
ISO 6722 -2
Road vehicles, 60 V and 600 V   single-core aluminium cables
ISO 14 572
Road vehicles – round, screened and   unscreened, 60 V and 600 V multi-core sheathed cables
LV 112-1
Electrical cables for motor vehicles   (copper, single-core, unshielded)
LV 112-2
Electrical cables for motor vehicles   (aluminium, single-core, unshielded)
LV 112-3
Specification of the current rating of   vehicle cables
LV 112-4
Electrical cables for motor vehicles   (copper alloy cables, single-core, unshielded)
LV 122
Twisted cables
LV 212
Sheathed cables for motor vehicles   (requirements and testing)
LV 213-1 & LV 213-2
High-frequency cables for motor   vehicles
LV 216-1 & LV 216-2
Shielded high-voltage sheathed cables   for motor vehicles and their electrical drives
 SAE J 1128
Engineering Society for advancing   mobility Land, Sea, Air and Space
TWP
Thin wall, Thermoplastic Insulated
GPT
General Purpose, Thermoplastic   Insulated
HDT
Heavy Duty, Thermoplastic Insulated
TXL
Thin wall, Cross (X) Linked Polyolefin   Insulated
GXL
General Purpose, Cross (X) Linked   Polyolefin Insulated
SXL
Special Purpose, Cross (X) Linked   Polyolefin Insulated
TWE
Thin wall, Thermoplastic Elastomer   Insulated
GTE
General Purpose, Thermoplastic   Elastomer Insulated
HTE
Heavy Duty, Thermoplastic Elastomer   Insulated
 JASO D 611:2009
Japanese Automobile Standard
AV
Vinyl insulated low tension electric   cable for automobiles
AVS
Low tension cable with reduced outside   diameter for automobiles, general wall thickness
AVSS
Low tension cable with reduced outside   diameter for automobiles, thin wall thickness
AVSSf
Low tension cable with reduced outside   diameter for automobiles, thin wall thickness, high flexibility
CAVS
Construction of conductors pressed in   circular shape,
  low tension cable with reduced outside diameter for automobiles, general wall   thickness
AVX
Crosslinked vinyl heat-resistant   low-tension cable for automobiles
AEX
Crosslinked polyethylene   heat-restistant low-tension cable for automobiles
superfiber - 超强度纤维 (0) 投诉
P:2023-09-19 10:04:34
辛辛苦苦签到攒的钱就那么点,算了
parallel data output - 并行数据输出 (0) 投诉
P:2023-11-17 08:45:33
你看我这条命值不值200金币
cooling liquid - 冷却液 (0) 投诉
P:2024-08-21 18:24:27
haha  确实贵啊
messenger wire clamp - 吊线夹 (0) 投诉
