首页 > 国外线缆
[技术资料] UL线规的代号和含义
P:2023-05-08 15:19:16
美规线规的代号和含义
Flat Wire:
(变形线)
SPT: Stranded Wire(绞线), Parallel(平行线), Thermoplastic(热塑性塑料)
热塑性平行线
This is always followed by a -1, -2 or -3, signifying insulation thickness for different applications. HPN: Heater, Parallel, Neoprene
Required for heater-type application, such as irons, toasters, etc.
NOTE: We can run some 20 AWG, but mostly we run 18, 16 and 14 AWG, 2 or 3 conductors. P is always Parallel Wire (Flat).
Jacketed Wire:
S = Stranded (or Service Wire)
J = Junior Service (300 Volt). If no "J" is in the wire type, then it is a hard service (600 Volt). T = Thermoplastic. If no "T" is in the wire type, then it has a rubber jacket.
O = Oil-Resistant Compound
W = Weather-Resistant Compound
V = Vacuum - as in vacuum cleaner. This is a small O.D. jacketed wire, very flexible and initially used for vacuum cleaners but now used on many different types of products. Available only in 18 AWG.
Examples:
SV = Stranded Vacuum Rubber Jacketed (NO "T") SJT = Stranded Junior Thermoplastic
SJTOW = Stranded Junior Thermoplastic, Oil and Weather resistant for UL and CSA.
Miscellaneous requirements:
S.P. = Surface Printed
N.M. = Non-Migratory compound to prevent the wire color from bleeding under unusual circumstances.
VW-1 = Vertical Flame test (formerly FR-1)
60°C = Standard temperature rating (except HPN - 90°C
105°C = Electri-Cord's alternate rating (we normally don't stock 75°, 90°C)
IEC, ICC = International Color Code on the inner conductors (Blue, Brown, Green w/Yellow Stripe)
N.A. = North American Color Code on the inner conductors (Black, White, Green) 41/34 = Stranding - 41 strands of 34 AWG wire for each inner conductor
T.C. = Tinned Copper inner conductors RIBBED = Outer jacket is striated with ribs
R/S or W/S = Red or White Stripe for visual polarity inspection on Flat wir
fiber-optic terminus - 光纤终端 (0) 投诉
P:2023-05-09 08:06:51
瞎眼在这里写标题!
HCS - high carbon steel高碳钢 (0) 投诉
P:2023-05-09 15:06:48
为什么我金币花了下载没有
PWS - private wire system专用[测试]线系统 (0) 投诉
P:2023-05-09 16:53:30
注意浏览器的设置,有的时候电脑系统安全设置太高,会自动删除了
tape armored cable - 钢带铠装电缆 (0) 投诉
