首页 > 国外线缆
[问题求助] 推荐UL STYLE
P:2008-05-19 13:23:40
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 1150 Issued: 1959-05-01
Revised: 2003-03-31
*Style 1150 Polyethylene Insulated, Shielded and Thermoplastic (PVC)
Jacketed Wire for Electronic Use.
______________________________________________________________________________
Rating 60°C, 300 Volts.
Conductor No. 26-16 AWG, solid or stranded, tinned or bare.
*Insulation Polyethylene or Flame-Retardant Polyethylene, 30 mils
minimum average thickness, 27 mils minimum at
any point.
Shielding Shielding over conductor insulation shall consist of
No. 38-30 AWG, tinned or untinned copper strands applied
as a wrap or a braid or a wrap of aluminum faced “Mylar”
tape with a parallel uninsulated drain wire or a
conductive PVC shield with a parallel uninsulated drain
wire.
*Jacket PVC, Class 43, 15 mils minimum average thickness, 13 mils
minimum at any point.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Tensile Strength and Elongation of Insulation,
Representative before aging for Polyethylene and
for Flame-Retardant Polyethylene.
Tensile Strength and Elongation of Jacket same as
for Class 43.
* Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Insulation, for Polyethylene and
Program for Flame-Retardant Polyehtylene.
(4) Jacket, Physical Properties, Class 43.
(4) Flexibility.
(4) Cold Bend.
* (12) Horizontal Flame Test.
(Continued on Page 1150A)
Subj. 758 Section 1 Page 1150A Issued: 1959-05-01
Revised: 2003-03-31
Marking General.
Use For electronic use in non-hazardous locations.
self-recovering insulation - 自恢复绝缘 (0) 投诉
