首页 > 国外线缆
[问题求助] 求UL1007和1015,2464标准
P:2008-05-15 08:16:18
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 1007 Issued: 1959-05-01
Revised: 2002-12-05
Style 1007 Polyvinyl Chloride Insulated Wire.
______________________________________________________________________________
Rating 80°C, 300 V.
Conductor 32-16 AWG, solid or stranded.
Insulation Polyvinyl Chloride, 15 mils minimum average,
13 mils minimum at any point, 60 or 80°C in oil,
if applicable.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, Unaged.
Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties.
Program (4) Heat Shock.
(4) Cold Bend
* (4) Deformation.
* (12) Horizontal Flame Test.
Marking General.
Use Internal wiring of appliances; or where exposed to oil
at a temperature not exceeding 60°C or 80°C, whichever
is applicable. Tags may indicate the following:
600 V Peak - For Electronic Use Only.
Subj. 758 Section 1 Page 1015 Issued: 1959-05-01
Revised: 2003-02-17
Style 1015 PVC Insulated Wire.
Rating 80°C, 90°C or 105°C; 600 V ac, 750 V dc.
Conductor 30 AWG - 2000 kcmil.
Insulation PVC
Min. Avg. Min at Any Point
Size Mils Mils
30-9 30 27
8,7 45 40
6-2 60 54
1-4/0 80 72
250-500 kcmil 95 86
550-1000 kcmil 110 99
1100-2000 kcmil 125 112
to UL Physical Properties, unaged, Class 43.
Counter-Check (4) Physical Properties, Class 43.
(4) Cold Bend.
(4) Deformation.
Marking General.
Use Internal Wiring of Appliances; or Internal Wiring of
Appliances where exposed to oil at a temperature not exceeding 60 deg. C or 80 deg. C (whichever is applicable). Tags may also indicate the following: 2,500 V peak - for electronic use only.
Subj. 758 Section 2 Page 2464 Issued: 1968-05-02
Revised: 2003-05-02
Style 2464 PVC Jacketed Cable.
Rating 80°C, 300 V.
Insulated Labeled or complying with manufacturer's AWM Procedure
Conductors having a minimum rating of 80°C and 300 V.
Assembly Two or more singles, twisted pairs of groups of twisted
singles twisted together or singles or groups of singles
may be laid parallel to form flat, oval or round cable.
Lay not specified. Barrier layer and/or fillers optional.
Manufacturer shall maintain a complete description of each
assembly. May use same or mixed AWG size.
*Covering (Optional.)
Shield Optional.
Jacket PVC - Class 43
THICKNESS OF PVC JACKET (mils)
#Dia. of Cable Minimum
Under Jacket Minimum at any
in Inches Average point
0.700 or less 30 24
0.701 - 1.000 45 36
1.001 - 1.500 60 48
1.501 - 2.500 80 64
2.501 - 4.000 110 88
4.001 or larger 140 112
# Major diameter if cable is flat or oval.
Braid Optional.
(Continued on Page 2464A)
Subj. 758 Section 2 Page 2464A Issued: 1968-05-02
Revised: 2003-05-02
Instructions Detailed Examination of the cable assembly and jacket.
to UL Physical Properties of Jacket.
Representative Dielectric Strength Test, 1500 Volts (shielded cable only).
The designation of all Styles of the individual conductors used making up the cable assembly shall be available, and the UL Representative’s tag shall indicate if the Style is labeled or not. If they are not labeled, the appropriate Follow-Up Tests shall be conducted.
Counter-Check (4) Physical Properties of Jacket.
Program (4) Heat Shock on Jacket.
(4) Cold Bend on Completed Cable.
(4) Deformation on Jacket, Class 43.
(12) Cable Flame Test on Completed Cable.
If the insulated styles are not labeled, the appropriate Follow-Up Tests shall be conducted.
Marking General.
Use Internal wiring or external interconnection of electronic
equipment (such as desk-type calculators, dictating
machines, or x-ray equipment).
two-stage extruder - 二段式挤出机 (0) 投诉
