[供应信息] 防爆伺服电机派克EX系列
P:2022-07-11 17:25:13
EX系列防爆伺服电机
性能特点
外框尺寸
70mm | 92mm | 120mm | 155mm
持续扭矩
1.75 - 35 Nm
15 - 310 lb-inch
峰值扭矩
6.6 - 137 Nm
58 - 1213 lb-inch
额定速度
0 - 7600 RPM
输入电压
230VAC | 400-480VAC
回馈类型
旋转变压器 | EnDat judui值编码器 (单圈) | EnDat judui值编码器 (多圈) | Hiperface judui值编码器 (单圈) | Hiperface judui值编码器 (多圈) | 无反馈模式
兼容 Parker 驱动器
Compax3 | SLVD-N
符合规格
CE标识 | UL/cUL 列表 | ATEX 'Ex' 安全
防护等级
IP64 | IP65
包括保持制动器
可选
冷却方法
风冷 / 自然冷却
轴类型
光轴 | 平键
型号:
EX310EAPB1200,EX310EAPB1201,EX310EAPB1210,EX310EAPB1211,EX310EAPB1500,EX310EAPB1501,EX310EAPB1510,EX310EAPB1511,EX310EAKB1200,
EX310EAKB1201,EX310EAKB1210,EX310EAKB1211,EX310EAKB1500,EX310EAKB1501,EX310EAKB1510,EX310EAKB1511,EX420EAPB1200,EX420EAPB1201,
EX420EAPB1210,EX420EAPB1211,EX420EAPB1500,EX420EAPB1501,EX420EAPB1510,EX420EAPB1511,EX420EAJB1200,EX420EAJB1201,EX420EAJB1210,
EX420EAJB1211,EX420EAJB1500,EX420EAJB1501,EX420EAJB1510,EX420EAJB1511,EX430EALB1200,EX430EALB1201,EX430EALB1210,EX430EALB1211,
EX430EALB1500,EX430EALB1501,EX430EALB1510,EX430EALB1511,EX430EAFB1200,EX430EAFB1201,EX430EAFB1210,EX430EAFB1211,EX430EAFB1500,
EX430EAFB1501,EX430EAFB1510,EX430EAFB1511,EX620EAVB1200,EX620EAVB1201,EX620EAVB1210,EX620EAVB1211,EX620EAVB1500,EX620EAVB1501,
EX620EAVB1510,EX620EAVB1511,EX620EARB1200,EX620EARB1201,EX620EARB1210,EX620EARB1211,EX620EARB1500,EX620EARB1501,EX620EARB1510,
EX620EARB1511,EX630EARB1200,EX630EARB1201,EX630EARB1210,EX630EARB1211,EX630EARB1500,EX630EARB1501,EX630EARB1510,EX630EARB1511,
EX630EANB1200,EX630EANB1201,EX630EANB1210,EX630EANB1211,EX630EANB1500,EX630EANB1501,EX630EANB1510,EX630EANB1511,EX820EARB1200,
EX820EARB1201,EX820EARB1210,EX820EARB1211,EX820EARB1500,EX820EARB1501,EX820EARB1510,EX820EARB1511,EX840EAKB1200,EX840EAKB1201,
EX840EAKB1210,EX840EAKB1211,EX840EAKB1500,EX840EAKB1501,EX840EAKB1510,EX840EAKB1511,EX860EAJB1200,EX860EAJB1201,EX860EAJB1210,
EX860EAJB1211,EX860EAJB1500,EX860EAJB1501,EX860EAJB1510,EX860EAJB1511
air line wire - 架空导线,架空线路导线 (0) 投诉
