首页 > 产品认证
[UL认证] 请求FFC线20624 20798的标准
P:2008-05-12 10:21:49
请斑竹提供一下 FFC线20624 20798的标准和定义给我
我一直想学习  但网上一点资料找不到
谢谢!
AFM - antifriction metal耐[抗]磨金属 (0) 投诉
P:2008-05-12 12:44:56
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 20624       Issued:   1989-09-20
                                    Revised:   2003-11-14
Style 20624     Insulated Flat Cable.
 _____________________
Rating      80°C, 60 Volts.
___________________________
Conductor       2-150, material not specified.  40-12 AWG flat or round
            conductors.  Straight or irregular parallel in one plane.
            Flat conductors 1.0 - 10.0 mils thick, 10-100 mils wide.
_________________________________________________________
*Insulation     (1)  PVC, 3.5 mils minimum bonded each side, or
            (2)  0.8 mil minimum biaxially oriented PETP
                 film bonded each side with 0.5 mil polyester adhesive
                            or
            (3)  0.8 mils minimum PETP film or flame retardant
                 polyester film and 0.5 mil minimum PVC on each side
                 of conductors laminated together.  10 mils minimum
                 edge width and 3 mils minimum between conductors.
            (4)  0.8 mils minimum polyimide film bonded on each side
                 of conductors with 0.4 mil minimum polyester
                 adhesive.  Total combined thickness shall be 1.2 mils
                 minimum.
__________________________________________________________________
Shield      (Optional) Metal faced polyester tape.
            Drain wire optional.
Standard        Appliance Wiring Material UL 758.
Instructions    Detailed Examination.
to UL           Flexing - flatwise into a U-bend around a 1/8 in.
Representative     diameter mandrel.
*           Spark Test.
UL          (4)  Detailed Examination.
Counter-Check   (4)  Flexing - Conditioned 7 days in air oven at 113°C,
Program          then flexed as above.
*           (12) Horizontal Flame Test.
Marking     General.
Use         Internal wiring of Class 2 circuits in electronic
            equipment.
[cuijiude 在 2008-5-12 12:48:04 编辑过]
GI cable - 气体绝缘电缆 (0) 投诉
P:2008-05-12 12:45:19
Subj. 758       Section 2       Page 20798       Issued:  1993-06-24
                                    Revised:  2003-06-20
Style 20798     Insulated Flat Cable.
______________________________________________________________________________
Rating      80°C, 60 V.
Conductor       2-150, copper foil.  Straight parallel in one plane.
            Conductors 1.0 - 10.0 mils thick, 10-100 mils wide.
Insulation      0.4 mil minimum biaxially oriented PETP (polyester)
film bonded each side with 0.5 mil polyester adhesive.  Minimum 13 mils of insulation between the outside edges and the first conductor and 7 mils minimum width between adjacent conductors.
Shield      (Optional) Metal faced polyester tape.  Drain wire optional.
Covering        (Optional) Polyester (Mylar) film, 0.02 - 4.0 mils
            bonded to cable with polyester adhesive.
*to UL      Flexibility, Unaged.
Representative  Spark Test.
*Counter-Check  (4)  Flexibility
Program     (12) Horizontal Flame Test.
Marking     General.
            equipment.
Cabsil method - 硅烷交联一步法(瑞士CAB公司研制的) (0) 投诉
P:2008-05-12 14:58:36
谢谢啦!!请问斑竹
FFC线您还有其它资料吗?贴出来可以吗
感谢了
concentric lay strand - 同心层绞线 (0) 投诉
