首页 > 国外线缆
[问题求助] 新型UL电线加工工艺跟其它线种有何不同?
P:2008-04-27 11:17:54
哪位大侠有没有相关的UL20624技术资料,这款线材的加工工艺跟其它线种有何不同?要求一般有哪些,还请高手帮忙解答!
ODL erminal - 操作数据记录终端 (0) 投诉
P:2008-04-27 11:37:00
高手还没有出现啊?
foamed contmuous filament polypropylene - 泡沫聚丙烯绳(作电缆填充材料用) (0) 投诉
P:2008-04-28 10:51:41
版主,我想申请你来帮忙啦!
junction cord - 中继塞绳,连接塞绳 (0) 投诉
P:2008-04-28 11:19:22
UNDERWRITERS LABORATORIES INC.              APPLIANCE WIRING MATERIAL
Subj. 758     Section 2     Page 20624       Issued:   1989-09-20
                                Revised:   2003-11-14
Style 20624       Insulated Flat Cable. ______________________________________________________________________________
Rating     80°C, 60 Volts. ______________________________________________________________________________
Conductor     2-150, material not specified.  40-12 AWG flat or round
           conductors.  Straight or irregular parallel in one plane.
           Flat conductors 1.0 - 10.0 mils thick, 10-100 mils wide.
*Insulation       (1)  PVC, 3.5 mils minimum bonded each side, or
           (2)  0.8 mil minimum biaxially oriented PETP
                film bonded each side with 0.5 mil polyester adhesive
                         or
           (3)  0.8 mils minimum PETP film or flame retardant
                polyester film and 0.5 mil minimum PVC on each side
                of conductors laminated together.  10 mils minimum
                edge width and 3 mils minimum between conductors.
           (4)  0.8 mils minimum polyimide film bonded on each side
                of conductors with 0.4 mil minimum polyester
                adhesive.  Total combined thickness shall be 1.2 mils
                minimum.
Shield     (Optional) Metal faced polyester tape.
           Drain wire optional.
Standard      Appliance Wiring Material UL 758.
Instructions  Detailed Examination.
to UL         Flexing - flatwise into a U-bend around a 1/8 in.
Representative       diameter mandrel.
*          Spark Test.
UL         (4)  Detailed Examination.
Counter-Check (4)  Flexing - Conditioned 7 days in air oven at 113°C,
Program            then flexed as above.
*          (12) Horizontal Flame Test.
Marking       General. ______________________________________________________________________________
Use        Internal wiring of Class 2 circuits in electronic
           equipment.
to float a cable ashore - 用浮筒把电缆拉上海岸(敷设) (0) 投诉
P:2008-04-30 11:01:32
此款线材加工工艺跟普通电子线加工工艺有很大的差异吧!
cotton - 棉纱,棉线 (0) 投诉
