首页 > 标准共享
[国外标准] ASTM E 154-99 Standard Test Methods for Water Vapor Retarders Used in Contact with Earth Under Concrete Slabs, on Walls, or as Ground Cover
P:2008-04-25 16:59:43
ASTM E 154-99 Standard Test Methods for Water Vapor Retarders Used in Contact with Earth Under Concrete Slabs, on Walls, or as Ground Cover.pdf
imprint - 盖印;印刻,特征,指印 (0) 投诉
