首页 > 线缆机器设备
[拉丝设备] 求购退火机
P:2008-04-24 09:00:58
1.     0.13 SQMM ~ 1.25 SQMM compact wire will be annealed by this machin
2.     Annealer for these range of compact wire.
3.     These cable shall be stranded on 630mm Double buncher and it shall be annealed by off-line as below:
4.     Please Refer to below drawing :
routine - 程序,例行工作;定期的 (0) 投诉
P:2008-04-24 10:34:59
啥东西  ,看不懂啊 ,大家中国人,发中文啊
stranding flyer - 绞合绕包头 (0) 投诉
P:2008-04-28 19:47:53
type
WS630
wire scope
(0.4~1.6)㎜
mechanical speed
Max2000 m/min
pay off motor
AC 5.5 kw
traverse motor
110 w
wire scope
(0.40~1.60)mm
mechanical speed
2000 m/min
Rated DC annealing current
2000 A
DC annealing Voltage
60 V
Annealing Capacity
180KVA
Steam generator capacity
9kw
weight of steam
12kg/h
<DIV align=center>
type
WS630
wire scope
0.4~1.6㎜
mechanical speed
Max2000 m/min
take up motor
AC 15 kw
traverse motor
110 w
</DIV>
shanghai dingfan electro technic machine co.,LTD   www.--sh-dingfan.com
        jian-li
        mobile:13370206211
Charging Current - 充电电流 (0) 投诉
P:2008-05-12 14:01:20
确实需要我们可以探讨一下呀!你联系方式都没
message processing program - 信息处理程序 (0) 投诉
P:2008-05-15 20:48:15
朋友有个联系方法吗?
joint-sleeve - 接头外壳 (0) 投诉
P:2008-05-19 17:17:07
以上要求 我公司可以达到您的要求
有需要请联系 昆山东利机电 0512-57512771
kg - kilogram千克,公斤 (0) 投诉
P:2008-09-11 22:47:36
温州嘉翔数控设备有限公司座落于浙江省属有“机械之乡”之称的瑞安市,是一家从事电工机械研发,生产和销售的高新技术企业。公司由原来温州华电数控设备有限公司不断改制发展延续至今。是国内较早研发生产铜包铝及铜线拉丝机、镀锡机企业之一。
http://www.--jxsksb.com/about.asp
MTS - multiplex timing source复用定时信源 (0) 投诉
P:2008-09-19 11:07:03
中拉连续退火嘛.我来帮您搞定.
JERRYLEE126@QQ.COM
Tin plated - 镀锡 (0) 投诉
P:2009-02-24 10:58:20
你要的就是个动力式退火机嘛。
专业生产高速连续退火机带自动换盘
www.--polyjd.com.cn
www.--zjgpoly.ney.cn
tree cluster - 树枝群,树枝丛,树枝束,树枝簇 (0) 投诉
P:2009-03-21 14:26:56
Wirshine Wire&Cable Machinery (Nantong) Co., Ltd is located in the City of Haimen—a National Clean City, east near Yellow Sea, south depends on Yangtze River separating of the Shanghai, close to Suzhou-Nantong Yangtze River Bridge, has extremely convenient transportation facilitates. The city is also called as “small Pudong in Golden Triangle”.
WIRSHINE—means Wire Machine,the company is a modern company which specializes in R&D, and manufacturing of machinery and equipment for electric wires and cables, and the main products of the company include different type of planetary stranding machine, rigid frame stranding machine, tubular stranding machine, drum cabling machine, laying-up stranding machine, copper rod drawing machine, aluminum or aluminum alloy rod drawing machine, extruder, optical fiber cable SZ stranding line, optical fiber sheath production line and relevant auxiliary equipments. The company has strong technical strength, advanced technology, excellent processing equipments and strict quality management system, and is dedicated to providing products with high quality and excellent performance. We are waiting to provide detailed technical consultation and perfect services for you.
“Quality achieves future”—we will make and let brand of WIRSHINE become a famous international brand, which leads Chinese market and well known around the world. We are cordially expecting you: select WIRSHINE brand, experience WIRSHINE products and feel WIRSHINE service.
scanning laser beam - 扫描激光束 (0) 投诉
P:2009-05-06 15:42:14
搞定了吗?怎么也没消息了
long-range communication cable - 长途通信电缆 (0) 投诉
P:2009-05-20 14:59:54
这个不是普通的中拉退火机啊,是先束线机束线完之后再进行退火的。
关键是工艺上有这个必要吗?在进630束丝机之前铜线就可以先退火软化的啊。
束线用这种接触式退火的,还没有见过。这东西一般用于单线的退货,束线来退火,能退的均匀吗?
timing-extraction - 定时提取 (0) 投诉
