[技术资料] 美国宇航局工艺标准:电缆和线束,通用规范 参考
P:2022-01-18 07:57:54
    美国宇航局工艺标准:电缆和线束通用规范
    电缆和线束通用规范
    cables and harnesses
    电缆和线束通用规范
    Often the most overlooked and ignored component of any electrical/electronic design, 电缆和线束es are essential to the accurate and rapid transmission of data and control signals.
    connector backshellharness in bend radius
    PREFERRED
    BACKSHELL
    Connector backshells shall be potted and molded, or use stress relief boots as required, in accordance with applicable engineering documentation.
    NASA-STD-8739.4 [13.1.1.c]
    PREFERRED
    BEND RADIUS
    Cables and harnesses shall not be subjected to bending forces resulting in radii less than the minimum specified for the most sensitive component (i.e.: coaxial, fiber, etc.) in the assembly.
    Best Workmanship Practice
    coaxial and fiber optic cablecoaxial and fiber optic cables
    PREFERRED
    COAXIAL/FIBER OPTIC CABLE LOCATION
    Harnesses should be designed so that coaxial/fiber optic cables are located at or near the bundle center to minimize flexure and to provide additional protection.
    PREFERRED
    COAXIAL/FIBER OPTIC CABLES
    Coaxial cable (flexible, semi-rigid, rigid) and fiber optic cables shall exhibit a neatly organized layout, with smooth bends and sufficient stress relief.
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    preferred connectordiscrete wire harnesses
    PREFERRED
    CONNECTOR STYLE
    Connectors shall be straight, right-angle or flange-mount. The use of right-angle connectors shall be minimized and restricted to applications where stress-free mounting of the cable assembly can be assured.
    PREFERRED
    DISCRETE WIRE HARNESSES
    Harnesses exhibit a neatly organized layout with smooth bends and sufficient stress relief. Connector cable clamps and cable straps are properly set.
    NASA-STD-8739.4 [19.6.1.e]
    dust capshybrid cables and harnesses
    PREFERRED
    DUST CAPS
    The mating surfaces of all unmated connectors shall be protected by covers during storage, handling and installation. Connectors on ESD sensitive hardware shall be protected by ESD rated dust caps/covers.
    NASA-STD-8739.4 [13.1.2], [16.2.4], [16.3.3]
    PREFERRED
    HYBRID CABLES/HARNESSES
    Hybrid cables/harnesses (copper/fiber optic/coaxial conductors) shall be designed to comply with the requirements of the most sensitive and demanding component (typically the fiber optic cable) in the assembly.
    identification markings on cables and harnessesidentification on connector
    PREFERRED
    IDENTIFICATION
    CABLES/HARNESSES
    Each cable/harness shall be identified by a permanent label/marking.
    NASA-STD-8739.4 [14.2.1]
    PREFERRED
    IDENTIFICATION
    CONNECTOR
    Each connector shall be identified by a permanent label/marking affixed directly to the connector body, or to the cable adjacent to the connector.
    NASA-STD-8739.4 [14.2.2]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束
    GENERAL REQUIRMENTS (cont.)
    polarizationribbon cable
    PREFERRED
    POLARIZATION/KEYING
    Interconnecting cables and harnesses shall be designed with physical constraints (keying, sizing, polarization, etc.) to prevent incorrect mating/interchanging with similar sized/colored connectors.
    NASA-STD-8739.4 [7.1]
    PREFERRED
    RIBBON CABLE
    The cable assembly meets dimensional, layout and design requirements and exhibits a smooth, flat profile with no visible damage to the connectors or the insulation. Connectors are properly aligned and seated.
    floating shield terminationgrounded shield termination
    PREFERRED
    SHIELD TERMINATION - FLOATING
    Heat shrink tubing is properly installed, tightly shrunk and the termination is visible. Overlaps are of sufficient length to meet minimum electrical spacing.
    NASA-STD-8739.4 [9.8.1], [9.9], [11.5], [19.6.1]
    PREFERRED
    SHIELD TERMINATION - GROUNDED
    Heat shrink sections are properly installed, tightly shrunk and the termination is visible. Overlaps meet minimum electrical spacing. Ground wire exhibits proper bend radius and strain relief.
    NASA-STD-8739.4 [7.3.22], [9.8.1], [9.9], [11.5], [19.6.1]
    spot tiesbackshell assembly
    ACCEPTABLE
    SPOT TIES
    Spot ties shall consist of a clove hitch, followed by a square or other similar non-slip knot (i.e.: surgeon, etc.).
    NASA-STD-8739.4 [9.2.2]
    ACCEPTABLE
    BACKSHELL ASSEMBLY
    Connector backshells, adapters and clamps shall be assembled and torqued per engineering documentation.
    NASA-STD-8739.4 [13.5]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    backshell screwexcessive thread protrusion
    ACCEPTABLE
    BACKSHELL SCREW PROTRUSION
    Screws shall protrude a minimum of 1-1/2 threads beyond the threaded hardware (e.g., nut, clamp, etc.), but shall not violate minimum electrical spacing or snag requirements, unless otherwise specified by engineering documentation.
    UNACCEPTABLE
    EXCESSIVE THREAD PROTRUSION
    Excess thread protrusion represents an assembly, interference and electrical separation problem, as well as adds unnecessary weight to the assembly.
    breakout dress with fabric braidsplit braiding at breakout
    ACCEPTABLE
    BREAKOUT DRESS W/ FABRIC BRAID
    Braiding shall be dressed to form a smooth profile across the breakout. Braiding shall not be split, slit or punctured to provide a breakout opening.
    NASA-STD-8739.4 [9.3]
    UNACCEPTABLE
    SPLIT/SLIT BRAIDING AT BREAKOUT
    Braiding shall not be split, slip or punctured to provide an opening at the breakout.
    cable lacing and running stitchcable layup
    ACCEPTABLE
    CABLE LACING
    RUNNING STITCH
    The lacing begins and ends with a knot. Wraps are properly spaced (relative to harness diameter) to maintain the wiring in a tight, neat bundle. Ends are properly trimmed.
    NASA-STD-8739.4 [9.2]
    UNACCEPTABLE
    CABLE LAYUP
    Cables containing discrete conductors shall be fabricated in one or more layers, by winding the conductors together uniformly. Layup (twist) of each layer shall be 8-16 times the outer harness diameter.
    NASA-STD-8739.4 [7.3.20], [19.6.1.e.4]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    cable lacing and spot tiesloose cable lacing
    ACCEPTABLE
    CABLE LACING
    SPOT TIES
    Ties are neat, tight and properly spaced (relative to harness diameter) to maintain the wiring in a tight, neat bundle. Ends are properly trimmed.
    UNACCEPTABLE
    LOOSE CABLE LACING
    The lacing has not been properly installed, resulting in a loose, unorganized bundle.
    NASA-STD-8739.4 [19.6.2.d.4]
    cable strap with metal tangsconductor dress
    ACCEPTABLE
    CABLE STRAPS/TIES
    Plastic straps should have metal tangs that lock securely into the ribbed portion of the strap.
    NASA-STD-8739.4 [7.3.4]
    ACCEPTABLE
    CONDUCTOR DRESS
    All wires are dressed with even bends and sufficient strain relief. Conductor crossover is minimized.
    cable ties and wrapsuntrimmed cable ties
    ACCEPTABLE
    CABLE TIES/TIE WRAPS
    The cable ties/tie wraps are sufficiently tight to prevent lateral movement along the cable bundle under normal handling, but can be rotated in place. Strap ends have been trimmed off square and flush with the face of strap head.
    NASA-STD-8739.4 [9.6]
    UNACCEPTABLE
    UNTRIMMED CABLE TIES
    The strap end shall be trimmed off, flush with the back end of the strap head.
    NASA-STD-8739.4 [9.6], [19.6.2.d.5]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    connector saversdirect weave fabric braid
    ACCEPTABLE
    CONNECTOR SAVERS
    The use of connector savers is recommended. Connector savers shall meet the same requirements as a flight connector.
    NASA-STD-8739.4 [17.2.7]
    ACCEPTABLE
    DIRECT WEAVE FABRIC BRAID
    Fabric braids woven directly on interconnecting harnesses or cables may be loose or tight. The finish shall be smooth, without gaps in coverage, and without frayed ends.
    NASA-STD-8739.4 [9.4]
    scuffing on connectordiscoloration on insulation
    ACCEPTABLE
    DISCOLORATION/SCUFFING
    CONNECTOR
    Slight scuffing or discoloration is acceptable, provided there is no impact to form, fit or function, and there is no exposure of base metal.
    ACCEPTABLE
    INSULATION
    The cable does not exhibit evidence of insulation damage, such as cuts, nicks, scrapes, crushing, cold flow or burns. Slight scuffing or discoloration is acceptable.
    NASA-STD-8739.4 [19.6.2.e.9]
    fabric braided sleevingfabric braid sleeving
    ACCEPTABLE
    FABRIC BRAIDED SLEEVING
    Prewoven fabric (unvarnished) braid sleeving may be installed over the wire harness. Sleeving shall be snug, secured at both ends and shall not slide freely. Ends shall not be frayed or unraveled, and shall be tucked under.
    ACCEPTABLE
    FABRIC BRAID SLEEVING
    ALTERNATE END DRESS
    The end of the braid may be secured by connector clamps, other hardware or potting.
    NASA-STD-8739.4 [9.3.2]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    fabric braid sleevingglass braid sleeving
    ACCEPTABLE
    BASIC END TERMINATION
    The end of the braid shall be tucked under and secured with a spot tie or plastic strap.
    NASA-STD-8739.4 [9.3.1]
    ACCEPTABLE
    GLASS BRAID SLEEVING
    The ends of glass braid may be bonded by use of adhesive, and then secured by spot tie or other means to prevent movement on the wire bundle.
    NASA-STD-8739.4 [9.3.3]
    group shield terminationdaisy chain ground termination
    ACCEPTABLE
    GROUP SHIELD TERMINATION
    Shield ground leads shall be terminated to a common ground point. No more than 4 conductors, plus a drain wire, shall be terminated in a single splice.
    NASA-STD-8739.4 [11.6]
    UNACCEPTABLE
    DAISY-CHAIN GROUND TERMINATION
    Shield ground leads terminated in a dasy-chain configuration are susceptible to a single-point failure, should one of the links break.
    NASA-STD-8739.4 [19.6.2.f.2]
    heat shrinkable sleevingheat shrink tube as stress relief
    ACCEPTABLE
    HEAT SHRINKABLE SLEEVING
    Sleeving shall be sized to provide a tight, smooth finish in the area of maximum diameter. Tubing shall be uniformly shrunk, without cracks, punctures, charred, burns or wrinkles.
    NASA-STD-8739.4 [9.8.1], [9.11], [19.6.1.e.13]
    ACCEPTABLE
    HEAT SHRINK TUBING AS STRESS RELIEF
    The sleeving covers the termination and extends a minimum of 5 mm (0.20 in.) over the wire insulation. Tubing is fully shrunk, tight and sufficiently rigid to provide stress relief and prevent flexure at the solder termination.
    NASA-STD-8739.4 [9.9], [Fig. A]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    cable with identificationin line splice
    ACCEPTABLE
    IDENTIFICATION
    Each cable/harness shall be identified by a permanent label/marking. Each connector shall be identified by a permanent label/marking affixed directly to the connector body, or to the cable adjacent to the connector.
    NASA-STD-8739.4 [14.2.1], [14.2.2]
    ACCEPTABLE
    IN-LINE SPLICE
    The splice exhibits a smooth profile, proper strain relief and is located in an area of the harness not subjected to flexure.
    insulation wrapmetal braid sleeving
    ACCEPTABLE
    INSULATION WRAP
    Non-conductive tape/insulation wrap may be used in applications in which the use of heat-shrinkable tubing is impractical. Tape and wrapping materials shall be installed per engineering documentation.
    ACCEPTABLE
    METAL BRAID SLEEVING
    Metal braid sleeving may be installed over harnesses by either direct weave or by use of prewoven tubing. An insulation/separation layer shall be installed between the harness and the metal braid.
    NASA-STD-8739.4 [9.7]
    overall harness shieldingpolymide and nylon braid sleeving with hot knife sealing
    ACCEPTABLE
    OVERALL HARNESS SHIELDING
    An overall braided metallic shield provides mechanical and electrical protection (EMI/RFI) to the harness. Metallic shielding shall exhibit a smooth and tight finish, with a uniform distribution of coverage and no projecting strands.
    NASA-STD-8739.4 [11.1.3]
    ACCEPTABLE
    POLYIMIDE/NYLON BRAID SLEEVING
    HOT KNIFE SEALING
    Polyimide or nylon braids (for use on ground support equipment) may have their ends sealed by use of a "hot knife" or similar instrument.
    NASA-STD-8739.4 [9.3.4]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    shield and drain wirespiral wrap sleeving
    ACCEPTABLE
    SHIELD/DRAIN WIRE
    The shield and drain wire have been properly terminated, per engineering documentation.
    NASA-STD-8739.4 [19.6.1.f.2]
    ACCEPTABLE
    SPIRAL WRAP SLEEVING
    Spiral wrap shall be tight, uniformly spaced and shall not overlap. Ends shall be trimmed to eliminate sharp edges.
    Note: Spiral wrap shall not be used on spacecraft or launch vehicles.
    NASA-STD-8739.4 [9.5]
    solder sleeve terminationsolder sleeve termination
    ACCEPTABLE
    SOLDER SLEEVE TERMINATION
    The solder sleeve has been properly installed and tightly shrunk. Strain relief is acceptable. Overlaps are of sufficient length to meet minimum electrical spacing. Solder fillet is visible, fully flowed and smooth.
    NASA-STD-8739.4 [11.4]
    UNACCEPTABLE
    The solder sleeve has not been completely shrunk and is improperly positioned, resulting in a poor fit that does not provide a good mechanical grip or seal, and which does not meet minimum overlap requirements.
    splice assemblystrain relief
    ACCEPTABLE
    SPLICE ASSEMBLY PROFILE
    The location of splices shall be staggered to minimize the increase in profile to the harness. Final assembly profile shall not impact form, fit or function.
    ACCEPTABLE
    STRAIN RELIEF
    The cable (shield/unshielded) should be dressed to ensure that the strain relief mechanism transfers structural stresses from the connector to the cable sheath (or strength member) rather than to the individual conductors.
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    splice and solder sleeve restraintsplice and solder sleeve restraint
    ACCEPTABLE
    SPLICE/SOLDER SLEEVE RESTRAINT
    Cable ties/lacing shall be installed at both ends of a splice or solder sleeve, but placement shall not violate stress relief requirements.
    UNACCEPTABLE
    Cable ties/lacing shall not be installed across the splice/solder sleeve body, unless sufficient protection is provided to prevent compression damage to the termination and/or to the insulation of adjacent conductors.
    stress reliefinsufficient stress relief
    ACCEPTABLE
    STRESS RELIEF
    Wires exiting from the connector shall be stress relieved.
    UNACCEPTABLE
    INSUFFICIENT STRESS RELIEF
    The placement of cable ties/straps shall not negate strain relief in cables or harnesses.
    tie and wrap spacing on wiresincorrect tie spacing on wires
    ACCEPTABLE
    TIE/WRAP SPACING
    NASA-STD-8739.4 [9.2], [19.6.1.e.5]
    UNACCEPTABLE
    INCORRECT TIE SPACING
    Cable ties/wraps have not been properly spaced relative to bundle/harness diameter.
    NASA-STD-8739.4 [19.6.2.d.7]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    tie and wrap spacing at breakoutuniform conductor tension
    ACCEPTABLE
    TIE/WRAP SPACING AT BREAKOUT
    Lacing or tie wraps have been placed on both sides of the harness breakouts. Ties are neat and tight.
    ACCEPTABLE
    UNIFORM CONDUCTOR TENSION
    The conductors exhibit uniform tension throughout the length of the harness. No bunching, bowing, looping, kinks, etc.
    NASA-STD-8739.4 [19.6.1.e.3]
    unused spare conductorsdamaged connector
    ACCEPTABLE
    UNUSED/SPARE CONDUCTORS
    Unused or spare conductors shall be terminated by folding the unstripped end back on itself and then sealed with insulation sleeving or wrap. Conductor ends shall be secured to prevent unwanted movement, protrusion or snagging.
    NASA-STD-8739.4 [19.6.1.e.19]
    UNACCEPTABLE
    DAMAGE
    CONNECTOR
    Damage to the connector (i.e.: cuts, gouges, cracks, deformed features, bent pins, exposed base metal, etc.).
    NASA-STD-8739.4 [19.6.1.e.1]
    damaged insulationexposed power contacts
    UNACCEPTABLE
    DAMAGE
    INSULATION
    Damage to the cable jacket, ribbon or conductor insulation (i.e.: cuts, pinching, nicks, scrapes, crazing, crushing, cold flow, exposed conductors, punctures, thinning or burns).
    UNACCEPTABLE
    EXPOSED POWER CONTACTS
    Active signal/live voltages shall be confined to connectors with sockets to preclude the exposure of voltage points when the connector is disconnected.
    NASA-STD-8739.4 [7.3.18]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    improper bend radiusimproper cable tie wrap tension
    UNACCEPTABLE
    IMPROPER BEND RADIUS
    The harness exhibits a bend radius that is less than the minimum recommended for the conductor type(s) used and overall harness diameter.
    NASA-STD-8739.4 [7.3.21]
    UNACCEPTABLE
    IMPROPER CABLE TIE/WRAP TENSION
    Cable tie/wrap tension is too loose, allowing lateral movement along the cable bundle under normal handling.
    improper cable tie wrap tensionimproper lacing knot
    UNACCEPTABLE
    Cable tie/wrap tension is too high, resulting in deformation and pinching of the wire insulation.
    NASA-STD-8739.4 [19.6.2.d.3]
    UNACCEPTABLE
    IMPROPER LACING KNOT
    The cable lacing has been secured with a bow-knot, rather than a square/non-slip knot. This tie may eventually loosen.
    improper routingimproper slice gauge size
    UNACCEPTABLE
    IMPROPER ROUTING
    Cables and harnesses shall be routed so that they are protected from abrasion, cold flow, cut through, vibration, chafing, flexing and sharp edges.
    NASA-STD-8739.4 [7.3.14]
    UNACCEPTABLE
    IMPROPER SPLICE GAUGE/SIZE
    Replacement conductors shall be of the same voltage and current rating as the original conductor.
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
    电缆和线束通用规范 (cont.)
    improper terminationincomplete coverage of metal braid
    UNACCEPTABLE
    IMPROPER TERMINATION
    Solder and/or crimped terminations that do not meet the requirements of NASA-STD-8739.3 and/or NASA-STD-8739.4 shall be cause for rejection.
    NASA-STD-8739.4 [13.1]
    UNACCEPTABLE
    INCOMPLETE COVERAGE OF METAL BRAID
    Metal braid sleeving shall exhit uniform coverage, to provide electrical and mechanical protection to the underlying harness.
    NASA-STD-8739.4 [19.6.2.b.8], [19.6.2.e.5]
    incorrect lacing materialprojecting shield strands
    UNACCEPTABLE
    INCORRECT LACING MATERIAL
    Waxed lacing shall not be used for spaceflight applications.
    NASA-STD-8739.4 [19.6.2.d.2]
    UNACCEPTABLE
    PROJECTING SHIELD STRANDS
    The shield strands have been improperly dressed, resulting in projecting strands that may result in an electrical short or sharp object (punture/snag) concern.
    splices in flexure zoneunsealed environmental connector
    UNACCEPTABLE
    SPLICES IN FLEXURE ZONE
    Splices shall not be installed in areas where the harness is designed to flex.
    UNACCEPTABLE
    UNSEALED ENVIRONMENTAL CONNECTOR
    Sealing plugs or unused pins shall be installed in all unwired/unused holes to retain the environmental rating of the connector.
    NASA-STD-8739.4 [7.3.19]
    美国宇航局工艺标准
    NASA logoReleased:
    04.05.2002
    Revision:
    Revision Date:
    Book:
    Section:
    4.01
    Page:
上海富熬电子科技有限公司
分销航空、航天相关特种产品品牌如下:
1、 特殊超细金属丝及超薄带:LFA、CFW、AMETEK、ARNOLD、PCC Rollmet等
2、连接器合作品牌:SOURIAU、AERO- ELECTRIC、 AirBorn、 AMP、 Amphenol、 Cinch、 TE、 ITT、 Radiall、 Rockwell、 Tri-Star、Positronic、Glenair、 Deutsch等;
3、线缆合作品牌:Nexans、 Carlisle、Harbour、 Nexans、 Micro-Coax、  Draka、  Gore、 Raychem、Thermax;
4、集成电路合作品牌:AD、IDT、NS、SATCON、TI、VICOR、INTERSIL、MICROSEMI、LATTICE;
5、开关/继电器/传感器合作品牌: EATON、HONEYWELL、LEACH、ENDEVCO、DEUTSH、ECE、GRAYHILL、EMRISE;
上海富熬电子科技有限公司
电话:86-21-5718-0233
传真:86-21-5718-0235
邮箱:sales@sh-fuao.com
网址:www.--sh-fuao.com
地址: 上海市奉贤区南桥镇解放东路1018号
ultrasonic drilling - 超声波打孔 (0) 投诉
P:2022-01-18 09:00:39
翻譯得有點糟糕  如果中文翻不好 應該直接上原文名詞
autonatic cutover - 自动换盘,自动换盘装置 (0) 投诉
P:2022-01-18 22:37:19
收到,下次这类会注意,谢谢!
ring wire - 塞环引线,环线 (0) 投诉
