首页 > 国外线缆
[问题求助] 求教! UL62尼龙包覆导线的弯曲试验5.1.9怎么确定老化时间和温度?
P:2022-01-07 21:01:40
求教! UL62尼龙包覆导线的弯曲试验5.1.9,这个条目没看到老化时间和温度的具体规定?
branch cable - 分支电缆 (0) 投诉
P:2022-01-07 22:47:56
air-space paper insulation - 空气纸绝缘 (0) 投诉
P:2022-01-08 08:59:57
5.1.9 Bend test on nylon-covered conductors
A nylon covering over an individual insulated conductor (see Clause 4.1.3.4) or on a SPT-1 cord (see
Clause 4.3.10.4) shall not show any cracks when wound six complete close turns around a mandrel
having the same diameter as the fifinished conductor (the minor diameter in the case of a SPT-1 cord) after
specimens have been subjected to the air-oven aging test applicable to the insulation class. Following the
air-oven test, the specimen shall be allowed to cool for 16 h to 96 h prior to flflexing. Wrinkles or folds in
the nylon do not constitute failures.
这很好理解。after specimens have been subjected to the air-oven aging test applicable to the insulation class试样经过适用于绝缘等级的空气烘箱老化试验后。 即是按绝缘的老化条件。
songfeiX 奖励 10 金币,5 声望,于 2022-01-08 09:50:43 原因:奖罚
connecting loss - 连接损耗,连接器损耗 (1) 投诉
P:2022-01-12 23:11:28
用尼龙的考量是什么?更小的OF?
piezoelectric layer - 压电层 (0) 投诉
