首页 > 国外线缆
[问题求助] UL 2733电线最大直径可以做多大?
P:2021-11-23 13:49:10
APPLIANCE WIRING MATERIAL
RATING | |||
105 deg C, 600 Vac, Horizontal Flame. | |||
INSULATION | |||
Labeled Style 1015 | |||
ASSEMBLY | |||
Two to seven conductors cabled together. Length of lay not specified. Fillers optional. Maximum diameter of cable assembly under jacket is 0.350 inches. | |||
JACKET | |||
Extruded PVC, 15 mils minimum average, 12 mils minimum at any point. | |||
STANDARD | |||
Appliance Wiring Material UL 758. | |||
MARKING | |||
General. | |||
USE | |||
Internal Wiring. 这是UL对UL2733的要求,另外还要看你们自己的活页。 |
heavy cabling equipment - 重型电缆敷设设备,大型成缆设备 (1) 投诉
P:2021-11-26 11:09:35
WHP2016:APPLIANCE WIRING MATERIAL
Subj.758
Section 2
Page 2733
Issued: 1975-06-23
Revised: 2012-07-10
Style 2733
Multiple Conductor Cable using Non-Integral Extruded Jacket
RATING
INSULATION
Labeled Style 1015
ASSEMBLY
JACKET
STANDARD
MARKING
General.
USE
laboratory equipment - 试验室设备 (0) 投诉
P:2021-11-26 11:10:25
Subj.758
Section 2
Page 2733
Issued: 1975-06-23
Revised: 2012-07-10
Style 2733
RATING
INSULATION
Labeled Style 1015
ASSEMBLY
JACKET
STANDARD
MARKING
General.
USE
谢谢!请问活页在哪里找,怎样才可以看见?
Kinel - 基尼尔(法国Rhone Poulenc公司生产的一种聚(双马来)酰亚胺商品名,可用来加工塑料) (0) 投诉
P:2023-03-17 17:23:38
right handstoek stand - 右顶针架 (0) 投诉
