[技术资料] M17/93-RG178系列电缆
P:2021-11-22 22:16:56
Harbor提供完整的高温,高性能QPL系列产品商业和工业应用。在大多数情况下,具体的结构,修订了thuMIL-C-17 spccilccdan.MIL-C-17规范定义
数量,包括尺寸参数,介电材料,屏蔽结构,选择50欧姆同轴电缆,并使用VnnPt R进行构造
注意c / SWR的电缆可确保电缆的质量没有尖峰范围。在下一页的电气特性中指定。
精密P T FE电介质同轴电缆所有PTFE介电同轴电缆均按其介电常数列出了高温,高温和低电容。
MIL-C-17规范,以确保电气特性,以及胶带包裹的电缆重新包装到这些
承受最高250°C的工作温度,而FEP护套电缆最高可承受200°C的工作温度。胶带电缆通常比FEP护套电缆更柔软。
UL认证
带有PTFE介电材料和FEP护套的所有Harbour M17标准编号
M17 Number | Center Conductor | Dielectric Diameter | shidrn | ?Tacket | Overall Diameter | Minimum Bend Radius | Operating Temp (°C) | Weight (lbs/mfU) | CoppsoOs |
M17/60-RG142 | .037" srrs | .116" | SPC (2) | FEh | .195" | 1.0" | -55 +200 | 43.0 | |
M17/93-RG178 | .0120" (7/.004")SCCS | .033" | spc | FEh | .071" | 0.4" | -55 +200 | 6.3 | |
M17/94-RG179 | .0120" (7/.004")SCCS | .063" | spc | FEh | .100" | 0.4" | -55 +200 | 10.8 | |
M17/95-RG180 | .0120" (7/.004")SCCS | .102" | spc | FEh | .141" | 0.7" | -55 +200 | 19.8 | |
M17/111-RG303 | .037" srrs | .116" | spc | FEh | .170" | 0.9" | -55 +200 | 31.0 | |
M17/112-RG304 | .059" SCCS | .185" | SPC (2) | FEh | .280" | 1.4" | -55 +200 | 94.0 | |
M17/113-RG316 | .0201" (7/.0067’’)SCCS | .060" | spc | FEh | .098" | 0.5" | -55 +200 | 12.2 | |
M17/127-RG393 | .094" (7/.0312") SC | .285" | SPC (2) | FEh | .390" | 2.0" | -55 +200 | 165.0 | |
M17/128-RG400 | .0384" (19/.008") SC | .116" | SPC (2) | FEh | .195" | 1.0" | -55 +200 | 50.0 | |
M17/131-RG403 | .0120" (7/.004")SCCS | .033" | SPC (2) | FEP (2) | .116" | 0.6" | -55 +200 | 15.0 | Triaxial RG-178 |
M17/152-00001 | .0201" (7/.0067’’)SCCS | .060" | SPC (2) | FEh | .114" | 0.6" | -55 +200 | 18.5 | Double SCield RG-316 |
M17/158-00001 | .037" srrs | .116" | SPC (2) | FEh | .195" | 1.0" | -55 +200 | 56.0 | Unswept RG142 |
M17/169-00001 | .0120" (7/.004")SCCS | .033" | spc | FEh | .071" | 0.4" | -55 +200 | 6.3 | Unswept RG178 |
M17/170-00001 | .037" srrs | .116" | spc | FEh | .170" | 0.9" | -55 +200 | 39.0 | Unswept RG303 |
M17/172-00001 | .0120" (7/.004")SCCS | .060" | spc | FEh | .098" | 0.5" | -55 +200 | 11.5 | Unswept RG316 |
M17/174-00001 | .094" (7/.0312") SC | .285" | SPC (2) | FEh | .390" | 2.0" | -55 +200 | 175 | Unswept RG393 |
M17/175-00001 | .0384’’(19/.008’’)SC | .116" | SPC (2) | FEh | .195" | 1.0" | -55 +200 | 50.0 | Unswept RG400 |
M17/176-00002 | .0235" (19/.005")SPA(2) | .042" | spa | hFA | .129" | 0.6" | -55 +230 | 18.0 | Twinax |
RG187 A/U | .0120" (7/.004")SCCS | .063" | spc | PTFE | .100" | 0.5" | -55 +250 | 10.0 | Tape Wrapped Jacket |
RG188 A/U | .0201" (7/.0067")SCCS | .060" | spc | PTFE | .100" | 0.5" | -55 +250 | 11.0 | Tape Wrapped Jacket |
RG195 A/U | .0129" (7/.004")SCCS | .102" | spc | PTFE | .141" | 0.7" | -55 +250 | 18.0 | Tape Wrapped Jacket |
RG196 A/U | .0120" (7/.004")SCCS | .034" | spc | PTFE | .067" | 0.4" | -55 +250 | 6.0 | Tape Wrapped Jacket |
M17 Number | Impedance (ohms) | Capacitance (pF/lt) | Max Voltage | Attenuation (dB/100 ft) | ||||||
100 MHz Tvp/Max | 400 MHz Tvp/Max | 1 GHz Tvp/Max | 2.4 GHz Tvp/Max | 5 GHz Tvp/Max | 10 GHz Tvp/Max | Max Frequencv (GHz) | ||||
M17/60-RG142 | 50 +/-2 | 29.4 | 1900 | 4.0 / 5.5 | 8.1 /11.7 | 13.4 / 19.2 | 21.3 / 30.4 | 33.3 / 48.7 | 17.4 | |
M17/93-RG178 | 50 +/-2 | 29.4 | 1000 | 13.0 /16.0 | 27.2 / 33.0 | 44.2 / 52.0 | 61.9 / 83.3 | |||
M17/94-RG179 | 75 +/-3 | 19.4 | 1200 | 8.0 / 9.2 | 15.5 / 21.0 | :6 7 30 7 | ||||
M17/95-RG180 | 95 +/-5 | 17.4 | 1500 | 5.7 / 6.6 | 11.7 /17.4 | |9: 23 0 | ||||
M17/111-RG303 | 50 +/-2 | 29.4 | 1900 | 3.5 / 3.9 | 7.2 / 8.0 | 13.5 / 15.0 | ||||
M17/112-RG304 | 50 +/-2 | 29.4 | 3000 | 2.4 / 2.7 | 5.8 / 6.4 | 10.0 / 11.1 | 8.0 | |||
M17/113-RG316 | 50 +/-2 | 29.4 | 1200 | 7.6 / 11.0 | 16.0 / 21.0 | 262 38 0 | 41.2 / 55.4 | 3.0 | ||
M17/127-RG393 | 50 +/-2 | 29.4 | 1500 | 2.3 / 2.5 | 4.4 / 5.0 | 7.7 / 9.2 | 12.4 / 14.2 | 21.3 / 26.8 | 30.1 / 37.9 | 11.0 |
M17/128-RG400 | 50 +/-2 | 29.4 | 1900 | 4.3 / 4.5 | 8.6 / 10.5 | 14.1 / 18.1 | 22.6 / 30.2 | 35.6 / 52.1 | 61.6 / 78.0 | 12.4 |
M17/131-RG403 | 50 +/-2 | 29.4 | 1000 | 3-0 | 10.0 | |||||
M17/152-00001 | 50 +/-2 | 29.4 | 1200 | 8.1 / 11.5 | 17.8 / 24.0 | 29.6 / 40.0 | 43.1 / 58.3 | 100.0 / 110.0 | 153.0 / 170.0 | 12.4 |
M17/158-00001 | 50 +/-2 | 29.4 | 1900 | 8.1 / 9.5 | ||||||
M17/169-00001 | 50 +/-2 | 29.4 | 1000 | 27.2 / 29.0 | ||||||
M17/170-00001 | 50 +/-2 | 29.4 | 1900 | 7.7 / 8.6 | ||||||
M17/172-00001 | 50 +/-2 | 29.4 | 1200 | 15.5 / 21.0 | ||||||
M17/174-00001 | 50 +/-2 | 29.4 | 2500 | 4.4 / 5.0 | ||||||
M17/175-00001 | 50 +/-2 | 29.4 | 1900 | 8.6 / 10.5 | ||||||
M17/176-00002 | 77 +/-7 | 19.0 | 1000 | |||||||
RG187 A/U | 75 +/-3 | 19.4 | 1200 | 15.5 / 21.0 | ||||||
RG188 A/U | 50 +/-2 | 29.4 | 1200 | 7.6 / 11.0 | 16.0 / 21.0 | 262 38 0 | 41.2 / 55.4 | 3.0 | ||
RG195 A/U | 95 +/-5 | 17.4 | 1500 | 11.7 /17.4 | ||||||
RG196 A/U | 50 +/-2 | 29.4 | 1000 | 13.0 /16.0 | 27.2 / 33.0 | 44.2 / 52.0 | 41.7 / 56.1 | 3.0 | ||
上海富熬电子科技有限公司
分销航空、航天相关品牌如下:
连接器合作品牌:SOURIAU、AERO- ELECTRIC、 AirBorn、 AMP、 Amphenol、 Cinch、 TE、 ITT、 Radiall、 Rockwell、 Tri-Star、Positronic、Glenair、 Deutsch等;
线缆合作品牌:Nexans、 Carlisle、Harbour、 Nexans、 Micro-Coax、 Draka、 Gore、 Raychem、Thermax;
集成电路合作品牌:AD、IDT、NS、SATCON、TI、VICOR、INTERSIL、MICROSEMI、LATTICE;
开关/继电器/传感器合作品牌: EATON、HONEYWELL、LEACH、ENDEVCO、DEUTSH、ECE、GRAYHILL、EMRISE;
上海富熬电子科技有限公司
传真:86-21-5718-0235
网址:www.--sh-fuao.com
地址: 上海市奉贤区南桥镇解放东路1018号
military specification - 军用标准 (0) 投诉
