[材料介绍] California Fine Wire Co. CFW加州精线 航空航天等级金属丝 介绍
P:2021-11-13 15:11:27
CFW成立与1961年,一直致力于生产总类齐全的金属及合金线产品,几十年来我们一直为客户提供优异的产品。
CFW提供的产品应用与各个行业,如医疗、科研、航天等领域,目前CFW与上海富熬电子携手开拓国内市场,为客户提供高标准等级材料;
CFW线材分类
1、铜及其合金线、电阻线、贵金属线
2、镍及其合金线、难熔金属线、金属复合线
3、铝及其合金、热偶线、Glass Sealing Alloys
4、半导体、RTD线、高温线(陶瓷绝缘)
5、定制合金线、保险丝、Fine Wire & Ribbon, Potentiometer Alloys等
MATERIAL | SPECIFIC RESISTANCE (Ω–CM/F) | MELTING POINT °C | COMPOSITION | |
Aluminum | ||||
1 | ALUMINUM 1% SILICON | 15.2 | 657 | |
2 | ALUMINUM 1199 | 15.97 | 660 | Al99.99% |
3 | ALUMINUM EC 1350 | 16.83 | 657 | Al99.45% |
4 | ALUMINUM 2024 | 20.25 | 638 | Al93.84%Cu4.5%Mg1.5%Mn0.16% |
5 | ALUMINUM 3003 | 20.25 | 634 | Al98.8%Mn1.2% |
6 | ALUMINUM 4043 | 25 | 632 | Al94.75%Si5.25% |
7 | ALUMINUM 5005 | 19.95 | 652 | Al99.2%Mn0.8% |
8 | ALUMINUM 5052 | 10.23 | 649 | Al97.25%Cr0.25%Mn2.5% |
9 | ALUMINUM 5056 | 35.79 | 638 | Al94.6%Cr0.1%Mg0.1%Mn0.1% |
10 | ALUMINUM 6061 | 23.04 | 649 | Al97.9%Cr0.25%Cu0.25%Mg1%Si0.6% |
Copper | ||||
1 | ALLOY 725 | 94.3 | 1060 | Cu88.2%Ni9.5%Sn2.3% |
2 | BE COPPER ALLOY 10 CDA 175 | 22.8 | 1029 | Be0.55%Co2.55%Cu96.9% |
3 | BE COPPER ALLOY 25 CDA 172 | 46.2 | 865 | Be1.8%Cu98.1% |
4 | BE COPPER CDA 17410 | 36.9 | 1025 | Be0.3%Co0.5%Cu99% |
5 | BRASS FREE-CUT CDA 360 | 39.9 | 885 | Cu61.5%Pb3.1%Zn35.4% |
6 | BRASS 7030 CDA 230 | 37 | 915 | Cu70%Zn30% |
7 | BRASS GILDING CDA 210 | 18.5 | 1050 | Cu95%Zn5% |
8 | CADMIUM COPPER CDA 162 | 11.5 | 1030 | Cd1%Cu99% |
9 | COMMERCIAL BRONZE 90% CDA 220 | 23.6 | Cu90%Zn10% | |
10 | COPPER 27% NICKEL CLAD | 14 | 1100 | Cu99.9%Ni99% |
11 | COPPER 99.95% CDA 102 OF | 10.3 | 1083 | Cu99.5%min |
12 | COPPER 99.99% CDA 101 | 10.3 | 1083 | Cu99.99%min |
13 | COPPER ETP MAGNET WIRE | 10.3 | Cu99.9%min | |
14 | COPPER NICKEL 20% | 160 | 1150 | Cu79%Ni21% |
15 | COPPER ZIRCONIUM CDA 150 | 11.2 | 980 | Cu99.85%Zr0.15% |
16 | CUPRO NICKEL 70-30 | 225 | 1170 | Cu69.5%Fe0.5%Ni30% |
17 | LOW BRASS CDA 240 | 32.4 | 965 | Cu80%Zn20% |
18 | NICKEL SILVER CDA 752 | 173 | 1070 | Cu65%Ni18%Zn17% |
19 | NICKEL SILVER CDA 757 | 130 | 1040 | Cu65%Ni12%Zn23% |
20 | NICKEL SILVER CDA 764 | 189 | 1020 | Cu60%Ni18%Zn22% |
21 | PD-135 | 11.3 | 1080 | Cd1%maxCr1%maxCu99%min |
22 | PH BRONZE 5% CDA 510 A | 69.1 | 950 | Cu94.8%P0.2%Sn5% |
23 | PH BRONZE 8% CDA 521 C | 79.8 | 880 | Cu92%P0.16%Sn8% |
24 | PH BRONZE 10% CDA 524 D | 94.3 | 845 | Cu90%Sn10% |
Nickel | ||||
1 | ALLOY 99 | 48 | 1450 | Ni99.8%min |
2 | DURANICKEL 301 | 255 | 1450 | Al4%-4.75%Ni93%Ti0.25%-1% |
3 | MONEL 400 | 290 | 1350 | Cu32.5%Fe2.5%Mn2%Ni63% |
4 | MONEL 404 | 319 | 1299 | Cu43%-48%Ni52%-57% |
5 | Monel K 500 | 370 | Al2.3%-3.15%Cu23.35%-34.5%Fe2%maxMn1.5%maxNi63%-70% | |
6 | NICKEL 205 | 50 | 1450 | Ni99.45%min |
7 | NICKEL 211 | 102 | 1430 | Mn4.75%Ni93.7% |
8 | NICKEL 220 | 45 | 1450 | |
9 | NICKEL 270 | 45 | 1450 | Ni99.97%min |
10 | NICKEL A/200 | 48 | 1450 | Ni99%min |
Precious Metal | ||||
1 | ALLOY 20-245 | 245 | ||
2 | ALLOY 406 | 75 | ||
3 | ALLOY 411 | 37.0009 | Ag89%Pd11% | |
4 | ALLOY 417 | 57 | ||
5 | ALLOY 422 | 180 | 1880 | |
6 | ALLOY 443 | 80 | ||
7 | ALLOY 446 | 190 | ||
8 | ALLOY 486 | 610 | 1700 | |
9 | GOLD 99.99% BE MOD | 12.6 | 1063 | Au99.99%min |
10 | GOLD 99.99% | 14.14 | 1063 | Au99.99%min |
11 | PALLADIUM | 60 | 1554 | Pd99%min |
12 | PLATINUM 8% TUNGSTEN | 400 | 1870 | Pt92%W8% |
13 | PLATINUM 10% IRIDIUM | 150 | 1775 | Ir10%Pt90% |
14 | PLATINUM 10% RHODIUM | 111 | 1850 | Pt90%Rh10% |
15 | PLATINUM 20% IRIDIUM | 186 | 1840 | Ir20%Pt80% |
16 | PLATINUM 20% RHODIUM | 125 | 1900 | Pt80%Rh20% |
17 | PLATINUM PURE TC GRADE | 64 | 1773 | Pt99.99%min |
18 | RHODIUM 99.8% | 30 | 1960 | Rh99.8%min |
19 | SILVER 99.99% | 8.8 | 960 | Ag99.99% |
Resistance Wire | ||||
1 | MANGANIN 230 SHUNT | 230 | 1020 | Cu84%Mn12%Ni4% |
2 | MANGANIN 290 | 290 | 1020 | Cu84%Mn12%Ni4% |
3 | NICKEL ALLOY 30 | 30 | 1100 | Cu98%Ni4% |
4 | NICKEL ALLOY 60 | 60 | 1100 | Cu94%Ni6% |
5 | NICKEL ALLOY 90 | 90 | 1100 | Cu90%Ni10% |
6 | NICKEL ALLOY 120 | 120 | 1425 | Fe30%Ni70% |
7 | NICKEL ALLOY 180 | 180 | 1100 | Cu78%Ni22% |
8 | NICO | 294 | 1210 | Cu55%Ni45% |
9 | NIFE 5200 | 120 | 1425 | Fe30%Ni70% |
10 | STABLOHM 610 (TOPHET D) | 610 | 1300 | Cr20%Fe45%Ni35% |
11 | STABLOHM 650 | 650 | 1395 | Cr20%Ni80%Si1%-2% |
12 | STABLOHM 675 | 675 | 1350 | Cr16%Fe34%Ni60% |
13 | STABLOHM 710 | 710 | 1377 | Cr30%Ni70% |
14 | STABLOHM 750 | 750 | 1510 | Al4%Cr15%Fe81% |
15 | STABLOHM 800 A | 800 | 1395 | Al2.5%Cr20%Cu2.5%Ni75% |
16 | STABLOHM 812 | 812 | 1510 | Al4.5%Cr21%Fe74.5% |
17 | STABLOHM 875 | 875 | 1520 | Al5.5%Cr22.5%Fe72% |
Stainless Steel | ||||
1 | STAINLESS STEEL 302 | 420 | 1399 | |
2 | STAINLESS STEEL 304 | 420 | 1399 | |
3 | STAINLESS STEEL 305 | 420 | 1399 | |
4 | STAINLESS STEEL 308 | 455 | 1399 | |
5 | STAINLESS STEEL 309 | 170 | 1399 | |
6 | STAINLESS STEEL 310 | 520 | 1399 | |
7 | STAINLESS STEEL 316 | 470 | 1371 | |
8 | STAINLESS STEEL 316L | 445 | 1399 | |
9 | STAINLESS STEEL 347 | 470 | 1399 | |
10 | STAINLESS STEEL 430 | 360 | 1427 | |
材料应用
Glass Sealing Alloy | ||||
1 | Alloy 36 | 495 | 1427 | Fe64%,Ni36% |
2 | Alloy 42 | 430 | 1427 | Fe59%,Ni41% |
3 | Alloy 42-6 | 570 | Cr6%,Fe52%,Ni42% | |
4 | Alloy 52 | 258 | 1426 | Fe50%,Ni50% |
5 | Dumet | 58 | Cu99.9% | |
6 | Kovar | 294 | 1450 | Co17%,Fe54%,Ni29% |
Refractory Metals | ||||
7 | Molybdenum | 31 | 2610 | Mo99.9% |
8 | Tantalum R05200 | 74.6 | 2890 | Ta99.96% |
9 | Tantalum R05400 | 81.2 | 2890 | Ta99.96% |
10 | Tantalum | 81.2 | 2890 | Ta99.96% |
11 | Titanium 99% | 252 | 1660 | Ti99% |
12 | Tungsten 99.95% CS | 33 | 3420 | W99.95% |
Special Application | ||||
13 | Inconel 600 | 620 | 1354 | Cr17%,Fe10%,Ni72% |
14 | NI SPAN C ALLOY 902 | 611 | 1455 | Cr5.75%,Fe51.9%,Ni43%,Si1%,Ti2.75% |
15 | Steel Copper Clad 40% Cond | 25.9 | Cu99.99% | |
16 | Zinc 99.95% | 35.58 | 419 | Zn99.5% |
17 | Zirconium 99.% | 240 | Zr99.9% | |
Spring Wire | ||||
18 | Elgiloy | 599 | 1427 | Co40%,Cr20%,Fe18% ,Mo7%,Ni15% |
19 | Inconel 625 | 776 | 1288 | Cr23%,Mo10%,Nb4.15%,Ni4.15%,Ta4.15% |
20 | Inconel 718 | 751 | 704 | Cr17%,Fe8%,Mn2.5%,Ni63.25%,Ti3% |
21 | Inconel x750 | 731 | 816 | Cr17%,Mn1%,Nb1.2%,Ni70%Ta1.2%,Ti2.75% |
Thermocouple Wire | ||||
22 | Alumel TC Type K STD | 177 | 1400 | Al2%,Mn2%,Ni95% |
23 | Chromel P TC Type E STD | 425 | 1427 | Cr10%,Ni90% |
24 | Chromel P TC Type K STD | 425 | 1430 | Cr10%,Ni90% |
25 | Constantan TC Type E STD | 294 | 1221 | Cu55%,Ni45% |
26 | Constantan TC Type J STD | 294 | 1221 | Cu55%,Ni45% |
27 | Constantan TC Type T STD | 294 | Cu55%,Ni45% | |
28 | Copper TC Type T STD | 10.3 | Cu99.99% | |
29 | Iron TC Type J SPL | 75 | 1496 | Fe99% |
上海富熬电子科技有限公司 是CFW在国内航空、航天、医疗领等领域的独家代理,负责国内的市场及客户销售工作。
上海富熬电子科技有限公司
传真:86-21-5718-0235
网址:www.--sh-fuao.com
地址: 上海市奉贤区南桥镇解放东路1018号
hollow-end break - 空心端断线 (0) 投诉
