首页 > 国外线缆
[问题求助] 导体是铝,必须在AWM表面印字体现吗?
P:2021-10-12 14:13:24
导体是铝,必须在AWM表面印字体现吗?
drawing draft - 拉线模座;拉线道次 (0) 投诉
P:2021-10-12 18:46:56
UL758印字要求可以不印字,也可以印字。如果印字要按要求进行印字,看758关于的印字的详细要求
Satellite Antenna Cable - 卫星天线电缆 (0) 投诉
P:2021-10-13 08:56:08
Tag Markings -
      For products meeting only U.S. requirements, Tag markings are in accordance with the marking section of UL 758, the FUII , the Addendum and any requirements on the style page.
For products meeting only Canadian requirements, Tag markings shall have the following legible and durable markings:
(a) the manufacturer’s name, trade name, or other recognized symbol of identification;(b) the manufacturer’s identifying marker, if threads are used;
(c) the month and year of manufacturer;
(d) the size(s)(AWG or kcmil) of the conductors;
(e) the number of conductors;
(f) the type of conductor(if other than uncoated copper);
(g) “I” for Class I or “II”, or “I/II” for Class II, as applicable;
(h) “A” for Group A, “B” for Group B, or “A/B” for a product in both groups, as applicable;
(i) “wet” or “oil” or “fuel oil”, as applicable;
(j) the temperature rating (e.g., “80C”);
(k) the voltage rating (e.g., “150V”);
(l) limited use for internal wiring of electronic equipment and appliances (Class I only);
(m) the low temperature rating if below -15C (e.g., “-20C”, “-30C”, or “-40C”); and
(n) the dc resistance value (for resistance wire only).
software system - 软件系统 (1) 投诉
P:2021-10-14 07:58:52
dongsen332:
Tag Markings -
3楼,这才是行家,正解! FUII定义很清楚了
single-ply paper - 单层纸 (0) 投诉
P:2021-10-28 08:33:48
dual upset butt-welding - 双镦对焊,双镦对接焊 (0) 投诉
