首页 > 国外线缆
[问题求助] 求教UL62中的“R”类和“W”类具体指的啥
P:2021-07-05 20:58:03
消费者在使用 便携式风扇和电暖器 ( 取暖器、暖风机 ) 时普遍存在四种使用状况:
1 ) 消费者将风扇和电暖器或其他物体压在电源线上。
2 ) 消费者将风扇和电暖器推靠到墙边夹到电源线。
3 ) 消费者将风扇和加热器的电源线暴露在人会来回走动的地方。
4 ) 消费者在储存期间,电线暴露也会损坏。
“R”类就是增加以下4项测试内容
﹥ 磨损测试 Abrasion Test
﹥ 夹挤测试 Mandrel Pinching Test
﹥ 压碾测试 Mandrel Crushing Test
﹥ 弯曲测试 Flexing Test
vertical roller - 立辊,立式轧辊 (0) 投诉
P:2021-07-06 11:23:12
一、-R型在UL62没有定义R的名词,仅作为区分电缆型号的代码;(-R型需要额外增加4项测试,如下:)
Cords marked with the ″-R″ suffix as indicated in Clause 6.2.4(g) shall comply with the requirements
specified for the standard cord construction in addition to those specified in Clauses 4.2.13.2 – 4.2.13.5(Abrasion、Mandrel pinching、Mandrel crushing、Flexing).Cords marked with ″-R″ shall be limited to 0.824 – 2.08 mm2 (18 – 14 AWG), and 300 V.
二:-W型:UL62明确解释了名词:(注:-W型需额外增加4项测试:(抗UV 720Hrs&冷弯-30℃、Insulation resistance、Permittivity and stability factor、(第四项:根据具体电缆型号选测Swelling and blistering))
5.1.7 Weather resistance – all ″W″ cords and electric vehicle cables
,欢迎拍砖
reticular - 网状的,错综的 (2) 投诉
P:2021-07-06 13:52:53
UL电线标记与应用 里面有说明
Similarly, cables covered for use in accordance with Articles 725, 760, 770, 800, 820, and 830 of the NEC? are investigated with respect to their application: plenum, riser, general use or restricted residential use. Suffixes to the Type designation identify the use as defined in the appropriate NEC? articles:
-P: Plenum
-R: Riser
-No Suffix, -G: General purpose
-X: Limited residential use
Some wire and cable may also have a suffix ―-LS‖ or "ST1" which means that the entire construction complies with the requirements for flame retardant, limited smoke wiring materials as evaluated per UL 83, UL 1685 or UL 2556.
对于"W"里面有很多条款给予了说明,可以认为是“户外”使用电缆
ring network - 环形网络 (0) 投诉
