首页 > 国外线缆
[问题求助] 谁知道国内专业生产CMP级别通信线缆、网络线缆的生产厂家?
P:2008-04-14 12:27:42
谁知道国内专业生产CMP级别通信线缆、网络线缆的生产厂家?急需!!
drying tank - 干燥罐 (0) 投诉
P:2008-04-14 13:19:01
我们做﹐通过UL认证的。
refractive index difference - 折射率差 (0) 投诉
P:2008-04-14 14:11:11
江苏三角洲塑化有限公司,有很多呀,上网就可找到呀
surface quality - 表面质量 (0) 投诉
P:2008-04-14 16:28:52
CMP级别材料绝缘采用的是哪种材质的啊?因为看到不同的资料,说法不一样本人对此又没研究故有此一问!!
shotfiring cable - 放炮电缆,爆破电缆,引燃电缆 (0) 投诉
P:2008-04-23 17:19:11
CABLEX ELECTRONIC (WU JIANG) CO LTD
Communications Cable
<SCRIPT language=JAVASCRIPT> BldLink("DUZX.E236139", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX.E236139&ccnshorttitle=Communications Cable" + "&objid=1076386793&cfgid=1073741824&version=versionless" + "&parent_id=1073985853&sequence=1") </SCRIPT>DUZX.E236139
Communications Cable Certified for Canada
<SCRIPT language=JAVASCRIPT> BldLink("DUZX7.E236139", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX7.E236139&ccnshorttitle=Communications Cable Certified for Canada" + "&objid=1076386798&cfgid=1073741824&version=versionless" + "&parent_id=1073985855&sequence=1") </SCRIPT>DUZX7.E236139
DATWYLER CABLES & SYSTEMS
(SHANGHAI) CO LTD
<SCRIPT language=JAVASCRIPT> BldLink("DUZX.E245290", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX.E245290&ccnshorttitle=Communications Cable" + "&objid=1077448167&cfgid=1073741824&version=versionless" + "&parent_id=1073985853&sequence=1") </SCRIPT>DUZX.E245290
JINAN PAC CABLE & WIRE CO LTD
<SCRIPT language=JAVASCRIPT> BldLink("DUZX.E164061", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX.E164061&ccnshorttitle=Communications Cable" + "&objid=1074083337&cfgid=1073741824&version=versionless" + "&parent_id=1073985853&sequence=1") </SCRIPT>DUZX.E164061
<SCRIPT language=JAVASCRIPT> BldLink("DUZX7.E164061", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX7.E164061&ccnshorttitle=Communications Cable Certified for Canada" + "&objid=1074179048&cfgid=1073741824&version=versionless" + "&parent_id=1073985855&sequence=1") </SCRIPT>DUZX7.E164061
NINGBO ORIENT GROUP CO LTD
<SCRIPT language=JAVASCRIPT> BldLink("DUZX.E220470", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX.E220470&ccnshorttitle=Communications Cable" + "&objid=1075748668&cfgid=1073741824&version=versionless" + "&parent_id=1073985853&sequence=1") </SCRIPT>DUZX.E220470
<SCRIPT language=JAVASCRIPT> BldLink("DUZX7.E220470", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX7.E220470&ccnshorttitle=Communications Cable Certified for Canada" + "&objid=1075748673&cfgid=1073741824&version=versionless" + "&parent_id=1073985855&sequence=1") </SCRIPT>DUZX7.E220470
SCHNEIDER ELECTRIC (CHINA) INVESTMENT
CO LTD
<SCRIPT language=JAVASCRIPT> BldLink("DUZX.E317265", "/cgi-bin/XYV/template/LISEXT/1FRAME/showpage.html" + "?name=DUZX.E317265&ccnshorttitle=Communications Cable" + "&objid=1079196877&cfgid=1073741824&version=versionless" + "&parent_id=1073985853&sequence=1") </SCRIPT>DUZX.E317265
也可以在以下的网址中查到:http://database.ul.com/cgi-bin/XYV/cgifind.new/LISEXT/1FRAME/srchres.html
secondary distribution main - 二次配电干线 (0) 投诉
P:2008-04-23 17:23:03
在中国大陆就这么几家公司是合法的生产厂家,如果再有不清楚的,可以加我,在MSN:JIM9310@HOTMAI.COM
QQ:401747950.
Delay Skew - 延迟偏差 (0) 投诉
P:2008-04-24 08:47:06
新疆特电站~!
找去吧~!
ceramic liner - 瓷套管,陶瓷衬层 (0) 投诉
P:2008-05-15 20:50:32
绿茶:
什么时候也改做电线啦
bend testing machine - 弯曲试验机 (0) 投诉
P:2008-06-30 11:38:42
这个东东不是那么好做的,,,
distributed fiber-optic sensor - 分布式光纤传感器 (0) 投诉
P:2008-07-03 11:23:40
就是阿,说得容易,一把火全烧没了!!!
triple joint - 三头连接;电缆分支套管 (0) 投诉
