首页 > 国外线缆
[问题求助] UL铜导体用ASTM相关标准包含ASTM B3 /ASTMB33/ASTM B172/ASTM B 173 /ASTM B 174/ASTM B 738
P:2020-07-08 14:12:05
此系列ASTM标准为本人经过搜集得到,请有需要者下载参考。
cable longitudinal water-proof - 电缆纵向防水(密封) (0) 投诉
P:2023-12-31 11:01:12
Abstract
This specification covers tinned, round, soft, or annealed copper wire for electrical purposes. The tinned wire shall conformto the required tensile strength and elongation. Electrical resistivity shall be measured. The wire sizes shall be expressed as the diameter of the wire and shall be measured using micrometre caliper equipped with a vernier. The tin coating shall be continuous. The continuity of the wire shall be determined on representative samples taken before stranding or insulating. The continuity of tinning shall be determined by the hydrochlroic acid-sodium polysulfide test. The tin coating shall be firmly adherent to the surface of the copper. The adherence of coating on the wire shall be determined on representative samples taken before stranding or insulating. The adherence of coating shall be determined by the wrapping and immersion test.
Scope
1.1 This specification covers tin-coated, round, soft, or annealed copper wire for electrical purposes.
1.2 The values stated in inch-pound units are to be regarded as standard. The values given in parentheses are mathematical conversions to SI units that are provided for information only and are not considered standard.
1.2.1 Exceptions—The SI values for density, resistivity, and volume are to be regarded as standard.
1.3 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety, health, and environmental practices and determine the applicability of regulatory limitations prior to use.
1.4 This international standard was developed in accordance with internationally recognized principles on standardization established in the Decision on Principles for the Development of International Standards, Guides and Recommendations issued by the World Trade Organization Technical Barriers to Trade (TBT) Committee.
drycured material - 干式交联材料 (0) 投诉
