首页 > 产品认证
[其他认证] 超十种电缆电线被印度BIS列入强制认证类目,2020.8.1正式强制,出口印度的厂家请注意!
P:2020-03-11 12:57:40
针对总计13种线材及电缆产品,印度政府于年初发布,印度在售的厂家在售卖前必须获得印度BIS颁发的ISI证书,并在产品上印上认证标识。
以下法规(标准)于今年8.1正式强制生效,所涉及产品如下:
IS 1554(Part 1) : 1988+B375:C389B375:B375:C397Specification for PVC Insulated (Heavy Duty) Electric Cables   Part 1 For Working Voltages up to and Including 1100 V/  PVC绝缘(重型)大功率电缆规范,第1部分,适用于1100   V及以下的工作电压
IS 1554(Part   2) : 1988Specification for PVC   Insulated (Heavy Duty) Electric Cables Part 2 For Working Voltages from 3.3   kV up to and Including 11 Kv/ PVC绝缘(重型)大功率电缆规范,第2部分,工作电压范围为3.3   kV至11 kV(含)
IS 7098 (Part 1) : 1988Specification for Crosslinked Polyethylene Insulated PVC Sheathed   Cables Part 1 for working voltages up to and including 1100 V/ 交联聚乙烯绝缘PVC护套电缆规范,第1部分,适用于1100   V及以下的工作电压
IS 7098 (Part   2) : 2011Crosslinked   polyethylene insulated Thermoplastics sheathed cables – Specification Part 2   for working voltages from 3.3 kV up to and including 33 Kv/ 交联聚乙烯绝缘热塑性护套电缆–规范第2部分,工作电压范围为3.3 kV至33   kV(含)
IS 7098 (Part   3) : 1993Cross-Linked   Polyethylene Insulated Thermoplastics Sheathed Cables Part 3 For Working   Voltages from 66 kV Up to and Including 220 Kv/ 交联聚乙烯绝缘热塑性护套电缆第3部分,工作电压范围为66   kV至220 kV(含)
IS 14255 : 1995Aerial Bunched Cables – For Working Voltages Up   to and Including 1100 Volts – Specification/
     91/5000
    架空成束电缆–适用于1100伏及以下的工作电压–规格
IS 9968 (Part 2) : 2002Specification for Elastomer Insulated Cables Part 2 For Working   Voltages form 3.3 kV Up to and Including 33 Kv/ 弹性体绝缘电缆规范,第2部分,工作电压范围为3.3   kV及以下(包括33 kV)
IS 8784 : 1987Specification for Thermocouple Compensating Cables/ 热电偶补偿电缆
IS 9857 : 1990Welding Cables – Specification/ 焊接电缆
IS 14494 : 2019Elastomer Insulated Flexible Cables for Use in Mines – Specification 矿山用弹性体绝缘软电缆
IS 2593 : 1984Specification for Flexible Cables for Miner’s Cap-Lamps 用于矿工帽灯的柔性电缆
IS 5950 : 1984Specification for Shot Firing Cables (for use other than in shafts) 放炮电缆,爆破电缆,引燃电缆(用于轴以外的用途)
IS 17048 : 2018Halogen Free Flame Retardant (HFFR) Cables for Working Voltages Up to   and Including 1100 V – Specification 额定电压不超过1100 V的无卤阻燃(HFFR) 电缆
BIS认证是ISI认证发证机构印度标准局(The Bureau of Indian Standards),简称BIS,具体负责产品认证工作,它是印度唯一的产品认证机构。
ISI标志的申请周期长达半年,流程复杂,需要准备大量的文件资料,同时涉及到印度政府人员上厂审核。
贝客乐认证服务(广州)有限公司是印度贝客乐集团在中国设立的唯一办事处,专业服务出口印度的国内厂商,在印度有七个实验室,
知名合作伙伴有格力,美的,奥克斯,明纬,小米,惠普,三星,OPPO, 万和等;涉及行业包含电子零部件,电线电缆,大小家电,玩具,化学,钢材等等;
广州办事处成立以来协助上百家企业获得ISI证书,具有丰富的案例经验,还有服务本地化的一条龙优势,同时在印度当地有着深厚的资源。
业务咨询请联系:张小姐 18998298720(微信同号)
higher-order-mode filtering - 高次模滤波 (3) 投诉
P:2020-03-14 14:05:30
ISDN - integrated services digital[data]network综合服务数字[数据]网 (0) 投诉
P:2020-04-03 10:48:52
只待疫情过去万物复苏
combiner - 结合器,合光器 (0) 投诉
