[架空电缆] 10kV架空交联聚乙烯绝缘线的研制_韩续
P:2008-03-29 19:15:26
10KV架空交联聚乙烯绝缘线的研制.
oceanic exploiation cable - 海洋开发电缆 (0) 投诉
P:2008-04-05 17:15:11
噢,不错。
salvageging department - 利用车间;日用品生产车间 (0) 投诉
P:2008-04-14 09:42:52
不错,很值得一看!IEC60502是客户最厂要的标准!
Cross-linked polyethylene insulated power cable not only has excellent electric, mechanical properties, but also has powerful resistance against heat aging, environmental stress and chemical corrosion. Its structure is simple and convenient to use and can be laid with no restriction of different elevation.The permissible maximum operating temperature is 90℃. Our XLPE cable can be produced according to our company standard which is equivalent IEC60502. We can design and manufacture special XLPE cable according to the required by the customers.
Type
Description
Application
Cu core
Al core
YJV
YJY
YJLV
YJLY
XLPE insulated,PVC or PE sheathed power cable
For laying indoor, tunnel, channel and underground. Unable to bear external mechanical forces,but bear the traction force during laid
YJLV22
YJV23
YJV22
YJV23
XLPE insulated, steel tape armoured,PVCorPE sheathed power cable
For laying indoor, tunnel, channel and underground. Able to bear external mechanical forces, but unable to bear large pulling force
YJLV32
YJLV33
YJV32
YJV33
XLPE insulated, fine steel wire armoured, PVC or PE sheathed power cable
For laying in shaft, with large difference of level.able to bear external machanical forces andmoderate pulling force.
YJLV42
YJLV43
YJV42
YJV43
XLPE insulated, thick steel wire armoured,PVC or PE sheathed power cable
Able to bear positive pressure and pulling force
Karen
MSN: karenhncable@hotmail.com
multi-conductor cables - 多芯电缆 (0) 投诉
P:2008-05-22 21:04:51
对梗概内容能不能介绍一下?
谢谢
core spacing disc - 分线板 (0) 投诉
P:2008-05-23 09:24:56
新人 没金币能否发到我的邮箱jiangkun246@163.com
我是一名即将毕业的大学生
我正做一个10KV架空绝缘电缆的结构设计的题目
需要参考下您的 资料
谢谢了
sector-shaped solid aluminium conductor - 扇形实心铝导体 (0) 投诉
P:2008-05-25 17:55:41
谢谢
Low Tension - 低压。如使用在汽车之电线,电池与啟动马达之电线,汽车灯光用电线等。 (0) 投诉
P:2008-05-25 21:32:04
太谢谢 支持
ACSE - ACSR/AS铝包钢芯铝绞线 (0) 投诉
P:2008-05-27 16:40:09
好东西呀
branch chute - 支路,分支电路 (0) 投诉
P:2009-03-24 13:27:55
能否给我发份啊
xl0415@21cn.com
fireproofing solution - 防火溶液 (0) 投诉
P:2009-03-24 15:30:57
看后感觉有用的总结:碳黑能吸收紫外线,提高绝缘电缆的耐老化(耐气候)性能,当加入量大于1%时,电气性能(介电强度)开始下降。
anti-slipping drawing machine - 防滑动拉线机 (0) 投诉
P:2009-04-06 11:37:31
能否发一份到我邮箱!毕业设计需要啊!谢谢先!zhanglei20082009@129.com
multiple head concentric taping machine - 多头同心包带机 (0) 投诉
P:2009-04-08 08:41:29
呵呵,不错,这里能人不少啊
tracer - (线芯)标记,色标;故障探测器;测量头 (0) 投诉
