首页 > 国外线缆
[问题求助] 关于UL1032线材有什么特殊要求吗?
P:2008-03-28 08:53:36
请问有人知道UL1032线材有什么特殊要求吗?
APL - Aluminium Plastic Laminate (sheath construction)铝塑粘结护层结构 (0) 投诉
P:2008-03-28 09:18:11
UNDERWRITERS LABORATORIES INC.                APPLIANCE WIRING MATERIAL
Subj. 758      Section 1          Page 1032       Issued:  1959-05-01
                                    Revised:  2003-02-25
Style 1032        PVC Insulated Wire.
______________________________________________________________________________
Rating     90 deg. C, 1000 V ac and/or 1200 V dc.
Conductor        Nos. 30 AWG - 2000 MCM.
*Insulation       PVC, Class 43.
                           Min Avg        Min at Any Point
                AWG        Mils                  Mils
                      30-9            30         27
                8           45         40
                7-2         60         54
                1-4/0           80         72
                250-500  MCM         95           86
                550-1000 MCM       110        99
               1100-2000 MCM     125            112
Covering       Optional.  PVC, same compound as insulation,
           5 mils minimum at any point, 40 mils maximum.
Shield       Optional.
Jacket     Optional.  PVC, Class 43, 30 mils minimum average,
           23 mils minimum at any point.
Standard       Appliance Wiring Material UL 758.
Instructions    Detailed Examination.
to UL          Physical Properties of Insulation and Jacket, Unaged.
Representative     Spark Test.
UL            (4)  Detailed Examination.
Counter-Check     (4)  Physical Properties of Insulation and Jacket.
Program          (4)  Heat Shock.
             (4)  Cold Bend.
           (4)  Deformation.
*                (12) Horizontal Flame Test.
Marking        General.
Use        Internal Wiring of Appliances; or where exposed to oil at
           a temperature not exceeding 60 deg. C or 80 deg. C                    (whichever is applicable).  Tags may also indicate the                following:  3500 V peak - for electronic use only.
five fold quadding machine - 五头星绞机 (0) 投诉
P:2008-03-28 09:53:16
没有什么特殊要求,和1015差不多的
plastic extruding - 挤塑 (0) 投诉
P:2008-03-28 10:46:36
是的,属于高压电线
mastic - 膏,胶,粘合剂,涂料 (0) 投诉
P:2008-03-28 14:51:27
最普通的要求了。。常规的东西
anti-treeing additive - 防“树枝”添加剂 (0) 投诉
P:2008-03-28 18:39:29
我知道了,谢谢各位!!!
extruding machine - 挤出机 (0) 投诉
