首页 > 标准共享
[国外标准] BS EN 50265-1:1999 Common test methods for cables under fire conditions – Test for resistance to vertical flame propagation for a single insulated conductor or cable – Part 1: Apparatus
P:2019-09-19 08:43:32
BS EN 50265-1:1999 Common test methods for cables under fire conditions – Test for resistance to vertical flame propagation for a single insulated conductor or cable – Part 1: Apparatus.pdf
voltmeter-ammeter method - 电压-电流法 (0) 投诉
P:2023-11-07 14:53:12
有中文版的吗?
conductivity-imparting agent - 导电添加剂 (0) 投诉
