首页 > 连接器 插头附件
[连接端子] 1-120532-1/1-1658012-1泰科TE进口原装镀金插座1-1735482-0/1-2040478-2/1-2041342-2
P:2019-09-04 14:16:32
凌创辉电子 杨R:19925400835(WX同号) Q:2457426377
制造商 TE Connectivity AMP Connectors
制造商零件编号 1-1658012-1
描述 CONN DIFF ARRAY RCP 28P SMD GOLD
详细描述 28-位置-连接器-差分对阵列-母-表面贴装型-金
零件状态 有源
类别 连接器,互连器件
产品族 矩形连接器 - 阵列,边缘型,夹层式(板对板)
系列 MICTOR
连接器类型 差分对阵列,母
针脚数 28
间距 0.031"(0.80mm)
排数 2
安装类型 表面贴装型
特性 板导轨,接地母线(板)
触头镀层 金
触头镀层厚度 10.0μin(0.25μm)
接合堆叠高度 5mm,8mm,11mm,14mm,16mm,19mm,22mm,25mm,30mm
板上高度 0.128"(3.25mm)
1-120521-1TE Connectivity AMP Connectors
1-120521-2TE Connectivity AMP Connectors
1-120524-1TE Connectivity AMP Connectors
1-120527-1TE Connectivity AMP Connectors
1-120528-1TE Connectivity AMP Connectors
1-120529-1TE Connectivity AMP Connectors
1-120531-1TE Connectivity AMP Connectors
1-120532-1TE Connectivity AMP Connectors
1-120533-1TE Connectivity AMP Connectors
1-120534-1TE Connectivity AMP Connectors
1-120534-2TE Connectivity AMP Connectors
1-146888-1TE Connectivity AMP Connectors
1-146893-1TE Connectivity AMP Connectors
1-146897-1TE Connectivity AMP Connectors
1-1554700-0TE Connectivity AMP Connectors
1-1554701-0TE Connectivity AMP Connectors
1-1565359-1TE Connectivity AMP Connectors
1-1658012-1TE Connectivity AMP Connectors
1-1658012-2TE Connectivity AMP Connectors
1-1658012-3TE Connectivity AMP Connectors
1-1658012-4TE Connectivity AMP Connectors
1-1658012-5TE Connectivity AMP Connectors
1-1658013-2TE Connectivity AMP Connectors
1-1658013-3TE Connectivity AMP Connectors
1-1658014-3TE Connectivity AMP Connectors
1-1658015-2TE Connectivity AMP Connectors
1-1658015-4TE Connectivity AMP Connectors
1-1658043-1TE Connectivity AMP Connectors
1-1658043-2TE Connectivity AMP Connectors
1-1658043-3TE Connectivity AMP Connectors
1-1658043-4TE Connectivity AMP Connectors
1-1658043-5TE Connectivity AMP Connectors
1-1658044-1TE Connectivity AMP Connectors
1-1658044-4TE Connectivity AMP Connectors
1-1658046-3TE Connectivity AMP Connectors
1-1658047-1TE Connectivity AMP Connectors
1-1658049-1TE Connectivity AMP Connectors
1-1658050-2TE Connectivity AMP Connectors
1-1658051-1TE Connectivity AMP Connectors
1-1658051-2TE Connectivity AMP Connectors
1-1658062-1TE Connectivity AMP Connectors
1-1658062-2TE Connectivity AMP Connectors
1-1658062-3TE Connectivity AMP Connectors
1-1658062-4TE Connectivity AMP Connectors
1-1658062-5TE Connectivity AMP Connectors
1-1658063-2TE Connectivity AMP Connectors
1-1658071-1TE Connectivity AMP Connectors
1-1658071-2TE Connectivity AMP Connectors
1-1658071-3TE Connectivity AMP Connectors
1-1658071-4TE Connectivity AMP Connectors
1-1658071-5TE Connectivity AMP Connectors
1-1658437-4TE Connectivity AMP Connectors
1-1658462-1TE Connectivity AMP Connectors
1-1658462-2TE Connectivity AMP Connectors
1-1658462-3TE Connectivity AMP Connectors
1-1658462-4TE Connectivity AMP Connectors
1-1658462-5TE Connectivity AMP Connectors
1-1658463-2TE Connectivity AMP Connectors
1-1658467-2TE Connectivity AMP Connectors
1-1658486-1TE Connectivity AMP Connectors
1-1658486-2TE Connectivity AMP Connectors
1-1658486-3TE Connectivity AMP Connectors
1-1658486-4TE Connectivity AMP Connectors
1-1658486-5TE Connectivity AMP Connectors
1-1734054-2TE Connectivity AMP Connectors
1-1735481-0TE Connectivity AMP Connectors
1-1735482-0TE Connectivity AMP Connectors
1-1735821-0TE Connectivity AMP Connectors
1-1761612-0TE Connectivity AMP Connectors
1-1761612-2TE Connectivity AMP Connectors
1-1761612-3TE Connectivity AMP Connectors
1-1761612-5TE Connectivity AMP Connectors
1-1761613-5TE Connectivity AMP Connectors
1-1761614-0TE Connectivity AMP Connectors
1-1761614-3TE Connectivity AMP Connectors
1-1761614-5TE Connectivity AMP Connectors
1-1761615-1TE Connectivity AMP Connectors
1-1761615-5TE Connectivity AMP Connectors
1-1761616-0TE Connectivity AMP Connectors
1-1761616-2TE Connectivity AMP Connectors
1-1761616-3TE Connectivity AMP Connectors
1-1761616-5TE Connectivity AMP Connectors
1-1761617-1TE Connectivity AMP Connectors
1-1761617-5TE Connectivity AMP Connectors
1-1775015-2TE Connectivity AMP Connectors
1-1775149-2TE Connectivity AMP Connectors
1-179029-0TE Connectivity AMP Connectors
1-179208-4TE Connectivity AMP Connectors
1-179208-6TE Connectivity AMP Connectors
1-179208-8TE Connectivity AMP Connectors
1-179397-2TE Connectivity AMP Connectors
1-179868-0TE Connectivity AMP Connectors
1-179871-0TE Connectivity AMP Connectors
1-1981983-1TE Connectivity AMP Connectors
1-2007211-6TE Connectivity AMP Connectors
1-2007614-0TE Connectivity AMP Connectors
1-2007614-5TE Connectivity AMP Connectors
1-2040478-2TE Connectivity AMP Connectors
1-2041113-4TE Connectivity AMP Connectors
1-2041342-2TE Connectivity AMP Connectors
beam propagation method - 光束传播法,射束传播法 (0) 投诉
