首页 > 产品认证
[VDE认证] 出口到法国,VDE是不是强制需要的?
P:2009-06-08 13:22:21
key requirements acc. to low voltage directive (LVD) for power cord with IEC connector:<DIV> </DIV><DIV>wall socket plug - must be without CE sign</DIV><DIV>cable - must be with CE or VDE sign</DIV><DIV>IEC plug - must have CE sign</DIV><DIV> </DIV><DIV>If IEC plug is with NF or VDE sign, then relatd certifications must be presented of course! However, if this plug is with CE sign and LVD certificate + test report, then no NF / VDE sign required!</DIV><DIV> </DIV><DIV>希望上述信息对你有用</DIV>
potted joint - 封装接头,密封接头(树脂浇铸或模制) (0) 投诉
16
