首页 > 国外线缆
[问题求助] 请问UL1571 14AWG电子线额定电压是多少V?
P:2008-03-20 13:58:18
请问UL1571 14AWG电子线额定电压是多少V?是30V还是300V请各位同行们赐教!
junction box - 连接盒,分线盒,接线盒 (0) 投诉
P:2008-03-20 14:15:56
1571 你们做到14#这么大吗?1571类电子线的额定电压是300V呀
--------------电压应该为30V
[芝麻开门了 在 2008-3-29 16:46:52 编辑过]
eight-form wire - 8字形导线 (0) 投诉
P:2008-03-20 14:39:17
30V啊,上楼的不要误导啊!!!
UNDERWRITERS LABORATORIES INC.                  APPLIANCE WIRING MATERIAL
Subj. 758           Section 1          Page 1571        Issued:  1972-12-27                                  Revised:  2003-08-06
Style 1571     PVC Insulated Cable.
______________________________________________________________________________
Rating     80°C, 30 V.
Conductor      50 AWG min.  Material and stranding not specified.
Insulation     Solid or cellular PVC, or semi-rigid PVC, 2 mils min at
           any point, 100 mils max.  Irradiation optional. ______________________________________________________________________________
Covering       Extruded PVC, Polyamide, ETFE, or Polyester 2 mils min at
(Optional)     any point, or lacquered braid Irradiation optional.
Shield     Optional.
(Optional)
Jacket     Same as covering.
(Optional)
Shield     Optional.
Covering       Optional, same as covering.
Standard       Appliance Wiring Material UL 758.
Instructions    Detailed Examination.
to UL
Representative
UL         (4)  Detailed Examination.
*Counter-Check  (12) Horizontal Flame Test.
Program
Marking        General.
Use        Internal Wiring of Class 2 Circuits in electronic equipment.
Backbone/Riser Closet - 主干/竖井间 (0) 投诉
P:2008-03-20 15:00:33
谢谢了,如果有中文版本的就好了,我本人对英文不是很熟
radio-frequency cable - 射频电缆 (0) 投诉
P:2008-03-25 08:29:42
是30V,80度,
electrode - 电极,电焊条 (0) 投诉
P:2008-03-25 13:53:27
请问:UL安规电压和导线的额定电压有什么区别和联系阿?谢谢!
mill - 轧机,轧制设备;轧制 (0) 投诉
P:2008-03-26 16:59:05
这本来就是一个东东呀,安规电压可以高于额定电压
CPU - central processing unit中央处理装置 (0) 投诉
P:2008-03-28 15:04:59
80°C, 30 V.
cable vulcanizer - 电缆硫化器 (0) 投诉
P:2010-04-12 14:28:21
30v
telephone cable for long-distance service - 长途电话电缆 (0) 投诉
P:2010-04-13 17:09:37
直接查看UL Style Page 1571 ,额定电压是30V.
quadded cable - 四线组电缆 (0) 投诉
P:2010-04-13 21:25:03
同意楼上
die arm - 模臂(编织机的) (0) 投诉
P:2010-04-14 08:07:55
Rating80 deg C, 30 Vac, Horizontal flame.
80度   30V   水平燃烧测试!!!STYLE上面写得很清楚!!!英文还是要学习学习的!不然你做UL就是瞎子摸大象!
AC - 交流(Alternating Current)之缩写。 (0) 投诉
P:2010-04-29 17:36:20
学习了
aerial lug - 电缆头出线端子,电缆头出线夹头 (0) 投诉
P:2010-04-30 08:50:26
我看到一个 80 30 就明白了。。。 英文我们不需要背 只需要了解下就可以了
CCUAP - Computerized Cable Upkeep Administrative Program计算机化电缆维护管理程序[计划] (0) 投诉
