[USB] USB 2.0 镀金厚度有什么要求
P:2008-03-18 13:52:08
各大虾:USB 2.0 镀金厚度有什么要求?
schedule - 表格 (0) 投诉
P:2008-03-19 12:22:00
度金,我是不知道,度SN我是知道!
rupture test - 断裂试验 (0) 投诉
P:2008-03-19 20:12:06
下一个USB的规范,里面有接头镀层厚度的要求
autonatic cutover - 自动换盘,自动换盘装置 (0) 投诉
P:2009-03-31 14:06:06
glass bead - 玻璃球 (0) 投诉
P:2009-03-31 16:22:20
沒有吧
soft PVC - 软聚氯乙烯 (0) 投诉
P:2009-04-03 15:26:56
15μ或30μ
polymethyl-methacrylate - 聚甲基丙烯酸甲酯 (0) 投诉
P:2009-04-29 17:09:25
USB标准里有写的,好像不是15μ或30μ
bore check - 精密小测定器 (0) 投诉
P:2009-04-29 20:50:51
2.0   30u"
center hole - 中心孔(线盘的) (0) 投诉
P:2009-04-30 10:15:20
6.5.4.3 Plug (Male) Contact Materials
Substrate Material: 0.30 + 0.05 mm half-hard phosphor bronze.
Plating: Contacts are to be selectively plated.
A. Option I
1. Underplate: Minimum 1.25 micrometers (50 microinches) nickel. Copper over base material
is optional.
2. Mating Area: Minimum 0.05 micrometers (2 microinches) gold over a minimum of
0.70 micrometers (28 microinches) palladium.
3. Solder Tails: Minimum 3.8 micrometers (150 microinches) bright tin-lead over the
underplate.
B. Option II
is optional.
0.75 micrometers (30 microinches) palladium-nickel.
3. Wire Crimp/Solder Tails: Minimum 3.8 micrometers (150 microinches) bright tin-lead over
the underplate.
C. Option III
is optional.
2. Mating Area: Minimum 0.75 micrometers (30 microinches) gold.
underplate.
OWF - optimum working frequency最佳工作频率 (0) 投诉
P:2009-04-30 10:17:00
是指这一条吗,那应该是0.75um
carrier induced phase modulation - 自相位调制 (0) 投诉
P:2010-03-30 11:56:10
USB1.1----插头端子镀金15U"
USB2.0----插头端子镀金30U"
chlorination catalyst - 氯化催化剂 (0) 投诉
P:2010-04-06 21:28:39
去看SPEC吧,好象有几个option吧。
glass yarn - 玻璃丝 (0) 投诉
P:2010-04-07 09:16:41
Thanks
single drive - 单独传动装置 (0) 投诉
P:2020-04-01 14:42:48
transposing head - 换位头 (0) 投诉
