[问题求助] displayport发布标准1.1a
P:2008-03-16 08:05:26
VESA在2008年1月份发布最新的displayport1.1a标准和displayport面板连接器标准
VESA DisplayPort Standard
Version 1, Revision 1a
January 11, 2008
Purpose
The purpose of this document is to define a flexible system and apparatus capable of transporting video, audio
and other data between a Source Device and a Sink Device over a digital communications interface.
Summary
The DisplayPort™ standard specifies an open digital communications interface for use in both internal
connections, such as interfaces within a PC or monitor, and external display connections, including interfaces
between a PC and monitor or projector, between a PC and TV, or between a device such as a DVD player and
TV display.
DisplayPort.1.1a is revised to correct errata items in, and add clarifications to, DisplayPort Standard 1.1.
由于标准太大无法上传,请版主想法解决,先只上传displayport与DVI及HDMI转接互动标准上传
[surefireli 在 2008-3-16 8:06:43 编辑过]
stacking crane - 码垛起重机 (0) 投诉
