[问题求助] UL与BS EN 标准疑问?
P:2008-02-20 23:28:27
想請教各位:我司的網路線材是申請過UL認證(通信纜線)ul444標準.那現在英國客戶在問!
我們的線材是否可以通過(英國客戶發的E_MAIL)
Does the cable comply with EN50288-3-1 ?
Is insulation diameter 1.00mm +/- 0.06mm
Does insulation material meet BS EN 50290-2-23 ?
Is cable diameter 4.95mm =/- 0.125mm ?
Does sheath material meet BS EN 50290-2-27 ?
Is the cable tested to BS EN 60332-1-2 ?
Smoke emission tests to BS RN 61034-2
Acid gas emissions to BS EN 50267-2-1 ?
Are the materials tested in accordance with BS EN 50267-2-1 ?
Are the materials tested to in accordance with BS EN 50267-2-3 (
corrosivity of evolved gases ) ?
The supplier shall confirm that the flammability temperature of the
cable sheath material shall be at least 280 DegC when tested in
accordance with BS EN ISO 4589-3. Testing shall be carried out in an
externally certified test house.
假設性說我們公司申請UL認證的數據套用在這些標準>就能證明我們公司的現在可以通過BS EN 規範嗎?
是否有前輩可以替我說明呢!~以下是我的聯絡方式
QQ 553029669 MSN rudy2104@hotmail.com
Fibernet - 光纤以太网 (0) 投诉
